Katrina disaster vis-a-vis the Chinese earthquake - Page 5 - Mercedes-Benz Forum
post #41 of 53 (permalink) Old 05-22-2008, 09:35 AM
Date registered: Sep 2004
Vehicle: 95 E300
Quoted: 392 Post(s)
Leaky New Orleans levee alarms experts
Posted by Cain Burdeau / AP May 21, 2008 9:48PM
By CAIN BURDEAU
The Associated Press
NEW ORLEANS (AP) -- Despite more than $22 million in repairs, a levee that broke with catastrophic effect during Hurricane Katrina is leaking again because of the mushy ground on which New Orleans was built, raising serious questions about the reliability of the city's flood defenses.
Outside engineering experts who have studied the project told The Associated Press that the type of seepage spotted at the 17th Street Canal in the Lakeview neighborhood afflicts other New Orleans levees, too, and could cause some of them to collapse during a storm.
The Army Corps of Engineers has spent about $4 billion so far of the $14 billion set aside by Congress to repair and upgrade the metropolitan area's hundreds of miles of levees by 2011. Some outside experts said the leak could mean that billions more will be needed and that some of the work already completed may need to be redone.
"It is all based on a 30-year-old defunct model of thinking, and it means that when they wake up to this one -- really -- our cost is going to increase significantly," said Bob Bea, a civil engineer at the University of California at Berkeley.
The Army Corps of Engineers disputed the experts' dire assessment. The agency said it is taking the risk of seepage into account and rebuilding the levees with an adequate margin of safety.
"It's always a potential, so it is a design component for every feature," said Walter Baumy, the chief corps engineer in New Orleans.
The 17th Street Canal floodwall collapsed on the day Katrina surged over New Orleans in August 2005, and the failure severely damaged Lakeview. It was one of the biggest of about 50 levee breaches that contributed to the deaths of about 1,300 people.
Fixing the 17th Street Canal has been one of the most expensive and laborious repair jobs since the storm and has served as something of a test case for scientists and engineers, who plan to apply the lessons learned there to the city's other levees.
Among other things, they repaired the wall by driving interlocking sheets of steel 60 feet into the ground, compared with about 17 feet before the storm. The sheet metal is supposed to prevent canal water from seeping under the levee through the wet, toothpaste-like soil that lies beneath the city, which was built on reclaimed swamp and filled-in marsh.
Over the past few months, however, the corps found evidence that canal water is seeping through the joints in the sheet metal and then rising to the surface on the other side of the levee, forming puddles and other wet spots.
Engineers said the boggy ground is a more serious problem than the corps realizes. Bea said there is a roughly 40 percent chance of the 17th Street Canal levee collapsing if water rises higher than 6 feet above sea level. During Katrina, the water reached 7 feet in the canal.
John Schmertmann, a retired University of Florida professor and a consultant on foundations, agreed with Bea that the corps "may still be embedding some of these not-properly-considered factors, so the new walls may not do what the corps expects."
Reducing such seepage might require the driving of sheet metal far deeper into the ground than is done now, or some other solution, said Bea, who was part of a team of experts sent by the National Science Foundation to do an independent study of the levee failures during Katrina.
Donald Jolissaint, chief of the corps' technical support branch in New Orleans, denied the problem at the 17th Street Canal is serious.
"I personally do not at all believe that this little wet spot is anything that is going to cause a breach or a failure of any kind," he said. A newly installed floodgate could be used to cut off the flow of water into the canal and reduce pressure on the levee, he said.
Nevertheless, the corps is concerned enough that for weeks, workers have been analyzing the wet spots and digging a 160-foot-long, 10-foot-deep trench to zero in on the source. "We're doing everything we can to chase this down," Jolissaint said.
The corps is also spending about $100 million by taking more than 2,000 soil borings to find out what is under the ground and determine the best design.
Timothy Kusky, a geologist with Saint Louis University and an expert on the Mississippi River, said engineering a safe levee system in New Orleans will be very difficult because of the soil.
"You've got old riverbeds and floodplain deposits all interlayered and distributed laterally in a very complex way, and then you build a levee across them," Kusky said.
As a result, a levee sinks at different rates, and the sinking creates "little cracks in them that promote seepage, and also the old river channels and floodplain deposits have different potentials for underseepage," he said.
He said the corps understands a lot of the problems, but it takes a huge amount of data to map every weakness, and the agency does not have the manpower to see that every contractor is doing the job right.
Seepage was reported at the 17th Street Canal before Katrina. The corps denies that caused the collapse. Instead, the corps contends the floodwall flexed and finally cracked under the force of water piled against it by the storm.
The biggest problems we are facing right now have to do with George Bush trying to bring more and more power into the executive branch and not go through Congress at all and that’s what I intend to reverse.
~ Senator Barack H. Obama
Botnst is offline
post #42 of 53 (permalink) Old 05-22-2008, 09:46 AM Thread Starter
Difflock's Avatar
Date registered: Dec 2006
Vehicle: 1984 300GD "G" Wagen, and 1998 Steyr Puch 290GD "G" Van & a 1988 MB Trac 1000
Quoted: 178 Post(s)
Send a message via Yahoo to Difflock
Dopey,
there are none so blind as those that will not see
Actually I think your comment
"were entitled to expect"
says it all
ie wait with ones two arms the one length
and them blame "them" for not doing enough
to clean up that shite you had in the corner? / middle of the floor ?/ wherever was handy.
Price of eggs in Denmark ???
puzzled is all
Difflock is offline
post #43 of 53 (permalink) Old 05-22-2008, 09:50 AM
chromejunkie's Avatar
Date registered: Dec 2007
Vehicle: bike cost too much to drive
well the usa is at it again lets go and rush to fix everyone elses problems but not our own this country is getting more f@#$^& up by the day oil companys and bush will turn this counrty into a third world counrty before its all said and done . OUR GOVERNMENT BLOWS A FAT COCK .
living on the edge driving a fine line
chromejunkie is offline
post #44 of 53 (permalink) Old 05-22-2008, 09:54 AM
~BANNED~
Jakarta Expat's Avatar
Date registered: Aug 2006
Vehicle: PM me to Join the Expat Muslims for Obama Club........
Quoted: 4 Post(s)
You got pics of this...............
Jakarta Expat is offline
post #45 of 53 (permalink) Old 05-22-2008, 09:57 AM
I WILL FIND SOME
post #46 of 53 (permalink) Old 05-22-2008, 10:04 AM
~BANNED~
Quoted: 4 Post(s)
I WILL FIND SOME
Too bad Jay did not attend the BWOT blowout, you would already have them...............
post #47 of 53 (permalink) Old 05-22-2008, 10:07 AM
post #48 of 53 (permalink) Old 05-22-2008, 10:39 PM
dominic888's Avatar
Date registered: Feb 2006
Vehicle: 2002 ML 320
Originally Posted by Gregs300CD View Post
What I've heard (filtered through other's opinions) is that the government didn't want those people against the status quo to vote. Just irresponsibly repeating what I hear...
Like Chinese police donning saffron robes and starting riots.
But, I don't have access to truth. I don't get the Chinese government run news reports like you do.
I saw that picture floating around in the internet with the Chinese uniformed police wearing monk's robes. The police uniformed were green, the police had stop wearing those green uniforms for more than 4 or 5 years. From what I have read, those police were working as extras in a film back in 2000. For everybody who do not know, a Tibetan can spot a Han or Hui or a Qiang or a Mongolian in a second and vice versa. Even a rioting mob can tell who is rioting with them so a pseudo non Tibetan monk would stick out
Dominic
dominic888 is offline
post #49 of 53 (permalink) Old 05-23-2008, 03:55 AM
Smackrattle's Avatar
Date registered: Nov 2005
Quoted: 364 Post(s)
Originally Posted by Difflock View Post
Dopey,
says it all
puzzled is all
I hate stereotypes, but you really are a thick Mick, aren't you?
"Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful" - Seneca
Smackrattle is online now
post #50 of 53 (permalink) Old 05-23-2008, 06:43 AM Thread Starter
Difflock's Avatar
Quoted: 178 Post(s)
Dopey
Sorry buddy
wrong on both counts
(i) I am NOT a "Mick" nor indeed, do I consider myself Irish.
(ii) I have not ever sat a Sat test or an IQ test so I have no evidential proof
of my level of intelligence,
but
( a ) I consider myself reasonably intelligent, and my achievments in life would reasonably reflect a modicum of intelligence.
( b ) The missus is very? intelligent awarded "duex"? for maths in a good private school, and choose to marry me.
This decision was NOT influenced by the size of my penis or sexual performance.
and
(c) we have two intelligent children who passed the 11 plus selection examination WITHOUT CRAMMING. Which is virtually unheard of in our circles. Nor did we ever get involved with any of their homework or revision.
So ya boo sucks to you.
Now if you would care to explain about the price of eggs in Denmark?
Cheers
M
Difflock is offline
    FS: Vis Racing Carbon Fiber hood for W208 Rickchise23 C208/A208 CLK-Class 10 01-22-2008 02:42 PM
    Looking at a C240 wagon: what's the forum's general opinion vis a vis the competition? Murray von Kanada W203 C-Class 2 11-26-2003 04:13 AM
