Clutch for a Supra - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 08-06-2008, 05:09 PM Thread Starter
Date registered: Jun 2008
Vehicle: 240D, 300SD
Clutch for a Supra
I just wanted to know if there is any way to check if the clutch is starting to wear out? Do they start having symptoms before they go or do they just go? It is for a 3rd generation supra. Are there any checks with out removing the transmission? I had the motor replaced and I am getting ready to give it to a first time driver, also first time manual driver too at that. So I don't want the clutch to go out at a bad time. The guy putting the motor in said it has a lot left, but for a first time learner it is going to start to wear, so I wanted to be ready.
sdbahamut is offline
post #2 of 15 (permalink) Old 08-06-2008, 05:49 PM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1067 Post(s)
Put the car on a hill and try to see how your clutch engages as you try to go up from a stand still.
DP is offline
post #3 of 15 (permalink) Old 08-06-2008, 07:13 PM
Surely A Large Human
Qubes's Avatar
Date registered: Jun 2006
Vehicle: '08 C219
Quoted: 640 Post(s)
Put the clutch in, select 1st gear, and bring the RPM's up to redline or so. Hold it there about 10 minutes. If it starts to grab after a little bit, your clutch is okay....or, at least, it was.
Qubes is offline
post #4 of 15 (permalink) Old 08-06-2008, 07:15 PM
~BANNED~
Date registered: Sep 2004
Vehicle: 2002 clk320
Where is the clkman when you need him in a CLUTCH situation? Burpppppppppppp.
the clk man is offline
post #5 of 15 (permalink) Old 08-06-2008, 07:17 PM
Qubes's Avatar
Vehicle: '08 C219
Quoted: 640 Post(s)
I burped right when I read this.
By the way, I've had ringing in my phone ear ever since you ripped one earlier.
Qubes is offline
post #6 of 15 (permalink) Old 08-06-2008, 08:20 PM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 226 Post(s)
Posting a Toyota question in a Mercedes forum, off-topic no less? :flame:
2005 S430 4Matic 'Morton' W220.183 • 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #7 of 15 (permalink) Old 08-06-2008, 08:55 PM
Shane's Avatar
Vehicle: Taking my time on my ride
Quoted: 1795 Post(s)
You are worried about the clutch so you give it to a newbie? Am I missing something here? If the mech says it is ok then it probably is, he could make more money off of you if he sold you a new one.
Shane is offline
post #8 of 15 (permalink) Old 08-07-2008, 07:05 AM
FeelTheLove's Avatar
Vehicle: 83 Astral Silver 280 SL
Quoted: 8 Post(s)
Recall that earlier generations faced down fascism and communism not just with missiles and tanks, but with sturdy alliances and enduring convictions. They understood that our power alone cannot protect us, nor does it entitle us to do as we please. Instead, they knew that our power grows through its prudent use; our security emanates from the justness of our cause, the force of our example, the tempering qualities of humility and restraint.
-President Barack Obama, 1st Inaugural address
FeelTheLove is offline
post #9 of 15 (permalink) Old 08-07-2008, 07:15 AM
Membership withdrawn by request
Von Vorschlag's Avatar
Date registered: Apr 2006
Vehicle: A red Vimana
Quoted: 1122 Post(s)
No, your going to have to remove the trassmission and the engine and front seats and headlights also the rear wheels along with the gas tank and hand brake, good luck
Von Vorschlag is offline
post #10 of 15 (permalink) Old 08-14-2008, 07:07 PM Thread Starter
I know it was off topic, but I thought with a clutch there is probably many ways to check it with many different mechanics ideas, and I don't want to have to remember so many log in names for different forums. Shane I acually bought the car for my little brother. I have had one in the past and still have some parts for this year so I thought if anything I would know a little about it. He wanted a manual car so I helped him get one. As for the clutch the mechanic said it looked good. I did not tell him it was going to a newbie. Then I started to think and remembered it will burn up quick, so I wanted some steps to see when I need to replace it. I found my old Haynes manual and run the spin down test and one more, I think it will last a while. Thanks guys for the help
Replace clutch slave cylinder and bleed clutch jimmyl W123 E,CE,D,CD,TD,TE Class 7 12-17-2009 05:33 PM
any supra owners in here? tjobeid Off-Topic 27 07-04-2007 12:25 PM
OT!! Toyota Supra screaming....... 00 ML430 Bulldog W163 M-Class 0 03-12-2004 05:36 PM
Supra...... lok402 R170 SLK-Class 2 07-06-2003 04:18 AM
slk 32 V Supra Robbie R170 SLK-Class 20 06-15-2003 12:44 AM
