dexcool? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 04-05-2006, 11:37 PM Thread Starter
mzsmbs's Avatar
Date registered: Sep 2004
Vehicle: 1972 Mercedes 250 (/8) W114/M130
dexcool?
good? bad? if you have any opinions or any knowledge on this product please share. i have heard mixed stories and am kind of wondering.
thanks
in political asylum
mzsmbs is offline
post #2 of 11 (permalink) Old 04-06-2006, 12:46 AM
snips's Avatar
Date registered: Apr 2005
Vehicle: B6
RE: dexcool?
If you're talking about the factory recommended coolant in GM vehicles, I think it works excellent. It has to be flushed eventually, but it keeps things running well.
Freude am fahren!
snips is offline
post #3 of 11 (permalink) Old 04-06-2006, 01:04 AM Thread Starter
mzsmbs's Avatar
RE: dexcool?
i wasn't going to use it in a GM car. possibly in my MB. just wondering like i said. i don't want to taint the thread with what i have heard just yet.
thank you.
in political asylum
mzsmbs is offline
post #4 of 11 (permalink) Old 04-06-2006, 01:50 AM
BenzE500's Avatar
Vehicle: ABCLOSING
RE: dexcool?
Got a guy and GM I will ask him.
BenzE500 is offline
post #5 of 11 (permalink) Old 04-06-2006, 06:57 AM
Will Moderate For Cigars
cmitch's Avatar
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 207 Post(s)
RE: dexcool?
DON"T DO IT. If your head and intake gaskets are not made to withstand the dexcool, they will deterioate and cause MAJOR problems. Ask any GM 3100 V-6 owner.
BTW, get air in the system, you have JELLY!
cmitch is offline
post #6 of 11 (permalink) Old 04-06-2006, 09:39 AM
Date registered: Jul 2005
RE: dexcool?
Dexcool isn't that bad, but I don't see its advantages. The issues with dexcool sludging up have to do with people mixing it with green stuff (topping it off with coolant other than dexcool) and using those tablets. They recommend to use some sort of a coolant tablet that is supposed to do something good but what it does is muck things up, plugging heater cores and stuff. I think most dexcool horror stories are due to the above two things. HTH
wannasl is offline
post #7 of 11 (permalink) Old 04-06-2006, 09:55 PM
Date registered: Jun 2005
Vehicle: 2005 E320 cdi
RE: dexcool?
Mixing is a bad idea due to the gelling. I really can't see how dexcool is going to affect a head gasket or intake gasket. The GM intake manifold problem is not unique to GM. Certain ford 4.6's in pre 1998 crown victorias-not the trucks, GM 4.3 v6, 3.4 v6 and neons with 2. whatever have plastic intake manifolds which tend to crack and make a mess and expensive repair. I've had it happen several times on different vehicles-some with green and some with dexcool. It's the POS plastic manifold-not the coolant that causes the problem. I've been told that the VW coolant is really dexcool and have mixed with no bad results in 50k miles. If vw uses it maybe benz does to!
junkman is offline
post #8 of 11 (permalink) Old 04-06-2006, 09:59 PM
rcltrh's Avatar
Date registered: Nov 2005
Vehicle: '01 ML-430/'96 C220/'05 Lexus RX330
RE: dexcool?
Just go to NAPA and get some Xerex G05, which is the same formula as MB coolant and is approved for MB vehicles. Doesn't cost much more than Dexcool or any other long life and you don't have to worry about it doing anything weird to your cooling system. Even the same piss yellow color of MB coolant.
'96 C220
'01 ML-430
'05 Lexus RX-330
rcltrh is offline
post #9 of 11 (permalink) Old 04-06-2006, 10:19 PM Thread Starter
mzsmbs's Avatar
RE: dexcool?
thanks guys. i already have the darn thing. i'll probably use it and see what happens.
in political asylum
mzsmbs is offline
post #10 of 11 (permalink) Old 04-06-2006, 10:31 PM
Syracuse315's Avatar
Date registered: Jan 2005
Vehicle: '86 190E 2.3L
RE: dexcool?
mzsmbs - 4/7/2006 12:19 AM
gulp
If it jams, force it. If it breaks, it needed replacing anyway.
1986 190E 2.3L 135,000mi
Syracuse315 is offline
