Spring Compressor - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 11-09-2008, 03:07 PM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1065 Post(s)
Spring Compressor
What do you think?
eBay Motors: Mercedes Benz Coil Spring Compressor Suspension Tools (item 110305512036 end time Nov-28-08 06:00:53 PST)
DP is offline
post #2 of 11 (permalink) Old 11-09-2008, 03:12 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1632 Post(s)
Well, I paid something like $400 for the original German Klann design, and those things are under tremendous pressure. I don't think I'd trust cheap Taiwanese or Indian metals for this purpose. YMMV
Zeitgeist is offline
post #3 of 11 (permalink) Old 11-09-2008, 03:14 PM Thread Starter
DP
DP's Avatar
DP is offline
post #4 of 11 (permalink) Old 11-09-2008, 03:15 PM
slightly creased
420 SE's Avatar
Date registered: Sep 2005
Vehicle: 1988 420 SE; 2015 ML 400
Quoted: 144 Post(s)
can you not rent them?
Ross
OzBenz
beware of fundamentalists
420 SE is offline
post #5 of 11 (permalink) Old 11-09-2008, 03:17 PM
Cruise Control
Zeitgeist's Avatar
Looks like it would work nicely for McPherson struts, but not so much for early MB stand-alone springs.
post #6 of 11 (permalink) Old 11-09-2008, 03:17 PM Thread Starter
DP
DP's Avatar
I could but I have ADD and I will get distracted and forget that the car is apart then go flirt around or waste time in OT
DP is offline
post #7 of 11 (permalink) Old 11-09-2008, 03:20 PM
Shane's Avatar
Vehicle: Taking my time on my ride
Quoted: 1795 Post(s)
Try very rigid struts or shocks by KYB before killing yourself with that job. If that fails and height is the issue put in a spacer.
Shane is offline
post #8 of 11 (permalink) Old 11-09-2008, 03:22 PM Thread Starter
DP
DP's Avatar
I wanted to take the front springs out to replace the control arm bushings. I don't need to replace the struts, they are fine.
The rear, I might want to replace the rubber top ends so I can make the car stop groaning.
(W126)
DP is offline
post #9 of 11 (permalink) Old 11-09-2008, 03:57 PM
Surely A Large Human
Qubes's Avatar
Date registered: Jun 2006
Vehicle: '08 C219
Quoted: 640 Post(s)
Can you do "coil binding" with one of those?
Qubes is offline
post #10 of 11 (permalink) Old 11-09-2008, 04:12 PM
TNTRower's Avatar
Date registered: Sep 2007
Vehicle: '98 E320 Wagon (non 4matic)
Send a message via AIM to TNTRower
In all seriousness drewprof go to the w210 forum and poke around. The guys over there love to lower the 210's. Some of the guys I think actually used those ebay ones with good results.
I agree that the pressure is tremendous and if your were using these in a shop you would want to go for the Klann design. If you are only using them for a few jobs then I think they should be ok. Again though, poke around the W210 and look for positngs by OhLord.
Who's John Galt.
"Timeo Danaos et dona ferentes" - Virgil, The Aeneid, Book 2
If the Arabs put down their weapons today, there would be no more violence. If the Jews put down their weapons today, there would be no more Israel. --Benjamin Netayahu
TNTRower is offline
do you have a spring compressor? NüR-SPEC W126 S,SE,SEC,SEL,SD,SDL Class 20 05-29-2007 06:16 AM
My new spring compressor is on the way. hotwheelbill W123 E,CE,D,CD,TD,TE Class 0 03-26-2007 11:58 AM
Linh, do you know how to change spring pads without a spring compressor? SteveL R170 SLK-Class 7 04-05-2002 01:34 PM
PROCEDURE FOR SPRING INSTALLATION WITHOUT THE SPRING COMPRESSOR Linh R170 SLK-Class 0 06-20-2001 09:34 AM
CHANGE SPRING WITHOUT USING SPRING COMPRESSOR..? YES, I DID MY YESTERDAY. Linh R170 SLK-Class 3 05-07-2001 02:34 PM
