Joel Schneider I need your help - Page 4 - Mercedes-Benz Forum
post #31 of 34 (permalink) Old 11-15-2008, 09:33 PM Thread Starter
worst mod in BW history
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK Iridescent Hyundai Accent lol,GoPed Freightshaker & Volvo semi's, c'mawn?
Quoted: 4 Post(s)
Originally Posted by joelschneider View Post
Sorry I did not see this sooner tk. The meter you have there is a a/c votage meter. It will read continuity regardless of what terminal you have it on because it will read through light bulbs circuit boards ect. Your best option would be to get a 12 v dc meter from a hardware store for about $10 or so. Then you can get a reading of which one has 12 volts going to it. If you wire it backwards you will have the hot and nuetral reversed on the 120 volt side of the inverter. If they bonded the ground on the outlet to the nuetral there is a good chance you are going to let the smoke out of it. Once the smoke is let out they do not work so well anymore. Some of the higher quality inverters have overload protection that will shut off power if the current is too high, but I don't think I would risk it. I would get a 12 volt dc meter or run new wires myself. Let me know if you need anything else.
Thanks. I swear something is amiss because I've hooked up invertersd with no problem before. btw, when the "smoke let out" it looked exactly like when the tape self destructed after Phelps got his instructions.
ThrillKill is offline
post #32 of 34 (permalink) Old 11-16-2008, 07:02 AM
Forum Administrator RC Colas® & Moon Pies®
Digmenow's Avatar
Date registered: Oct 2006
Vehicle: 1981 380SL 151K: 2001 E320 4Matic Estate 147K: 2008 E350 Sport 4Matic 120K: 2005 S500 116K
Quoted: 1390 Post(s)
... If you wire it backwards you will have the hot and nuetral reversed on the 120 volt side of the inverter....
subliminal
Quis custodiet ipsos custodes?
Digmenow is online now
post #33 of 34 (permalink) Old 11-16-2008, 07:10 AM
Digmenow's Avatar
Originally Posted by drewprof View Post
DO NOT MIX THE INPUT WITH THE OUTPUT!
They both DO NOT share a common ground. That's what probably fried your toy.
Don't cross the streams!
post #34 of 34 (permalink) Old 11-16-2008, 07:22 AM
Moderately subtle
edfreeman's Avatar
Date registered: Dec 2003
Vehicle: 94 E500, 97 500SL
Quoted: 91 Post(s)
Send a message via AIM to edfreeman
TK, if I'm reading the instruction booklet for your tester correctly, you can't use it the way you are trying to. If you look on the 2nd page where the chart of the LED's behavior is shown, you should get the following:
1. With the red test lead on a + DC wire and the black test lead on chassis ground, the tester will be seeing 12V DC + and the LED's will show up as given in the 4th line of the chart, meaning neon off, Left LED On (the one labelled + DC), right LED off, no movement on scale.
2. With the red test lead on a - DC wire and the black test lead on chassis ground, you'll be measuring continuity (both are at the same potential), and the LED's will show up as given in the 1st line of the chart, which just happens to be the same as condition 1.
The only way to use the tester for what you're intending is to separate the two wires you wish to hook the inverter up to, put a test lead on each, and your tester LED's will behave as shown on line 4 with the LED lit depending on whether the red wire is on + or -.
edfreeman is offline
    DTM Champion Bernd Schneider To End Racing Career And Become Mercedes-AMG Brand Ambas everythingmercedes Mercedes-Benz Motorsports & Racing 2 10-30-2008 11:06 PM
    Billy Joel smack R/C107 SL/SLC Class 2 08-23-2007 07:56 AM
    Bernd Schneider knows what he speaks about... MB_Racer R170 SLK-Class 4 11-20-2000 07:04 AM
