sleet sucks - Page 2 - Mercedes-Benz Forum
post #11 of 27 (permalink) Old 01-31-2008, 10:33 PM
Surely A Large Human
Qubes's Avatar
Date registered: Jun 2006
Vehicle: '08 C219
Quoted: 564 Post(s)
^ Liebert humidification pots suck.
Qubes is offline
post #12 of 27 (permalink) Old 01-31-2008, 10:37 PM
mcbear's Avatar
Date registered: Apr 2004
Vehicle: E500Es
You know all of this is learned because when I was growing up my parents NEVER hired anyone to do anything so it was dad and me for everything. I have not hired any work done either [except when the building inspector required an electrician for that annoying 220 stuff].
McBear,
Kentucky
Being smart is knowing the difference, in a sticky situation between a well delivered anecdote and a well delivered antidote - bear.
mcbear is offline
post #13 of 27 (permalink) Old 01-31-2008, 10:41 PM
mcbear's Avatar
Vehicle: E500Es
I found that the Downey system is both cheaper and gets the smell of Computer Room Geek out of the room. Only when I have put in mini and mainframe boxes have I required full humidification systems - although they break more often than they work and someone STILL has to go out and buy Downey.
McBear,
Kentucky
mcbear is offline
post #14 of 27 (permalink) Old 01-31-2008, 10:43 PM
Date registered: Mar 2006
Vehicle: 1999 ML320
Quoted: 311 Post(s)
Originally Posted by mcbear View Post
Years of working in Computer environments that need to NOT have static electricity have taught me neat tricks.
I didn't see the edit. I would use boiling water on both the inside and outside of the pipes. Turn you water heater up to max to get the best heat but remember to turn it back down before showering. Once it is pliable it should loosen up unless someone put liquid nail on the threads. .
Will try that. Liquid wrench did not work earlier presumably not
for plastic. I really hope it wasn't glued in place.
mlfun is offline
post #15 of 27 (permalink) Old 01-31-2008, 10:46 PM
Vehicle: 1999 ML320
Quoted: 311 Post(s)
Originally Posted by MorganA View Post
Anyone else having a minor ice-storm?
No, but I might have an ice-stream.
mlfun is offline
post #16 of 27 (permalink) Old 02-01-2008, 03:24 AM
Date registered: Oct 2007
Vehicle: 2002 SLK 230 1986 560SL 2008 Honda CRV
if you have a heat gun or a hair dryer that should loosen the glue.
livefreeordie is offline
post #17 of 27 (permalink) Old 02-01-2008, 04:13 AM
Smackrattle's Avatar
Date registered: Nov 2005
Quoted: 323 Post(s)
Yes,use the hairdryer as suggested and put a strap wrench on the joint and keep the torque applied even if you think there is no movement.They tend to let go very slowly.
Smackrattle is online now
post #18 of 27 (permalink) Old 02-01-2008, 05:31 AM
yoseyman's Avatar
Vehicle: Baby
I hit "Black Ice" last night.
I was leaving a hip hop party and the fucker walked right out in front of me.
yoseyman is offline
post #19 of 27 (permalink) Old 02-01-2008, 05:53 AM
~BANNED~
Jakarta Expat's Avatar
Date registered: Aug 2006
Vehicle: PM me to Join the Expat Muslims for Obama Club........
Quoted: 4 Post(s)
Sleet? I got that here, sometimes there will be little build up of it in the bottom of the tray that catches ice in the freezer from the ice maker
Jakarta Expat is offline
post #20 of 27 (permalink) Old 02-01-2008, 12:27 PM
mcbear's Avatar
Vehicle: E500Es
So, Morgan, how did the test go? It was nice and clear at 7am this morning. Temp was above freezing and the roads were clear.
McBear,
Kentucky
mcbear is offline
    This really sucks... Ynot R171 SLK-Class 23 03-11-2006 09:14 AM
    W220 S Class Thru Rain/Sleet and Snow? Bee W220 S-Class 15 01-12-2006 08:19 PM
    This sucks. dsb R171 SLK-Class 14 08-14-2005 12:55 PM
    My ML sucks! S4toML W163 M-Class 6 04-13-2003 10:19 AM
    Dealer Sucks - Help!!!!! SI W163 M-Class 2 06-26-2002 05:43 AM
