Oil Pressure(automobile content warning) - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 04-02-2008, 09:45 AM Thread Starter
iNeon's Avatar
Date registered: Jan 2005
Vehicle: 2008 PT, 1998 neon--1965 VW 1200
Send a message via AIM to iNeon Send a message via MSN to iNeon Send a message via Yahoo to iNeon
So, I've got this beater 1984 245 gas-powered volvo wagon to drive the few weeks my car is in the shop for a head rebuild, and I'm curious as to what 'normal' oil pressure is?
On the 240D, the gauge swung wildly-- in-line with engine speed-- and it would sit a tick above or below 15psi at warm idle, peg at the top with any increase in engine speed.
This car hot idles at about the same oil pressure(checked by the 1984 dash gauge-- above the red mark, about 1bar) but in OD on the highway, it'll sit at 2-3bar, and the oilcan light flickers. I'm thinking that pressures between 15-60psi for an old car with 229k miles is great, and that it's just a bit of broken insulation making the light flicker, but wanted to ask youall what you thought.
I'm drive it anyway, so we'll see eventually... it'd just be nice to drive the car to the junker under it's own power when I'm done using it!
This signature removed to protect the innocent.
iNeon is offline
post #2 of 15 (permalink) Old 04-02-2008, 12:30 PM
mcbear's Avatar
Date registered: Apr 2004
Vehicle: E500Es
As long as you check the oil and it is full at the dipstick I would assume you have a sending unit that is going blinkie. With 200K+ it could be the sending unit, the wiring harness to the sending unit or the oil pump but unless you hear valves making a racket after the car has warmed up [more a sign of oil pump], you should be good.
McBear,
Kentucky
Being smart is knowing the difference, in a sticky situation between a well delivered anecdote and a well delivered antidote - bear.
mcbear is offline
post #3 of 15 (permalink) Old 04-02-2008, 03:22 PM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
There might be more/better feedback on the General MB forum here...
Don't believe everything you think
Jayhawk is offline
post #4 of 15 (permalink) Old 04-02-2008, 03:30 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1541 Post(s)
McB's suggestions are all spot-on, but I think that era Volvo uses solid lifters (w/adjustment shims), so the valves won't give you any audible indication that oil pressure has been diminished.
Zeitgeist is offline
post #5 of 15 (permalink) Old 04-02-2008, 03:57 PM
Date registered: Nov 2005
Vehicle: 1996 210.020
You may have two sending units, one for the gauge and one for the lamp. If this is the case, I would check the lamp sender for leaking oil. They often leak oil (and show low pressure) when they go bad.
Matt L is offline
post #6 of 15 (permalink) Old 04-02-2008, 09:52 PM Thread Starter
iNeon's Avatar
Hey, thanks ya'll!
It's got to be the sender, i've now driven it 300 miles(on $35.00- not bad!) and it'd have made some noise or indication something were wrong by now. The gauge is more accurate than the lightbulb, always. It cold idles at 4bar, warm idles(and when coasting with the clutch in) at 1bar-- logic tells me that's fine.
Now, how big can the tires be? I wanna get it muddy this summer. Alabama mud will re-dye the carpets their original color=)
iNeon is offline
post #7 of 15 (permalink) Old 04-02-2008, 10:54 PM
Vehicle: 2014 E250 Bluetec 4-Matic, 1983 240D 4-Speed
Quoted: 256 Post(s)
Sounds like you are over the suspicion of something bad going on. But, if you are still uneasy, put a hand held gauge in the sensor location. Not sure if Autozone will lend you a tool like that. My son borrowed the high school's auto shop set up for his car. Turned out it was a huge mess on his car and he virtually rebuilt the engine - the sensor sender was reading correctly. But the hand held item answered the question. Jim
JimSmith is offline
post #8 of 15 (permalink) Old 04-03-2008, 04:53 AM
Forum Administrator RC Colas® & Moon Pies®
Digmenow's Avatar
Date registered: Oct 2006
Vehicle: 1981 380SL 151K: 2001 E320 4Matic Estate 147K: 2008 E350 Sport 4Matic 120K: 2005 S500 116K
Quoted: 1439 Post(s)
Originally Posted by JimSmith View Post
Turned out it was a huge mess on his car and he virtually rebuilt the engine - Jim
Do you have a link for downloading that virtual engine rebuilder? Sounds like fun.
Quis custodiet ipsos custodes?
Digmenow is online now
post #9 of 15 (permalink) Old 04-03-2008, 07:58 AM
Quoted: 256 Post(s)
"Virtually rebuilt the engine" was intended to mean he rebuilt the head, changed the connecting rod bearings, a bunch of camshaft drive chain parts, the oil pump and a few other miscellaneous parts using the virtual experience he gained from connecting with a guy in Sweden who knows his car inside and out. Here is a thread from last summer on the subject:
1986 190E 2.3-16 Chain Guide Rail Replacement - ShopForum
Jim
JimSmith is offline
post #10 of 15 (permalink) Old 04-03-2008, 08:42 AM Thread Starter
iNeon's Avatar
it's just a beater, nothing to worry about beyond that it continues beating about for a month more. I'll post up a YouTube or something if ya want to see. It's an adventure every time you drive somewhere, and it's a sweet, sweet victory when you reach that destination!
To the untrained eye, these things look like a w123... To someone that's owned a w123... They're execrable. Dreadful little loose-trim trucklike thing with low-rent plastics, vinyls and the cheapest carpets this side of OE 1973 VW felt.
Mechanically, it's a marvelously reliable thing, and it's got to be getting over 24mpg. The overdrive setup on the 4-Speed manual is crazy, and I don't ever care to learn how that electronic thing works, but it's a marvel just the same. That there's a house-type light switch wired to the transmission to turn on and off the overdrive button on the gearshift only strengthens my resolve to never look under this thing besides to pour something in it.
I want another Benz. Can a w203 beater be as reliable/efficient as this 240DL beater? It's got to be getting 25+mpg-- 10 dollars 2 days ago, and I've driven over 100 miles on it. Some has to be residual, but the needle was in the orange when I put the 10 in. Way better than an automatic.
BORK BORK BORK
iNeon is offline
    HELP oil pressure warning light illuminated?!?! S320_on_18s W140 S-Class 13 01-10-2008 11:00 PM
    Valentine's message - WARNING EXPLICIT CONTENT 190Evoluzione Off-Topic 2 02-09-2007 09:24 AM
    Gas/ Oil Pressure Gauge, Warning Lights, Cruise Control Dead rocketfu W201 190-Class 2 10-08-2006 02:43 PM
    Bad Ass Automobile Photos (56k warning) Nutz 4 Benz Off-Topic 22 03-24-2006 01:11 AM
    Oil Temp? Pressure? High Warning J-Atlanta R170 SLK-Class 2 04-25-2001 05:24 AM
