BMW Fuel Tank Suction - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-23-2007, 04:01 AM Thread Starter
faisal300ce's Avatar
Date registered: Feb 2006
Vehicle: 300CE-24
Send a message via Yahoo to faisal300ce
My friend has a BMW 740iL, he had a leak in his Fuel tank and got it replaced 3 months ago. There seems to be a leak in the fuel tank again and it appears that it is being caused by vacum being generated in the tank. The Tank sucks inwards (like a plastic bottle) and some how gets back to its original poistion. This breathing factor is causes the tank to contract and expand damaging the corners and finally causing small leaks in the walls.
Any idea what is causing it and how it can be resolved?
190E (1991)
300CE-24 (1991)
faisal300ce is offline
post #2 of 2 (permalink) Old 04-23-2007, 05:45 AM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon/'01 EV Weekender
Quoted: 1419 Post(s)
More than likely it's a non-functioning check-valve or clogged charcoal filter cannister in the tank ventilation system. In the short term, he might try leaving the fuel cap slightly loose, to avoid the collapse, but the engine may register this as a vacuum leak and idle a little rough.
Zeitgeist is offline
    Fuel tank on TE/TD NovaScotia300TD W123 E,CE,D,CD,TD,TE Class 4 09-21-2006 09:45 PM
    Fuel Tank 230GE_Freestyler G-Class 2 09-12-2006 12:24 PM
    Help Removing Fuel Tank Fuel Screen JohnMcConnell W123 E,CE,D,CD,TD,TE Class 24 09-08-2006 06:06 AM
    looking for a new fuel tank mr diesel W123 E,CE,D,CD,TD,TE Class 5 10-02-2005 04:02 PM
    Was something loose? I filled my gas tank, and my fuel meter never reset to the full tank reading.. AC_ML W163 M-Class 5 08-20-2004 07:12 AM
