I smell bananas. - Page 3 - Mercedes-Benz Forum
post #21 of 28 (permalink) Old 08-22-2007, 09:24 AM
Roch207's Avatar
Date registered: Jul 2004
Vehicle: 2005 E320 CDI, 1995 E300D, 2002 Avalanche
Wonder how DR made out?
Roch207 is offline
post #22 of 28 (permalink) Old 08-22-2007, 09:30 AM
Designo_E320
Guest
Posts: n/a
Quoted: Post(s)
Originally Posted by deathrattle
But there aren't any here. Does that mean I've had a stroke?
How old are you and do you have hyperlipidemia, diabetes, and high blod pressure? If so then you need to go to your doctor especially if you feel dizzy and are not strong in some parts of your body.
post #23 of 28 (permalink) Old 08-22-2007, 10:58 PM Thread Starter
~BANNED~
deathrattle's Avatar
Date registered: Jan 2005
Vehicle: 1992 W126 300 SE
LOL, no my cholesterol levels are fine, my blood sugar level well regulated and my BP runs low, around 95/60. I have no idea where the smell came from, but it went away. I'm glad it was a fruity smell-I could think of many worse odours to have to endure.
deathrattle is offline
post #24 of 28 (permalink) Old 08-23-2007, 05:12 AM
Designo_E320
Guest
Posts: n/a
Quoted: Post(s)
Well, that great! Best of luck and hope you remain in good health. Anyways, I would definitely let the doctor know about this during the next regular check-up. Secondly, if this happens again, then PLEASE tear your self away from BWOT and go to the doctor and let him know. I wish you best of health.
post #25 of 28 (permalink) Old 08-23-2007, 06:27 AM
worst mod in BW history
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK Iridescent Hyundai Accent lol,GoPed Freightshaker & Volvo semi's, c'mawn?
Quoted: 4 Post(s)
Originally Posted by Von Vorschlag
Titre du document / Document title
Lateralization of brain activation to imagination and smell of odors using functional magnetic resonance imaging (fMRI): Left hemispheric localization of pleasant and right hemispheric localization of unpleasant odors
Auteur(s) / Author(s)
HENKIN Robert I. (1) ; LEVY Lucien M. (2) ;
Affiliation(s) du ou des auteurs / Author(s) Affiliation(s)
(1) The Taste and Smell Clinic, Washington, D.C., ETATS-UNIS
(2) Department of Radiology, Georgetown University Medical Center, Washington, D.C., ETATS-UNIS
Résumé / Abstract
Purpose: Our goal was to use functional MRI (fMRI) of brain to reveal activation in each cerebral hemisphere in response to imagination and smell of odors. Method: FMRI brain scans were obtained in 24 normal subjects using multislice fast low angle shot (FLASH) MRI in response to imagination of banana and peppermint odors and in response to smell of corresponding odors of amyl acetate and menthone, respectively, and of pyridine. Three coronal sections selected from anterior to posterior brain regions were used. Similar studies were obtained in two patients with hyposmia using FLASH MRI and in one patient with hyposmia using echo planar imaging (EPI) both before and after theophylline treatment that returned smell function to or toward normal in each patient and in two patients with birhinal phantosmia (persistent foul odor) and global phantogeusia (persistent foul taste) with FLASH and EPI fMRI before and after treatment with neuroleptic drugs that inhibited their phantosmia and phantogeusia. Activation images were derived using correlation analysis. Ratios of hemispheric areas of brain activation to total hemispheric brain areas were calculated for FLASH fMRI, and numerical counts of pixel clusters in each hemisphere were made for EPI studies. Total pixel cluster counts in localized regions of each hemispheric section were also obtained. Results: In normal subjects, activation generally occurred in left (L) > right (R) brain hemisphere in response to banana and peppermint odor imagination and to smell of corresponding odors of amyl acetate and menthone. Whereas there were no overall hemispheric differences for pyridine odor, activation in men was R > L hemisphere. Although absolute activation in both L and R hemispheres in response to banana odor imagination and amyl acetate smell was men > women, the ratio of L to R activation was women > men. In hyposmic patients studied by FLASH fMRI, activation to banana odor imagination and amyl acetate smell was L > R hemisphere both before and after theophylline treatment. In the hyposmic patient studied with EPI before theophylline treatment, activation to banana and peppermint odor imagination and to amyl acetate, menthone, and pyridine smell was R > L hemisphere; after theophylline treatment restored normal smell function, activation shifted completely with banana and peppermint odor imagination and amyl acetate and menthone smell to L > R hemisphere, consistent with responses in normal subjects. However, this shift also occurred for pyridine smell, which is opposite to responses in normal control subjects. In patients with phantosmia and phantogeusia, activation to phantosmia and phantogeusia before treatment was R > L hemisphere; after treatment inhibited phantosmia and phantogeusia, activation shifted with a slight L > R hemispheric lateralization. Localization of all lateralized responses indicated that anterior frontal and temporal cortices were brain regions most involved with imagination and smell of odors and with phantosmia and phantogeusia presence. Conclusion: Imagination and smell of odors perceived as pleasant generally activated the dominant or L > R brain hemisphere. Smell of odors perceived as unpleasant and unpleasant phantosmia and phantogeusia generally activated the contralateral or R > L brain hemisphere. I think you may have had what they call a flash back . Treatment should be refraining from putting mirco dots on you cornflakes
The only thing that lengthy Bot-like tome did for me is give me a taste for a Heineken.
ThrillKill is offline
post #26 of 28 (permalink) Old 08-23-2007, 07:44 AM
Membership withdrawn by request
Von Vorschlag's Avatar
Date registered: Apr 2006
Vehicle: A red Vimana
Quoted: 1122 Post(s)
mission successful
Von Vorschlag is offline
post #27 of 28 (permalink) Old 08-23-2007, 11:29 AM
Shane's Avatar
Vehicle: Taking my time on my ride
Quoted: 1792 Post(s)
Sniff Ass.
Shane is offline
post #28 of 28 (permalink) Old 08-23-2007, 11:53 AM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1575 Post(s)
Just thinking out loud, or is that on your to-do list?
Zeitgeist is offline
    It's a miracle, Gambian president claims cure for AIDS: green paste and bananas Jakarta Expat Off-Topic 1 02-21-2007 08:47 AM
    A/C smell dimitriss W164 M-Class 1 04-29-2006 06:07 AM
    different smell black benz W201 190-Class 2 06-05-2005 05:10 AM
    Smell black benz W201 190-Class 3 06-03-2005 11:20 PM
    Cherries & Bananas Guest (MBNZ) W202 C36 AMG, C43 AMG 0 05-16-2001 11:01 PM
