Segway's Next Big Thing?!? - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 04-14-2006, 06:30 PM Thread Starter
firstmb's Avatar
Date registered: Jan 2005
Vehicle: 2006 ML350
Looks Interesting..!!
_______________________________________________
Like the mythical half-horse, half-man of Greek lore, Concept Centaur combines the best of several technologies to create an innovative whole. The result of exploration by Segway Inc.'s product development team, Concept Centaur will challenge the way you think about four-wheeled transportation.
From time to time Segway's product development team devotes days, or even weeks, to creating new product concepts with the goal of finding a prince among frogs. It's a product exploration process they call "frog kissing." During this time, engineers and designers are encouraged to use any available materials in a very short time frame to prove a concept will work.
Recently, the product development team demonstrated that Concept Centaur was a prince—a concept that passed this initial feasibility test, but is not yet ready to become a product. Concept Centaur demonstrates Segway's continued commitment to breakthrough innovation and the innumerable possibilities for the future of personal transportation.
Concept Centaur combines proprietary dynamic stabilization technology with advanced propulsion and suspension systems, and an intuitive user interface to create a unique four-wheel device that is easily controllable on two or four wheels. Its full suspension and aggressive rider positioning provide an exhilarating ride for one or two people while maintaining control over a variety of terrain. Its rugged performance, zero emissions, and quiet operation make it a good low-impact way to explore the world. Its power and versatility make it suitable for a variety of indoor and outdoor recreational and commercial applications.
Intuitive user controls:
Thumbs forward: The Centaur's forward and backward propulsion is easily controlled by pushing a thumb throttle located on the underside of the right-hand handlebar.
Pop a wheelie: The Centaur uses dynamic stabilization technology to limit and/or maintain the angle at which the rider experiences the device. What would normally be a dangerous maneuver on a motorcycle or ATV becomes safe and controlled on the Centaur. In addition, the rider can position his/her body in three different ways, which makes for a fun ride. This technology also allows for a high-performance design with a short, compact wheelbase - a combination that traditionally can be very difficult to control.
Lean forward, go forward: If you've haven't yet experienced the Segway HT, now is the time. If you have, you know what we mean by intuitive controls. Concept Centaur uses dynamic stabilization in a similar way. When on two wheels, the Centaur is controlled by how the rider shifts his or her weight. To go forward, lean forward. To go back, lean back.
Simultaneous mechanical and drive-by-wire steering:
Smart steering: The front two wheels turn left and right mechanically, which is made possible by an innovative linkage system designed by Segway engineers. The Centaur's advanced controls software also allows the rear wheels to turn at different rates in response to data received from the rider's steering direction. When on two wheels, steering is accomplished in the same manner, by turning the handlebar. Sensors in the vertical portion of the steering column monitor the rider's input and sends a signal to the controller boards, which then issue a command to drive either or both of the rear wheels. Turning rate is coordinated so that even with the wheels off the ground, Centaur follows the path defined by the front wheel angles. This allows smooth transitions between two-wheel and four-wheel operation.
Environmentally friendly:
No exhaust: Batteries power the Centaur, which means that there are no emissions during operation. In addition, the Centaur uses regenerative braking, which means the batteries are recharged during deceleration and hill descents.
Quiet: Electric motors and an innovative gearbox design result in a quiet ride.
Low-impact tires: The Centaur prototypes use the same non-marking silica-based tires as the Segway HTs'. These tires are smooth, which allows the rider to perform exciting maneuvers while having little impact on the terrain.
Distinctive design, elegant suspension:
A profile X-shape: The profile of the Centaur creates an "X." Right after the Centaur was crowned a prince by the engineers, they quickly pulled in Segway's industrial design team to integrate their vision into the product's form and function. What resulted is a concept with a sleek minimalist design that elegantly showcases the rider, leaving the simple mechanical elegance of the underlying design visible.
Three shocks: There are three shocks on the Centaur that absorb bumps and help the wheels maintain contact with the ground. There is one in each front "arm" and one in the rear.
Lightweight: Concept Centaur only weighs about 150 pounds and can be easily transported in the back of a large SUV or small pick-up truck. If developed, its light weight would allow for transport on the back of small cars through a hitch-mounted rack, similar to that used for carrying bicycles.
Thanks, D.
________________________________________________
2006 ML 350 - Black, Appearance Package, Navigation System, Entertainment Package, Sunroof Package, Heated Seats, IPod Integration
firstmb is offline
post #2 of 10 (permalink) Old 04-14-2006, 07:27 PM
Shane's Avatar
Vehicle: Taking my time on my ride
Quoted: 1795 Post(s)
RE: Segway's Next Big Thing?!?
How much?
Shane is offline
post #3 of 10 (permalink) Old 04-14-2006, 11:27 PM
Andrew2004az's Avatar
Date registered: Feb 2004
Vehicle: 02 ML 320
It would be nice if the segway cost 1/4 of what it did a lot more would be sold. Last time i checked they cost about $10,000 you could get a nice sports bike for that or even a decent used car.
Andrew2004az is offline
post #4 of 10 (permalink) Old 04-14-2006, 11:46 PM
~BANNED~
deathrattle's Avatar
Vehicle: 1992 W126 300 SE
Segway's "next big thing" is likely to be bankruptcy.[|)][:o)]
deathrattle is offline
post #5 of 10 (permalink) Old 04-15-2006, 02:39 PM
GMISBEST.
Guest
Posts: n/a
Quoted: Post(s)
Here is better
post #6 of 10 (permalink) Old 04-15-2006, 05:35 PM
asianml's Avatar
Date registered: Sep 2005
Looks interesting.
I remember seeing that Disney security, parking lot people used Segway's I think. And I remember an old guy spending 15 minutes taking a Segway out of his car just to spend less than 5 minutes to return an item at Best Buy.
2002 Mercedes-Benz ML320 (sold)
2011 Chrysler Town & Country
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5
asianml is offline
post #7 of 10 (permalink) Old 04-15-2006, 06:31 PM
Vehicle: 02 ML 320
asianml - 4/15/2006 8:35 PM
Looks interesting.
What really makes me mad is seeing the police around here on them along with the mail man and other government workers. Every time i see one driven by a government worker I say to my self great another waste of tax $$$.
post #8 of 10 (permalink) Old 04-17-2006, 12:01 PM
BackRoll23's Avatar
Date registered: Nov 2004
Vehicle: 99 E 320
Send a message via AIM to BackRoll23 Send a message via MSN to BackRoll23 Send a message via Yahoo to BackRoll23
Isn't that thing basically an ATV? No different than a quad, except with far less power and cleaner emissions.
BackRoll23 is offline
post #9 of 10 (permalink) Old 04-17-2006, 12:15 PM
BenzE500's Avatar
Vehicle: ABCLOSING
Ill wait for it to reach 1200. dollars
BenzE500 is offline
post #10 of 10 (permalink) Old 04-17-2006, 03:33 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
deathrattle - 4/14/2006 11:46 PM
LOL [:D][:D][:D]
Check Codes is offline
