Trying to figure out this DJIA thing!?!? - Page 5 - Mercedes-Benz Forum
post #41 of 47 (permalink) Old 09-17-2008, 06:22 AM
~BANNED~
Jakarta Expat's Avatar
Date registered: Aug 2006
Vehicle: PM me to Join the Expat Muslims for Obama Club........
Quoted: 4 Post(s)
Originally Posted by drewprof View Post
You got the half wave right but then you mess up with you voltage assessment, you still kept the output at 20Vpp. Yes, you will get a 1.7V drop due to two diodes for each half cycle but that would be subtracted from 10Vpp
I agree, don't use a resistor based voltage divider because you will be consuming energy at no load. Remember that a current will be going through R1 and R2 of said divider and your output impedance is low anyway which can be a problem once you plug in a load. Next, your best bet is to use the large enough resistor value with a capacitor at each end of the output of the bridge rectifier. That would filter the signal and you got your analysis correct about what could happen with the balance if you use too large or too low of a value. The simplest way to obtain the 8Vdc after that is to use a Zener diode but Op amps are better like you mentioned but to a certain degree, that is how much current do you want this "power supply" to output? You have to figure that automotive applications require much higher currents than say, an audio amp or some control circuitry.
Right, but why is it your wife still complains you can't fix the light next to the bed?
Jakarta Expat is offline
post #42 of 47 (permalink) Old 09-17-2008, 06:32 AM
~BANNED~
Quoted: 4 Post(s)
God Damn the Dow just dropped 200 points within 3 minutes of the opening bell...........
post #43 of 47 (permalink) Old 09-17-2008, 07:20 AM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1046 Post(s)
With me being on BWOT so much I guess she forgot to unplug her vibrator hence there is no power to the table lamp, besides that's a dedicated 240V line anyway
DP is offline
post #44 of 47 (permalink) Old 09-17-2008, 12:36 PM
Haddixracing
Guest
Posts: n/a
Quoted: Post(s)
I never said anything about it being 20V out of the rectifier did I? Oh maybe you meant because of the rating I chose for the IC voltage regulator. That has to be at least as high as the fullwave PP incase of reverse voltage breakdown of the diode occurs. Otherwise you are replacing the IC when you get voltage spikes on the input side of the rectifier.
post #45 of 47 (permalink) Old 09-17-2008, 01:23 PM
slybydesign's Avatar
Date registered: Jan 2007
Vehicle: My Two Left Feet
Drew and Heddi ya'll are pretty smart. I read your posts and such. Some times I wish I could hop in your conversation and add to it but all it ends up doing is making
3. Paul Hamm, Gymnast: I owe a lot to my parents, especially my mother and father.
slybydesign is offline
post #46 of 47 (permalink) Old 09-17-2008, 01:32 PM
Surely A Large Human
Qubes's Avatar
Date registered: Jun 2006
Vehicle: '08 C219
Quoted: 577 Post(s)
I hate voltage spikes on the input side of my rectifier. Try explaining those marks to your wife.
Qubes is online now
post #47 of 47 (permalink) Old 09-17-2008, 01:40 PM
    Can't figure this out..please HELP! TpaBenZo W124 E,CE,D,TD Class 6 06-28-2009 10:14 PM
    can you figure this one out??? eurosdpec W201 190-Class 10 02-06-2008 03:18 PM
    Help me figure this out please IN-FLT General Mercedes-Benz 5 12-21-2007 06:44 PM
    Can't Figure This Out...! TimsML430 W163 M-Class 4 10-16-2007 01:55 AM
    Figure this one out: Mattiesbenz W123 E,CE,D,CD,TD,TE Class 8 12-02-2005 05:08 AM
