How to get more of your money's worth for every gallon - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 05-28-2008, 11:31 PM Thread Starter
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 1015 Post(s)
1-Only buy or fill up your car or truck in the early
morning when the
ground temperature is still cold. Remember that all
service stations
have their storage tanks buried below ground. The
colder the ground the more dense the gasoline, when it
gets warmer gasoline expands, so buying in the
afternoon or in the evening....your gallon is not
exactly a gallon. In the petroleum business, the
specific gravity and the
temperature of the gasoline, diesel and jet fuel,
ethanol and other petroleum products plays an
important role.
2-A 1-degree rise in temperature is a big deal for
this business. But
the service stations do not have temperature
compensation at the pumps.
3-When you're filling up do not squeeze the trigger of
the nozzle to a
fast mode. If you look you will see that the trigger
has three
(3)stages: low, middle, and high. In slow mode you
should be pumping on low speed, thereby minimizing the
vapors that are created while you are pumping. All
hoses at the pump have a vapor return. If you are
pumping on the fast rate, some other liquid that goes
to your tank becomes vapor.
Those vapors are being sucked up and back into the
underground storage tank so you're getting less worth
for your money.
4-One of the most important tips is to fill up when
your gas tank is
HALF FULL or HALF EMPTY. The reason for this is, the
more gas you have in your tank the less air occupying
its empty space. Gasoline evaporates faster than you
can imagine. Gasoline storage tanks have an internal
floating roof. This roof serves as zero clearance
between the gas and the atmosphere, so it minimizes
the evaporation. Unlike service stations, here where I
work, every truck that we load is temperature
compensated so that every gallon is actually the exact
amount.
5-Another reminder, if there is a gasoline truck
pumping into the
storage tanks when you stop to buy gas, DO NOT fill
up--most likely the gasoline is being stirred up as
the gas is being delivered, and you might pick up some
of the dirt that normally settles on the bottom. Hope
this will help you get the most value for your money.
DO SH ARE THESE TIPS WITH OTHERS!
WHERE TO BUY USA GAS, THIS IS VERY IMPORTANT TO KNOW.
READ ON
Gas rationing in the 80's worked even though we
grumbled about it.
It might even be good for us! The Saudis are
boycotting American goods. We should return the favor!
An interesting thought is to boycott their GAS.
Every time you fill up the car, you can avoid putting
more money
into the coffers of Saudi Arabia . Just buy from gas
companies that don't import their oil from the Saudis.
I thought it might be interesting for you to know
which oil
companies are the best to buy gas from.
These companies import Middle Eastern oil:
Shell........................... 205,742,000 barrels
Chevron/Texaco......... 144,332,000 barrels
Exxon /Mobil............... 130,082,000 barrels
Marathon/Speedway... 117,740,000 barrels
Amoco ............................62,231,000 barrels
Citgo gas is from South America
Here are some large companies that do not import
Middle Eastern oil:
Sunoco................0 barrels
Conoco................0 barrels
Sinclair.................0 barrels
B P/Phillips...........0 barrels
Hess.....................0 barrels
ARC0....................0 barrels
If you go to Sunoco. com, you will get a list of the
station
locations near you.
All of this information is available from the
Department of Energy
and each is required to state where they get their
oil and how much they are importing.
Teutone is offline
post #2 of 19 (permalink) Old 05-28-2008, 11:39 PM
mzsmbs's Avatar
Vehicle: 1972 Mercedes 250 (/8) W114/M130
cool. i bike most of the time.
in political asylum
mzsmbs is offline
post #3 of 19 (permalink) Old 05-29-2008, 12:01 AM
worst mod in BW history
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK Iridescent Hyundai Accent lol,GoPed Freightshaker & Volvo semi's, c'mawn?
Quoted: 4 Post(s)
Good tips.
I don't know if I mentioned this but several chains of truck stops have installed heaters on their tanks. It's easily spotted as truck diesel is normally green but when heated turns white. I would not be surprised to see this practice applied to gasoline in the near future,
ThrillKill is offline
post #4 of 19 (permalink) Old 05-29-2008, 12:09 AM
FeelTheLove's Avatar
Vehicle: 83 Astral Silver 280 SL
Quoted: 8 Post(s)
I now want $25,000 for my 83 280SL.
Recall that earlier generations faced down fascism and communism not just with missiles and tanks, but with sturdy alliances and enduring convictions. They understood that our power alone cannot protect us, nor does it entitle us to do as we please. Instead, they knew that our power grows through its prudent use; our security emanates from the justness of our cause, the force of our example, the tempering qualities of humility and restraint.
-President Barack Obama, 1st Inaugural address
FeelTheLove is offline
post #5 of 19 (permalink) Old 05-29-2008, 12:53 AM
ThrillKill's Avatar
Quoted: 4 Post(s)
For gas, or is that the selling price?
post #6 of 19 (permalink) Old 05-29-2008, 08:06 AM
chromejunkie's Avatar
Date registered: Dec 2007
Vehicle: bike cost too much to drive
2 gals.
living on the edge driving a fine line
chromejunkie is offline
post #7 of 19 (permalink) Old 05-29-2008, 09:03 AM
Smackrattle's Avatar
Date registered: Nov 2005
Quoted: 316 Post(s)
morning when the
service stations
important role.
this business. But
the nozzle to a
has three
for your money.
your gas tank is
amount.
pumping into the
READ ON
grumbled about it.
more money
which oil
Middle Eastern oil:
station
locations near you.
That's very interesting. Now I would like to see the math based on buying 10 gallons a week for a year with a tempetaure differential average of 15C.Ice used to be kept in underground wells from winter until summer, so I imagine underground tanks are quite well insulated by their surroundings.
How many CC's of gasoline do you estimate are converted to vapour while pumping 10 gals fast compared to slow?
If you always fill-up from a half empty tank to full, how much gas are you wasting by hauling around an extra half tank of gas the whole time?
Perhaps simply using your right foot more gently would yield better economy, without all the logistics?
"Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful" - Seneca
Smackrattle is online now
post #8 of 19 (permalink) Old 05-29-2008, 11:27 AM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1038 Post(s)
Most of that stuff are myths. I am however working an alternate water based fuel; be patient, I will update everyone once I crack the secret.
DP is offline
post #9 of 19 (permalink) Old 05-29-2008, 11:32 AM
Date registered: May 2008
Great Info Thanks
A4GR is offline
post #10 of 19 (permalink) Old 05-29-2008, 11:48 AM
MB-SV's Avatar
Date registered: Nov 2007
Quoted: 77 Post(s)
urban legend fun
S.
2013 Mercedes C250 Sport package PLUS steel gray metallic/black
2007 Lexus IS350 Sport package smoky granite mica/gray (+F-Sport, etc.)
2010 Honda Civic GX (CNG) white/tan
MB-SV is offline
    Miles Per Gallon Hi Fi W210 E-Class 40 04-03-2008 06:31 PM
    $3.90 a Gallon in CA Aouate R170 SLK-Class 35 04-02-2008 02:21 AM
    $4.04 @ gallon,who can beat me? Nutz 4 Benz Off-Topic 46 01-17-2008 08:57 PM
    30 Smiles per Gallon nobby R/C107 SL/SLC Class 23 06-25-2007 04:49 PM
    Miles per gallon bulletproof diesel W123 E,CE,D,CD,TD,TE Class 4 01-22-2005 06:21 PM
