Star Wars - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-18-2007, 05:58 AM Thread Starter
Date registered: Sep 2004
Vehicle: 95 E300
Quoted: 392 Post(s)
Star Wars
Jet From Supermassive Black Hole Seen Blasting Neighboring Galaxy
By Marc Kaufman
Washington Post Staff Writer
Tuesday, December 18, 2007; Page A03
A jet of highly charged radiation from a supermassive black hole at the center of a distant galaxy is blasting another galaxy nearby -- an act of galactic violence that astronomers said yesterday they have never seen before.
Using images from the orbiting Chandra X-Ray Observatory and other sources, scientists said the extremely intense jet from the larger galaxy can be seen shooting across 20,000 light-years of space and plowing into the outer gas and dust of the smaller one.
3C321 system
This composite image shows the jet from a black hole at the center of a galaxy striking the edge of another galaxy, the first time such an interaction has been found. X-rays from Chandra (colored purple), optical and ultraviolet (UV) data from Hubble (red and orange), and radio emission from the Very Large Array (VLA) and MERLIN (blue) show how the jet from the main galaxy on the lower left is striking its companion galaxy to the upper right. The jet impacts the companion galaxy at its edge and is then disrupted and deflected, much like how a stream of water from a hose will splay out after hitting a wall at an angle. (Chandra X-ray Center, Harvard-Smithsonian Center for Astrophysics)
The smaller galaxy is being transformed by the radiation and the jet is being bent before shooting millions of light-years farther in a new direction.
"What we've identified is an act of violence by a black hole, with an unfortunate nearby galaxy in the line of fire," said Dan Evans, the study leader at the Harvard-Smithsonian Center for Astrophysics in Cambridge. He said any planets orbiting the stars of the smaller galaxy would be dramatically affected, and any life forms would likely die as the jet's radiation transformed the planets' atmosphere.
Black holes are generally thought of as mysterious cosmic phenomena that swallow matter, but the supermassive ones that occur at the center of many -- possibly all -- galaxies also set loose tremendous bursts of energy as matter swirls around the disk of material that circles the black hole but does not make it in.
That energy, often in the form of highly charged gamma rays and X-rays, shoots out in powerful jets that can be millions of light-years long and 1,000 light-years wide.
Scientists are just beginning to understand these jets, which not only transform matter in their path but also help produce "stellar nurseries," where new stars are formed.
Evans's collaborator, Martin Hardcastle of the University of Hertfordshire in England, said the collision they have identified began no more than 1 million years ago and could continue for 10 million to 100 million more years. Hardcastle called the collision a great opportunity to learn more about the jets.
"We see jets all over the universe, but we're still struggling to understand some of their basic properties," he said. "This system . . . gives us a chance to learn how they're affected when they slam into something -- like a galaxy -- and what they do after that."
The two galaxies are more than 1.4 billion light-years away from the Milky Way galaxy (a light-year equals about 6 trillion miles). But they are close to each other in cosmic terms -- about as far as the distance from Earth to the center of the Milky Way. That the two appear to be moving toward a merger may have played a role in creating such a powerful jet from the larger galaxy's central black hole.
The researchers said that the collision would have no effect on Earth, but the process is one that could play out in our galaxy a billion years into the future.
The galaxy Andromeda is the closest to the Milky Way, and the two are gradually coming closer to each other. In time, astronomers say, the two will merge, and the process may cause the dormant central black holes in either the Milky Way or Andromeda to become active and begin sending out similarly powerful jets.
If a jet were to hit Earth, Evans said, it would destroy the ozone layer and collapse the magnetosphere that blankets the planet and protects it from harmful solar particles. Without the ozone layer and magnetosphere, he said, much of life on Earth would end.
"This jet could be causing all sorts of problems for the smaller galaxy it is pummeling," Evans said.
Neil deGrasse Tyson, an astrophysicist from the American Museum of Natural History in New York, said the discovery illustrates how researchers can now observe astronomical phenomena using many different tools and understand how they behave at many different points along the electromagnetic spectrum. Only when scientists measure a galaxy at all different wavelengths, he said, "can you really understand what's going on."
In making their discovery, the researchers used data from three orbiting instruments -- the Chandra X-ray Observatory, the Hubble Space Telescope and Spitzer Space Telescope -- as well as ground-based observatories including the Very Large Array telescope in New Mexico and Britain's Multi-Element Radio Linked Interferometer Network. The Astrophysical Journal will publish the results next year.
The biggest problems we are facing right now have to do with George Bush trying to bring more and more power into the executive branch and not go through Congress at all and that’s what I intend to reverse.
~ Senator Barack H. Obama
Botnst is offline
post #2 of 3 (permalink) Old 12-18-2007, 06:29 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
Passing gas is just never a good thing...
GeeS is offline
post #3 of 3 (permalink) Old 12-18-2007, 10:44 AM
Naomilla2.0's Avatar
Date registered: Nov 2003
Vehicle: 1988 560SEL sold:
Neil deGrasse Tyson:
I always think that with a name like that he would have achieved even greater success as a chef.
Met him in person around the time of the opening of the Rose Center for Earth and Space - very smart and articulate man.
Naomilla2.0 is offline
    For all the Star Wars fans DestroyerW140 Off-Topic 9 12-11-2006 07:28 PM
    Star Wars II gbvoigt R171 SLK-Class 4 10-05-2005 10:06 AM
    Just like Star Wars ... gbvoigt R171 SLK-Class 3 10-04-2005 07:43 PM
    STAR WARS: REVENGE OF THE SITH JamesDean Off-Topic 19 06-14-2005 04:06 AM
    for all you Star Wars fans amgbnz Off-Topic 4 02-16-2004 10:02 AM
