How It Works: The $150,000 Watch - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-13-2006, 06:40 PM Thread Starter
firstmb's Avatar
Date registered: Jan 2005
Vehicle: 2006 ML350
Porsche’s latest chronograph is the first watch with a digital display that’s driven by springs and gears. Here’s a look at a few of its 800 parts
TIMEKEEPING
The Porsche’s timekeeping mechanism is similar to other mechanical watches but is very accurate and durable, thanks to its precise design and assembly. The slow release of tension from a wound mainspring supplies the watch’s power. As the mainspring uncoils, gears transfer its energy to a balance wheel, which converts the energy to measured beats by rotating back and forth at a set rate (28,800 times an hour, or four times a second) like a small pendulum. This moves the escape wheel, the first of a number of gears that reduce those beats to one per second. These drive the second hand, which triggers the minute and hour hands.
WINDING
A freely spinning rotor weighted on one side with palladium-gold alloy moves in circles around the case as the wearer swings his arm. That circular motion winds the watch’s springs through a series of gears.
CHRONOGRAPH
A chronograph is like a stopwatch—it tracks elapsed time up to 10 hours. The Porsche is the first mechanical watch with a digital display: numbered dials instead of hands to show hours, minutes and seconds passed. A separate spring drives each dial, and each full rotation of the chronograph’s second hand lifts a lever and releases the minutes disc to advance one number almost instantly. That resets the lever for another circuit. Each full rotation of the minutes disc operates a similar lever under the 10-minutes disc, which in turn advances the hours disc.
POWER RESERVE
The power-reserve indicator shows you how long the watch will run without additional winding. Typically, a gear connected to the mainspring turns a gauge as the spring wears down. But the Porsche has three additional springs for the chronograph. When the chronograph is on, the spring turning the minutes disc (which makes 600 rotations in 10 hours) will run out before the timekeeping spring does. So the watch automatically switches to monitoring the chronograph while it is running—a first in watchmaking.
WHY IS IT $150,000?
In short, “complications�-mechanisms that do anything other than tell time. Watchmakers innovate by creating new ones, such as the Porsche’s digital display and power-reserve gauge, or by packing in several. The most expensive modern watch, Vacheron Constantin’s $1.5-million Tour de l’Ile, has 16, including sky and moon charts.
SPECS: PORSCHE DESIGN INDICATOR
Size: 1.9 in. (w), 0.7 in. (h)
Weight: 4.86 oz.
Price: $150,000
Case Material: Titanium
Individual Parts: About 800
Number Made: 40 (in 2005)
Years in Development: 4
New Complications: 2
Accuracy: Within 4 seconds a day
Thanks, D.
________________________________________________
2006 ML 350 - Black, Appearance Package, Navigation System, Entertainment Package, Sunroof Package, Heated Seats, IPod Integration
firstmb is offline
post #2 of 6 (permalink) Old 03-13-2006, 07:35 PM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 207 Post(s)
RE: How It Works: The $150,000 Watch
I always said I'd have a hard time justifying a car that cost $150,000 but a WATCH??
I have a Citizen Eco-drive that I paid over $400.00 for. Expensive in my mind but a bargain compared to the Porche.
cmitch is offline
post #3 of 6 (permalink) Old 03-13-2006, 07:39 PM
my260e's Avatar
Date registered: Jan 2006
Vehicle: 1987 260E, 2000 C230, 2001 S500
Send a message via AIM to my260e
i remember this rule...forgot where i heard it from, but only buy a watch cheaper than 20 and more than 2000 *i.e. rolex* but...150,000 whoa...
my260e is offline
post #4 of 6 (permalink) Old 03-14-2006, 01:23 AM
shrimpton's Avatar
Vehicle: '90 560SEL, V8 Landcruiser, Toyota S/Wagon
I've spent the last two days doing paint maintenance inside a house with a large clock that chimed each quarter hour, half hour, and - of course... hour.
Getting constant reminders of 'How Time Flies' became bloody irritating.
I underpriced the job by three chimes [:(!]!!
shrimpton is offline
post #5 of 6 (permalink) Old 03-14-2006, 07:21 AM
Gert's Avatar
Date registered: Aug 2004
Vehicle: Mercedes G Brabus
Bad investment if you plan to sell it in the near future with profit or even without loss. If that's the case go for Patek Philippe, Rolex, Vacheron Constantine or Audemars Piguet.
Gert is offline
post #6 of 6 (permalink) Old 03-14-2006, 09:32 AM
30-98's Avatar
Vehicle: Many
Just a common self-winding Ebauche with a remontoir and digital disks,A.L.Breguet was making digital self-winders from 1790-1810 that make this look like Blacksmith's work,hell,Tompion,Knibb and others were making making digital dials in the 1680's.
30-98 is offline
