Fun facts - Mercedes-Benz Forum
post #1 of 20 (permalink) Old 02-19-2008, 03:51 PM Thread Starter
Moderately subtle
edfreeman's Avatar
Date registered: Dec 2003
Vehicle: 94 E500, 97 500SL
Quoted: 112 Post(s)
Send a message via AIM to edfreeman
Fun facts
Peel a banana from the bottom and you won't have to pick the little 'stringy things' off of it. That's how the primates do it.
Take your bananas apart when you get home from the store. If you leave them connected at the stem, they ripen faster.
Store your opened chunks of cheese in aluminum foil. It will stay fresh much longer and not mold!
Peppers with 3 bumps on the bottom are sweeter and better for eating. Peppers with 4 bumps on the bottom are firmer and better for cooking.
Add a teaspoon of water when frying ground beef. It will help pull the grease away from the meat while cooking.
To really make scrambled eggs or omelets rich, add a couple of spoonfuls of sour cream, cream cheese, or heavy cream in and then beat them up.
For a cool brownie treat, make brownies as directed. Melt Andes mints in double broiler and pour over warm brownies. Let set for a wonderful minty frosting.
Add garlic immediately to a recipe if you want a light taste of garlic; and at the end of the recipe, if your want a stronger taste of garlic.
Leftover snickers bars from Halloween make a delicious dessert. Simple chop them up with the food chopper. Peel, core and slice a few apples. Place them in a baking dish and sprinkle the chopped candy bars over the apples. Bake at 350 for 15 minutes!!! Serve alone or with vanilla ice cream.
1. Reheat Pizza Heat up leftover pizza in a nonstick skillet on top of the stove, set heat to med-low and heat till warm. This keeps the crust crispy. No soggy micro pizza. I saw this on the cooking channel and it really works.
2. Easy Deviled Eggs Put cooked egg yolks in a zip lock bag. Seal, mash till they are all broken up. Add remainder of ingredients, reseal, keep mashing it up mixing thoroughly. Cut the tip of the baggy, squeeze mixture into egg. Just throw bag away when done easy clean up.
3. Expanding Frosting -- When you buy a container of cake frosting from the store, whip it with your mixer for a few minutes. You can double it in size. You get to frost more cake/cupcakes with the same amount. You also eat less sugar and calories per serving.
4. Reheating Refrigerated Bread -- To warm biscuits, pancakes, or muffins that were refrigerated, place them in a microwave with a cup of water. The increased moisture will keep the food moist and help it reheat faster.
5. Newspaper Weeds Away -- Start putting in your plants, work the nutrients in your soil. Wet newspapers, put layers around the plants overlapping as you go cover with mulch and forget about weeds. Weeds will get through some gardening plastic they will not get through wet newspapers.
6. Broken Glass -- Use a wet cotton ball or Q-tip to pick up the small shards of glass you can't see easily.
7. No More Mosquitoes -- Place a dryer sheet in your pocket. It will keep the mosquitoes away.
8. Squirrel Away! To keep squirrels from eating your plants sprinkle your plants with cayenne pepper. The cayenne pepper doesn't hurt the plant and the squirrels won't come near it.
9. Flexible vacuum -- To get something out of a heat register or under the fridge, add an empty paper towel roll or empty gift wrap roll to your vacuum. It can be bent or flattened to get in narrow openings.
10. Reducing Static Cling -- Pin a small safety pin to the seam of your slip and you will not have a clingy skirt or dress. Same thing works with slacks that cling when wearing panty hose. Place pin in seam of slacks and -- ta da! -- static is gone.
11. Measuring Cups -- Before you pour sticky substances into a measuring cup, fill with hot water. Dump out the hot water, but don't dry cup. Next, add your ingredient, such as peanut butter, and watch how easily it comes right out.
12. Foggy Windshield? -- Hate foggy windshields? Buy a chalkboard eraser and keep it in the glove box of your car. When the windows fog, rub with the eraser! Works better than a cloth!
13 Reopening Envelope -- If you seal an envelope and then realize you forgot to include something inside , just place your sealed envelope in the freezer for an hour or two. Voila! It unseals easily.
14. Conditioner -- Use your hair conditioner to shave your legs. It's a lot cheaper than shaving cream and leaves your legs really smooth. It's also a great way to use up the conditioner you bought but didn't like when you tried it in your hair...
15. Goodbye Fruit Flies -- To get rid of pesky fruit flies, take a small glass fill it 1/2' with Apple Cider Vinegar and 2 drops of dish washing liquid, mix well. You will find those flies drawn to the cup and gone forever!
16. Get Rid of Ants -- Put small piles of cornmeal where you see ants. They eat it, take it 'home,' can't digest it so it kills them. It may take a week or so, especially if it rains, but it works & you don't have the worry about pets or small children being harmed!
17. INFO ABOUT CLOTHES DRYERS -- The heating unit went out on my dryer! The gentleman that fixes things around the house for us told us that he wanted to show us something and he went over to the dryer and pulled out the lint filter It was clean. (I always clean the lint from the filter after every load clothes.) He took the filter over to the sink, ran hot water over it. The lint filter is made of a mesh material - I'm sure you know what your dryer's lint filter looks like. Well,...the hot water just sat on top of the mesh! It didn't go through it at all! He told us that dryer sheets cause a film over that mesh that's what burns out the heating unit. You can't SEE the film, but it's there. It's what is in the dryer sheets to make your clothes soft and static free -- that nice fragrance too, you know how they can feel waxy when you take them out of the box, well t his stuff builds up on your clothes and on your lint screen. This is also what causes dryer units to catch fire & potentially burn your house down with it! He said the best way to keep your dryer working for a very long time (& to keep your electric bill lower) is to take that filter out & wash it with hot soapy water & an old toothbrush (or other brush) at least every six months. He said that makes the life of the dryer at least twice as long! How about that!?! Learn something new everyday! I certainly didn't know dryer sheets would do that. So, I thought I'd share! Note: I went to my dryer & tested my screen by running water on it. The water ran through a little bit but mostly collected all the water in the mesh screen. I washed it with warm soapy water & a nylon brush & I had it done in 30 seconds. Then when I rinsed it the water ran right Thru the screen! There wasn't any pudding at all! That repairman knew what he was talking about!
edfreeman is offline
post #2 of 20 (permalink) Old 02-19-2008, 03:54 PM
GMISBEST's Avatar
THE BEST CAR...
GMISBEST is offline
post #3 of 20 (permalink) Old 02-19-2008, 03:59 PM
worst mod in BW history
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK Iridescent Hyundai Accent lol,GoPed Freightshaker & Volvo semi's, c'mawn?
Quoted: 5 Post(s)
What the Heloise are you talking about?
ThrillKill is offline
post #4 of 20 (permalink) Old 02-19-2008, 04:19 PM
Will Moderate For Cigars
cmitch's Avatar
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 226 Post(s)
Originally Posted by GMISBEST View Post
THE BEST CAR...
Whar da hell didya come from and whar you bean?
2005 S430 4Matic 'Morton' W220.183 • 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #5 of 20 (permalink) Old 02-19-2008, 04:26 PM
Roch207's Avatar
Date registered: Jul 2004
Vehicle: 2005 E320 CDI, 1995 E300D, 2002 Avalanche
Thank you Martha.
Roch207 is offline
post #6 of 20 (permalink) Old 02-19-2008, 04:42 PM
Date registered: Sep 2004
Vehicle: 95 E300
Quoted: 392 Post(s)
Have you seen that photo shoot where Lindsey Lohan poses as Martha Stewart, posing as Marilyn Monroe?
The biggest problems we are facing right now have to do with George Bush trying to bring more and more power into the executive branch and not go through Congress at all and that’s what I intend to reverse.
~ Senator Barack H. Obama
Botnst is offline
post #7 of 20 (permalink) Old 02-19-2008, 04:46 PM
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 107.024 RIP
Quoted: 95 Post(s)
Tain't no one skeered 'o yer pepper dust 'round these parts....
isthisdave is offline
post #8 of 20 (permalink) Old 02-19-2008, 04:51 PM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1069 Post(s)
7 is interesting because I seem to attract mosquitoes like crazy. I will try it this summer
DP is offline
post #9 of 20 (permalink) Old 02-19-2008, 04:57 PM
Roch207's Avatar
No, but did you hear Corkscrew got banned from SLKWorld? It's true. I heard he also welched on a $3.00 water at a bar once.
Roch207 is offline
post #10 of 20 (permalink) Old 02-19-2008, 04:59 PM Thread Starter
Moderately subtle
edfreeman's Avatar
Quoted: 112 Post(s)
That water was $3.50 . . . no wonder he was banned.
Little known facts on Iran Teutone Off-Topic 55 01-24-2008 05:38 AM
Sex Facts! Jayhawk Off-Topic 2 09-09-2006 11:54 AM
Sex Facts ThrillKill Off-Topic 10 06-26-2006 03:49 PM
R171 - The facts! Torsten, MBSLK.de R171 SLK-Class 14 02-04-2004 02:05 PM
20"rims with Z-rated tires + 4" of fluffy snow = FUN FUN Chris Krikorian W163 M-Class 2 12-09-2001 08:12 PM
