Official Bi-Xenon Headlights using 14000K,15000K, 30000K Bulbs ? Pink or Purple Look - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 03-02-2007, 04:02 PM
dklein
Guest
Posts: n/a
Quoted: Post(s)
Originally Posted by Professor
I want a disco ball in my car
i had one on the tractor had to remove it the neighbors thought it was a UFO and kept shooting at it
post #12 of 15 (permalink) Old 03-02-2007, 06:05 PM
~BANNED~
Jakarta Expat's Avatar
Date registered: Aug 2006
Vehicle: PM me to Join the Expat Muslims for Obama Club........
Quoted: 4 Post(s)
Considering who is driving, there is already enough "Disco" in that car now.
Jakarta Expat is offline
post #13 of 15 (permalink) Old 03-02-2007, 06:51 PM
Naomilla2.0's Avatar
Date registered: Nov 2003
Vehicle: 1988 560SEL sold:
Originally Posted by max_benz
I like my car to stand out from everyone elses.
why? it's already got you driving in it right?
馬鹿は死ななきゃ治らない。
Naomilla2.0 is offline
post #14 of 15 (permalink) Old 03-02-2007, 07:37 PM
Date registered: Sep 2004
Vehicle: 2014 E250 Bluetec 4-Matic, 1983 240D 4-Speed
Quoted: 256 Post(s)
Xenon lamps do not "burn" at the temperature of their color rating. They are much like flourescent lamps, however they produce photons in the visible range instead of the UV or another range and then rely on a surface coating on the ID of the glass tube to convert the invisible photons to visible ones. Here is a description from Sylvania:
"Definition of HID
High intensity Discharge lighting is light from a plasma discharge rather than a filament. The system involves a ballast to start the light and certain gasses to create the light. Overall the system uses less energy than halogen lighting, while producing 3 times more light.
How HID lights work
High Intensity Discharge Lights do not have a filament. Instead light is created from an electrical discharge between two electrodes in a micro-environment of xenon gas and metal halide salts. The light is emitted by an electrically energized gas -- a plasma discharge-- formed and sustained between the two electrodes.
The distinctive blue-white light of HID lamps stimulates the reflective paints in road markers and signs creating a safer driving environment. Additionally, the increased light output is designed to illuminate a wider area in front of the vehicle, improving visibility and safety, without disturbing the vision of oncoming drivers.
XENARC® HID lamps have over three times the lumens per watt of traditional halogen light sources and are more efficient at converting electrical energy into light. They produce at least 70% more light than traditional lamps, and use less power while producing less heat. This gives designers new freedom to explore the frontiers of front end design. By creating more compact headlights to fit smaller spaces, better aerodynamics are possible."
Color temperature has nothing to do with the bulb temperature, or at least it shouldn't. For example, your computer screen has a white balance, or color temperature you can set, and it is similarly described in degrees Kelvin. This represents a theoretical black body temperature that would radiate the same distribution of colors. Reddish tones are "cooler" and bluish tones are "warmer" or "hotter." Check this page in Wikipedia:
http://en.wikipedia.org/wiki/Color_temperature
So, changing the color temperature is usually manipulated in a HID bulb by altering the constituents of the gas. Given they produce three times the number of visible photons with less actual power, I find it hard to believe they will subject the lamp socket to temperatures that exceed a typical tungsten filament "Halogen" bulb, like an H-4 or an H-7. But, it is all in the details, so I would go ask the manufacturer.
Do some research. The color of the light has quite a bit to do with how things are perceived by the human eye, and more bluish colors tend to fatigue the human eye. Probably not a good choice if you intend to drive long distances at night. Jim
JimSmith is offline
post #15 of 15 (permalink) Old 03-03-2007, 05:25 AM
dklein
Guest
Posts: n/a
Quoted: Post(s)
"Definition of HID
How HID lights work
Color temperature - Wikipedia, the free encyclopedia
good post jim
educational!! thanx
FS: W203 Bi-xenon Headlight original w/ Xenon Hi beam bulbs / ballast Elite W203 C-Class 5 10-31-2011 01:04 PM
Official Bi-Xenon Headlights using 14000K,15000K, 30000K Bulbs ? Pink or Purple Look max_benz W203 C-Class 5 03-05-2007 01:51 AM
Seeing Purple Pink S- Class! Gunndy General Mercedes-Benz 9 06-26-2006 09:33 PM
Do they make Xenon projector headlights for the 2000 ML- mine has aftermarket Xenon in the housing HACK THT W163 M-Class 7 03-25-2006 02:55 PM
Xenon bulbs for headlights hocky W202 C-Class 6 07-08-2003 07:10 PM
