Next Audi S4 to get 333hp supercharged V6 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-23-2008, 08:25 PM Thread Starter
Date registered: Nov 2006
Supercharged V-6 to pump out 333hp
Audi has just released info on the European version of the next Audi S4 and it’s no surprise that it utilizes forced induction. Rather than Audi’s usual method of turbocharging cars, the new S4 is supercharged and makes 333hp at and pumps out 324 ft-lbs of torque from 2500 to 4850 rpm. Audi claims a 0-100 km run of 5.1 seconds, so the run to 60 mph could be five seconds flat or even in the four second range!
Other highlights include the optional S Tronic seven-speed dual clutch transmission.
The new S4 will also include “Audi Drive Select” which will allow drivers to choose from “comfort” “dynamic” or “auto” modes. Depending on the mode the ECU will change the throttle response, the S-Tronic shift points and the speed-dependent servotronic steering. And if the vehicle is equipped with the MMI operating system, the driver can customize these settings in a fourth mode. This system also works in conjunction with the optional dynamic shock absorbers, dynamic steering and the active sport differential, which can adjust power from the left and right rear wheels in just 100 milliseconds so almost 100 percent of the power can be sent to one wheel.
Full Story & Press Release Here
Luxury&Exotics is offline
    Supercharged? mpbruin108 W210 E-Class 4 04-28-2007 09:52 AM
    Supercharged? Chauffeurdave W126 S,SE,SEC,SEL,SD,SDL Class 1 05-11-2006 12:59 PM
    Supercharged Blokhus R170 SLK-Class 10 01-30-2005 06:12 PM
    supercharged.......... sebastian W126 S,SE,SEC,SEL,SD,SDL Class 6 12-05-2003 05:19 PM
    I used to love Audi TT because of its unique look and style but now I HATE Audi TT!! ..... Andy ::VancouveR:: R170 SLK-Class 5 07-15-2003 11:00 AM
