wheel hubs - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 07-02-2007, 03:18 PM Thread Starter
crunk04gtp's Avatar
Date registered: Nov 2006
Vehicle: 2003 S500, 1983 300SD
wheel hubs
This isn't about my benzo but this forum is so much better than my grand prix forum (where I didn't get any help). Guys on that forum know a lot about modding L32s and L67s but aren't as on top of the repairs. On top of it all they're jerks. Thread jacking is a serious offense that will get you ostracized. At any rate, I've got a creaking noise coming from the front of my Grand Prix whenever the car pitches up, I take a hard turn or hit a pothole. It gets worse with a lot of city driving. The stealership told me it was the wheel hubs (which include bearings on this car) and wanted 950 bucks to fix it. Needless to say I opted for doing it myself. But it seems like a bad bearing would make a repetitive noise as opposed to what I've got going on. Any opinions? Also, someone was telling me that if I changed the wheel hubs myself I would need to have the rotors realigned. Is this the case and if so would it be safe to drive it a mile or so to the mechanic to get it done?
Bill
The Teutonic Plauge
2003 S500
69,000 miles
crunk04gtp is offline
post #2 of 8 (permalink) Old 07-02-2007, 03:36 PM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1052 Post(s)
On a Benz, replacing the wheel hub is easy but a creaking noise is most likley not a wheel hub no matter what car you drive.
I say check your suspension components including rubber pieces if your springs rest on one for example.
Why would a rotor need alignment? Typically when you slide a rotor over the hub it should fit and if held by screws (the case with the benz) then there is no balancing needed. Notice I used the word balancing because that's what a disk would need if any.
Maybe they meant wheel alignment? In that case you are better off taking it for a front alignment only if you mess with the suspension; replacing the bearings and hub should not effect alignment (again that's the case with a benz).
DP is offline
post #3 of 8 (permalink) Old 07-02-2007, 03:51 PM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 18 Post(s)
That's a front wheel drive no? I'd look at the CV joints,inner and outer plus the engine/transmission mounts and the rack.
Nutz 4 Benz is offline
post #4 of 8 (permalink) Old 07-02-2007, 03:58 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1611 Post(s)
Ball joints (notorious creakers)
Outer CV joints (serious culprits, if sharp turns precede the creaks)
Strut mount bearings (creakers and squeakers)
I highly doubt the hubs (wheel bearings) would creak
Zeitgeist is offline
post #5 of 8 (permalink) Old 07-02-2007, 04:32 PM
Shane's Avatar
Vehicle: Taking my time on my ride
Quoted: 1795 Post(s)
Raise the front of the car and move the struts at the top a little, then drive it again and see. Before this try silicone spray on top of the strut. IF all this fails replace struts. If you have a base suspension GM you are guaranteed the shocks and struts are pure shit.
Shane is offline
post #6 of 8 (permalink) Old 07-06-2007, 11:12 AM Thread Starter
crunk04gtp's Avatar
Thanks y'all.
Bill
The Teutonic Plauge
2003 S500
69,000 miles
post #7 of 8 (permalink) Old 07-06-2007, 01:37 PM
old300D's Avatar
Date registered: Jul 2003
Vehicle: '83 240D
I'm sure you are right, but every domestic FWD car I've been in has done this after a while. I think it's normal
OBK #35
old300D is offline
post #8 of 8 (permalink) Old 07-06-2007, 01:54 PM
DP
DP's Avatar
Yep, my wife's Voyager creaks in the front once the strut bolts get loose. I have to tighten them once every six months to have a civilized ride. The problem is that they are not accessible unless I remove the whole windshield wipper mechanism.
One day I will buy a new car if everything on it is accessible but then again that's never going to happen anyway
DP is offline
    709d Wheel Hubs Wanted lesbrook For Sale/Wanted/Trade/Giveaway 1 08-14-2008 02:17 PM
    Does anyone know the exact diameter of the Wheel hubs? Dave OH R170 SLK-Class 3 02-07-2006 10:40 AM
    rusted hubs bartlettplace The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 11-21-2005 07:37 PM
    star caps on wheel hubs stewedg R129 SL-Class 1 01-24-2005 10:58 AM
    Slootted nut tool for front axle wheel hubs petermerle G-Class 6 08-07-2003 03:28 PM
