C# Vs VB - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 06-13-2007, 04:35 AM
FeelTheLove's Avatar
Date registered: Sep 2004
Vehicle: 83 Astral Silver 280 SL
Quoted: 8 Post(s)
Originally Posted by drewprof
Wow that's excellent news about the reverse compiling. I am very good at modeling and have used VB6 professionally as well as C++ in a pure research environment so I understand when to use one versus the other. My problem was this C# since I did not peek into it to see what it is about and of course I have stopped programming right about the time the .net architecture came into the scene. Like GS said, burnout was a factor.
I was checking the web so I can compare the two of them and it seems like C# is not that hard to get up to speed but like FTL said if I am modeling business processes I might be better off with VB but I am not too sure if this VB.net is the same thing as VB6.
With time I will figure it out but I welcome your opinions to speed up my decision process, thanks.
VB.net is radically different from VBA or VB6. I had to take a couple of college courses to make the transition, the entire approach is different, and I would recommend taking at least the introductory. It is much, much tighter code than the old VB. It is an extremely layered approach, where one object is stacked on top of another to achieve data flow, extremely complex and non-intuitive at first but extremely powerful once one has the hang of it . It creates tons and tons of code for you as you declare and manipulate objects that you can then modify if you desire.
I have coded nothing in C#, but I work with those who do, and they are fanatics. It's basic syntax is typical C so the transition for C/C++ programmers is much easier than from VB6 to VB.net. It is web-focused C, essentially. In my industry it is being used for man-machine interface stuff, for example, say you had a production line producing chemicals in Houston and you wanted chemists in Chicago monitoring the various pressures and flows of your feedstocks, you would write a C# app that talked to the valves and then put the result into web pages that could be browsed at your lab in Chicago in real time over a web VPN. You could add alerts and graphics and all kinds of other neat stuff. Doing the same thing in VB.net would take forever. Conversely, say you were a bean counter's dweeb, and you needed to access a million records produced by this C# app, summarize them, slice and dice some stats, and come up with a report that presented production on this line as a cost component of the plant as a whole, you would be insane to do it in C# because the SQL server interface alone would take you a month. So now the engineering dept uses C#, and the accounting and MRP people use VB.net. But the new beauty of it is, when we are both finished the complementing apps, we can reverse compile into either language so we can now understand what each of us is doing.
Recall that earlier generations faced down fascism and communism not just with missiles and tanks, but with sturdy alliances and enduring convictions. They understood that our power alone cannot protect us, nor does it entitle us to do as we please. Instead, they knew that our power grows through its prudent use; our security emanates from the justness of our cause, the force of our example, the tempering qualities of humility and restraint.
-President Barack Obama, 1st Inaugural address
FeelTheLove is offline
post #12 of 16 (permalink) Old 06-13-2007, 05:11 AM
Forum Administrator RC Colas® & Moon Pies®
Digmenow's Avatar
Date registered: Oct 2006
Vehicle: 1981 380SL 151K: 2001 E320 4Matic Estate 147K: 2008 E350 Sport 4Matic 120K: 2005 S500 116K
Quoted: 1534 Post(s)
I don't know why but that made sense. Do you teach a night class at the local JuCo?
Quis custodiet ipsos custodes?
Digmenow is online now
post #13 of 16 (permalink) Old 06-13-2007, 05:16 AM
Quoted: 8 Post(s)
No, but I could if I wanted to. My plan is to get out of business at around 55 or so and then start a teaching career, which is really sort of a retirement program anyway.
post #14 of 16 (permalink) Old 06-13-2007, 06:06 AM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1052 Post(s)
I should have waited to teach at that age too because as much as I like teaching and the lifestyle I hate the pay. By the way FTL I hear that in the industry on average C# people get paid more than VB people is that true and why?
DP is offline
post #15 of 16 (permalink) Old 06-13-2007, 06:41 AM
Quoted: 8 Post(s)
Pay for programmers varies widely depending on their analytical abilities, no matter what the language - . But when comparing entry level salaries or comparing apples to apples coder jobs, C# pays higher due to simple market economics - C-type languages are harder to learn, and generally required a higher aptitude in mathematics, so there are less of them. C programmers are extremely useful to shop-floor industry, so there is great demand for them, and they are in great demand for the authoring of commercial-grade software, which if successful can generate profits for investors. VB.net programmers are more plentiful because the coursework is less demanding. Most of the jobs in VB in general are report writers and other lowlife code toads. Success in VB.net comes from acquiring expertise in a particular industry and then using VB.net to produce quick, reliable and useful information for big shot decision makers who need big questions answered in a hurry, and the ability to extend the app to use Office objects so that you can integrate your work with common desktop tools used by everyone. Some of those areas are extremely hot: Vb.net with Outlook/Exchange integration pays big bucks, as does VB.net w/ASP.net/ADO.net skills, which is where I do a lot of work. Excel integration can also be big bucks if one has deep accounting or financial skillls to go along with it.
post #16 of 16 (permalink) Old 06-13-2007, 06:48 AM Thread Starter
DP
DP's Avatar
I see, it's no different from the old days. I did VB5/6 with ADO and that was in demand back then.
DP is offline
