Anyone running VMware? - Page 2 - Mercedes-Benz Forum
post #11 of 28 (permalink) Old 08-17-2008, 05:07 PM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 230 Post(s)
Originally Posted by drewprof View Post
Thanks, mine has only 2GB of RAM but will it hang in there until I get a chance to get some? Where in the hell do I insert the memory chips on this thing? It's one large 24" screen with USB ports in the back, that's it!
On an Intel Mac, the memory is installed at the bottom of your machine. You should see a little flip door that fastens with a small phillips screw. The older machines, you had to take the back off.
Also, OSX 10.5x comes with boot camp, so you shouldn't need virtualization software. Earlier versions had issues but it's been 'debugged'.
Here's a link to Apple's website about it:
Apple - Mac OS X Leopard - Features - Boot Camp
Congratulations on your purchase. You have been assimilated.
2005 S430 4Matic 'Morton' W220.183 • 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #12 of 28 (permalink) Old 08-17-2008, 05:08 PM
Surely A Large Human
Qubes's Avatar
Date registered: Jun 2006
Vehicle: '08 C219
Quoted: 640 Post(s)
It's really easy. Two screws on the underside of the monitor, right in the center. Spring loaded. Remove the cover, and you'll see little levers that will eject the memory, and seat the new ones. Takes five minutes, tops.
Qubes is offline
post #13 of 28 (permalink) Old 08-17-2008, 05:10 PM
Qubes's Avatar
Vehicle: '08 C219
Quoted: 640 Post(s)
Boot camp will only let you run Windows as a separate OS instance. Fusion gives you that way too cool "Unity" mode, where Windows apps and OS X apps run on the same desktop, seamlessly. Apple-Tab cycles through both OS'es apps, no goofy window to click in and out of, etc. Truly a thing of beauty.
Qubes is offline
post #14 of 28 (permalink) Old 08-17-2008, 05:18 PM
cmitch's Avatar
Quoted: 230 Post(s)
Also, remember to install memory in matched pairs. I believe your machine has 2 slots capable of holding a 2GB stick each. If you upgrade to 4, you'll have to buy a matching set of two 2GB sticks. Since your machine came with 1GB, you would need to see what brand it is and add the exact same kind to the other slot to upgrade to 2GB. If your machine came with 2 512MB sticks, you'll need to pull them out and install the 1GB pair.
cmitch is offline
post #15 of 28 (permalink) Old 08-17-2008, 05:20 PM
cmitch's Avatar
Quoted: 230 Post(s)
Macs are a thing of beauty.
cmitch is offline
post #16 of 28 (permalink) Old 08-18-2008, 05:22 AM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1123 Post(s)
I never in my life thought that I would leap into a Mac, it just sounded too geeky for me but boy was I wrong! Beauty is an understatement, I am friggin hooked.
DP is offline
post #17 of 28 (permalink) Old 08-18-2008, 05:45 AM
~BANNED~
Jakarta Expat's Avatar
Date registered: Aug 2006
Vehicle: PM me to Join the Expat Muslims for Obama Club........
Quoted: 4 Post(s)
Is the porn in 3D or what?
Jakarta Expat is offline
post #18 of 28 (permalink) Old 08-18-2008, 05:55 AM
FeelTheLove's Avatar
Date registered: Sep 2004
Vehicle: 83 Astral Silver 280 SL
Quoted: 8 Post(s)
Never use VMWare with my Mac, I just terminal-serve into serve someplace to run Windows, using TS Client for Mac, but we do use VM Ware extensively for virtual server work - great cost cutter.
Recall that earlier generations faced down fascism and communism not just with missiles and tanks, but with sturdy alliances and enduring convictions. They understood that our power alone cannot protect us, nor does it entitle us to do as we please. Instead, they knew that our power grows through its prudent use; our security emanates from the justness of our cause, the force of our example, the tempering qualities of humility and restraint.
-President Barack Obama, 1st Inaugural address
FeelTheLove is offline
post #19 of 28 (permalink) Old 08-18-2008, 08:15 AM Thread Starter
DP
DP's Avatar
Yep, I'm running Fusion 2 beta 2 (free download). It definitely works well at filling the gap left by Windows apps you need (like MS Project, Visio, etc). I'd get yourself some more memory. You can get a 4GB memory kit (2x2GB DIMMS) from NewEgg for around $150 or so. Well worth it.
this? VMware Fusion Overview, Run Windows on Mac, Virtual PC on Mac - VMware
DP is offline
post #20 of 28 (permalink) Old 08-18-2008, 08:17 AM
Qubes's Avatar
Vehicle: '08 C219
Quoted: 640 Post(s)
^ Yep, kinda.. Actually, this: VMware Fusion 2.0 Beta 2 - VMware
Qubes is offline
Libertarians lose another one: Running Bear, Running Bare mcbear Off-Topic 4 07-30-2008 06:33 AM
Car running finally is it running hot or O.K. cheapold280ce W123 E,CE,D,CD,TD,TE Class 15 04-23-2008 06:42 PM
Still Not Running Jayare W124 E,CE,D,TD Class 7 10-12-2007 06:21 AM
Running In Ray Symons W203 C-Class 1 09-12-2005 01:25 PM
Anyone running 33 x 10.5s? greenG G-Class 1 06-06-2004 07:37 AM
