Nice trick for matching job applicants to positions - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-23-2006, 11:13 PM Thread Starter
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Here's a simple test.
Put about 1000 bricks in some particular arrangement in a closed room that has a window.
Then send 2 or 3 candidates into the room and close the door. Leave them alone and come back after 6 hours.
Then analyze the situation:
1. If they are counting the bricks, put them in the accounting department.
2. If they are recounting them, put them in auditing.
3. If they have messed up the whole place with the bricks, put them in engineering.
4. If they are arranging the bricks in some strange order, put them in planning.
5. If they are throwing the bricks at each other, put them in operations.
6. If they are sleeping, put them in security.
7. If they have broken the bricks into pieces, put them in information technology.
8. If they are sitting idle, put them in human resources.
9. If they say they have tried different combinations, yet not a brick has been moved, put them in sales.
10. If they have already left for the day, put them in marketing.
11. If they are staring out of the window, put them in strategic planning.
12. If they are talking to each other, and not a single brick has been moved, congratulate them and put them in top management.
13. Finally, if they have surrounded themselves with bricks in such a way that they can neither be seen nor heard from, put them in Congress.
Check Codes is offline
    OT: What a nice detailing job can do to your car! arevee R170 SLK-Class 7 03-20-2006 07:59 AM
    nice paint job... OBX884 W126 S,SE,SEC,SEL,SD,SDL Class 2 03-03-2006 08:45 AM
    Nice LEGO (TM) Job... Check Codes Off-Topic 9 11-20-2005 04:33 PM
    Nice paint job thogaa Unimog 6 05-17-2005 11:32 AM
    Fuse positions E300D kggkgg W124 E,CE,D,TD Class 1 04-09-2004 06:22 PM
