190E Stalls - Page 11 - Mercedes-Benz Forum
post #101 of 128 (permalink) Old 12-02-2008, 09:26 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 695 Post(s)
Originally Posted by drewprof View Post
Thanks Z that's some good stuff
Do as gOD says. Do not deviate, do not improvise.
GeeS is offline
post #102 of 128 (permalink) Old 12-02-2008, 09:59 AM
slybydesign's Avatar
Date registered: Jan 2007
Vehicle: My Two Left Feet
Originally Posted by GermanStar View Post
Wrong car, Sly.
Sorry. thanks GermanStar. At least you let me know. Now I know I can fully ignore this thread in shame....
3. Paul Hamm, Gymnast: I owe a lot to my parents, especially my mother and father.
slybydesign is offline
post #103 of 128 (permalink) Old 12-02-2008, 10:09 AM
Surely A Large Human
Qubes's Avatar
Date registered: Jun 2006
Vehicle: '08 C219
Quoted: 564 Post(s)
Drew, have you tried to suck-start it? You tip-toe pole-dancing fairy?
Qubes is offline
post #104 of 128 (permalink) Old 12-02-2008, 11:37 AM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1038 Post(s)
I am I am
DP is offline
post #105 of 128 (permalink) Old 12-02-2008, 11:39 AM Thread Starter
DP
DP's Avatar
Originally Posted by slybydesignw210 View Post
Does the car have allot of carbon build up in the TB or the EGR? I had odd idle and had to trouble shoot all those things, cleaning the MAF and Throttle Body helped for me, and now I am cleaning the EGR Valve.
No MAF in this car but a Seafoam snake oil is in order to clean the intake
DP is offline
post #106 of 128 (permalink) Old 12-02-2008, 11:41 AM
I haven't used that stuff but saw it at Walmart the other day. Does this stuff really work, I hear much about it.
post #107 of 128 (permalink) Old 12-02-2008, 11:47 AM Thread Starter
DP
DP's Avatar
I don't know, some people swear by it and some just categorize it as snake oil
DP is offline
post #108 of 128 (permalink) Old 12-02-2008, 12:14 PM
I may try this out. Who knows, I don't want to try and fix something thats not broken.
post #109 of 128 (permalink) Old 12-03-2008, 11:04 AM Thread Starter
DP
DP's Avatar
Originally Posted by Zeitgeist View Post
The fuel regulator was a common source of problems for the early CIS cars (again, pressure related), but Drew's 201 has CIS-E, which has incorporated that feature into the fuel distributor. Harbor Freight has an inexpensive fuel injection test kit, which I believe has the appropriate fittings and switch valve for testing CIS injection pressures. I'm pretty sure it's a cheap knock-off of the Snap-On version I own.
I bought that kit this morning from HF I will be playing with the CIS tomorrow.
Wish me luck
DP is offline
post #110 of 128 (permalink) Old 01-11-2009, 12:44 PM Thread Starter
DP
DP's Avatar
Update:
I installed an ICV today and this POS is still stalling!
Here is a list of things done:
ICV
ICV hoses
Fuel Pump
Fuel Filter
Fuel pressure test: Passed
Lambda test: Passes
EHA current test: Passed
Compression on all cylinders: Passed
Timing: adjusted
Spark plugs and wires
Signal from ignition: Passed and clean
Ground testing: Passed using a probe and a signal generator
Exhaust and Cat: New
Car has no oil leaks or head gasket issues.
The economy gauge reads 1/4 (to almost 1/2 sometimes) when the car is stopped but in gear; it will go to ZERO if in neutral or park (Everyone I asked seems to have the same reading, however this is not the case with my 560SEL, it only registers on that gauge if I press on the gas like it should)
What do I do now?
DP is offline
    My 190E stalls if the temp is below -15 deg C Guest (MBNZ) W201 190-Class 5 01-19-2016 10:21 AM
    86 190E stalls at startup m4411b W201 190-Class 3 10-09-2005 02:38 PM
    190E stalls when cold ssanmor W201 190-Class 4 03-08-2005 10:57 PM
    85 190E 2.3 stalls jaguarnaut W201 190-Class 5 08-30-2004 09:49 PM
    190E splutters and stalls Guest (MBNZ) W201 190-Class 16 11-18-2003 03:43 AM
