Anyone here done low-tech body repair? - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 07-25-2007, 06:36 AM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1066 Post(s)
There is no way you will be able to align that piece of crap. Visual inspection is not enough.
I am impressed, a Saab driver that gets dirty!
DP is offline
post #12 of 15 (permalink) Old 07-25-2007, 11:19 AM
mcbear's Avatar
Date registered: Apr 2004
Vehicle: E500Es
The trick is to get it as close as possible with visual measurements. Do an alignment and see where you are. THEN, take the car to a frame shop, have them rack it and they can reset within an hour. That way, you have minimal frame shop costs, if any.
McBear,
Kentucky
Being smart is knowing the difference, in a sticky situation between a well delivered anecdote and a well delivered antidote - bear.
mcbear is offline
post #13 of 15 (permalink) Old 07-25-2007, 11:47 AM
Punjabi's Avatar
Vehicle: Bandwidth
Adustable steel props (don't know what they are called in the US but we use them for supporting upper floors, etc. in a building when replacing beams and the like) are ideal for this kinda remedial work when used in the horizontal position. Decent timber packers at ends and your problem solved but ensure the other end of prop is supported/braced within the engine bay otherwise it will just push the car away! Your local hire shop should have some .......heh, heh.
Punjabi is offline
post #14 of 15 (permalink) Old 07-25-2007, 02:00 PM
Always Remembered RIP
cascade's Avatar
Date registered: Nov 2006
Vehicle: 1991 560SEC AMG
Location: Grass Valley, N. Calif. / Gardnerville, Nevada
Quoted: 17 Post(s)
Send a message via AIM to cascade
^^^^^^Oh that's rich, now you are an expert HEH HEH. We'll let you know when we need advice on the care and feeding of water buffalos. Stick around HEH HEH
Jim
<--- superschnelle 300 hp 10:1 ECE euro HV, Hochverdichtung = high compression (11/2011) ... Wie im Freien Fall. Nur horizontal.
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity." >'='<
cascade is offline
post #15 of 15 (permalink) Old 07-25-2007, 02:37 PM
Punjabi's Avatar
Vehicle: Bandwidth
heh, heh.....who's we? Momma n you? heh, heh......
Punjabi is offline
Low RPM miss REPAIR AlaRonnie R/C107 SL/SLC Class 2 07-20-2007 10:50 AM
need a good MB repair/service tech beabout W126 S,SE,SEC,SEL,SD,SDL Class 1 09-07-2005 11:17 AM
Tech question about engine repair today dealing with plug supressors Miked619 R170 SLK-Class 2 08-20-2004 10:21 AM
Fuel Level Sender Repair article up in G-tech section of ClubGwagen site Hipine G-Class 0 11-17-2002 07:02 PM
Lexus tech looks at next repair order............. Guest (MBNZ) W202 C36 AMG, C43 AMG 5 06-29-2001 02:23 PM
