Computer Wiz needed - Page 5 - Mercedes-Benz Forum
post #41 of 91 (permalink) Old 02-19-2008, 06:37 PM Thread Starter
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
Quoted: 2 Post(s)
Yes, the monitor is hooked up.
When I turn the computer on the monitor light goes green then orange
No beeps heard
Yes, i heard the fan going
If I press one of the buttons on the monitor it will say, "computer is in power save mode press any key or move mouse to exit"
The lights are inbetween the 2 USB ports and the earphones plug. Thanks for the help
'79 280CE with 226,000 miles
'76 240D 4 speed with 190,000
'85 300D Turbo with 266,000 miles
GONE but not forgotten
'76 300D with 195,300 miles
"83 300D with 174,000 miles
79Mercy is offline
post #42 of 91 (permalink) Old 02-19-2008, 06:39 PM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1120 Post(s)
Did you get a memory checksum message at all or was the screen blank.?
DP is offline
post #43 of 91 (permalink) Old 02-19-2008, 06:45 PM
pumpkin's Avatar
Date registered: Feb 2008
Vehicle: 1996 c220
sounds to me like you have hardware failure, does it go to windows?
now if you can get to windows in safe mode you can try a system restore this will be a date you can pick to an earlier date when it was working good.
youll need to go start programs systems and click system restore pick an earlier date when was working.
then it will restart and should be good
if not sound like you have lost some data or its conflicting so you can also do this.
go to control panel click device manager click display if it shows working ok then its another one try mouse and keyboard too see if all are ok.
if none of this work you can try reinstalling the version on windows your using xp or vista
this will fix the damaged software issues
pumpkin is offline
post #44 of 91 (permalink) Old 02-19-2008, 06:45 PM
Surely A Large Human
Qubes's Avatar
Date registered: Jun 2006
Vehicle: '08 C219
Quoted: 640 Post(s)
^ Re-read the thread, kthxbai.
Qubes is offline
post #45 of 91 (permalink) Old 02-19-2008, 06:54 PM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 228 Post(s)
How's this for a whiz?
2005 S430 4Matic 'Morton' W220.183 • 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #46 of 91 (permalink) Old 02-19-2008, 07:00 PM Thread Starter
79Mercy's Avatar
Vehicle: 1979 280CE
Quoted: 2 Post(s)
When I turn the computer on it does absoultly nothing. I have to press the menu button on the monitor to even get the power saver message.
I got no messages at all just the "windows has shut down to prevent damage to your computer" on the big blue screen this afternoon when I moved the mouse.
I can't get to the windows screen, I can't get to anything at all.
79Mercy is offline
post #47 of 91 (permalink) Old 02-19-2008, 07:02 PM
DP
DP's Avatar
Do you know how to swap hardrives? Like take the one you have on this faulty computer and put it in the other one you mentioned that you have? or make it a slave drive?
DP is offline
post #48 of 91 (permalink) Old 02-19-2008, 07:12 PM Thread Starter
79Mercy's Avatar
Vehicle: 1979 280CE
Quoted: 2 Post(s)
No, I don't know how to do that. It seems this isn't a easy fix so I'll just take it to a shop tomorrow morning. Thanks for your help. I'll let you know what the shop says.
79Mercy is offline
post #49 of 91 (permalink) Old 02-19-2008, 07:14 PM
Qubes's Avatar
Vehicle: '08 C219
Quoted: 640 Post(s)
$5 says they tell you to buy a Mac.
Qubes is offline
post #50 of 91 (permalink) Old 02-19-2008, 07:14 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 749 Post(s)
Good idea. If your Boot CD spun up but wouldn't load, you have a hardware problem that you won't be able to deal with tonight.
GeeS is offline
Clk 2003 Computer Reset! Help Needed! Median C209/A209 CLK-Class 6 02-02-2008 01:54 PM
Is this Wiz or something else? zoso W140 S-Class 0 12-30-2006 08:15 AM
E 280 computer/brain needed funinthesun Audio & Telematics Forum 1 07-23-2005 11:46 AM
560SEL rare onboard computer info needed mutley666 W126 S,SE,SEC,SEL,SD,SDL Class 2 07-16-2005 11:03 AM
Wiz! NewBeast W211 E55 AMG, E63 AMG 7 06-09-2004 08:09 AM
