air bubbles out of polyurathane(SP?) - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 11-11-2005, 05:23 PM Thread Starter
iNeon's Avatar
Date registered: Jan 2005
Vehicle: 2008 PT, 1998 neon--1965 VW 1200
Send a message via AIM to iNeon Send a message via MSN to iNeon Send a message via Yahoo to iNeon
RE: air bubbles out of polyurathane(SP?)
its not perfect and it just doesnt fit well enough for me, but its surely an improvement over the black plastic that it came with.
i think next time i will pick up a full set of matching trims(prolly 35-50 dollars at u pull it) and do them all at once, these panels match, but the ash tray and switch panel match eachother better and the heater control and the console trim match eachother better still, its a little funny when theyre all put together.
next time i am going to get a brayer(?) and use contact cement. this heat activated adhesive seemed ok when i was constructing the panels, but once i atarted installing them, it wasnt as good.
i also want burled walnut instead of oak.
This signature removed to protect the innocent.
iNeon is offline
post #12 of 15 (permalink) Old 11-11-2005, 06:27 PM
worst mod in BW history
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK Iridescent Hyundai Accent lol,GoPed Freightshaker & Volvo semi's, c'mawn?
Quoted: 4 Post(s)
dope - 11/9/2005 5:24 AM
Whatever you do,be safe and wear rubber gloves.You certainly don't want to contract any nasty veneereal diseases.
What a drip. Eurethra comedian or a wise ass. Remind me of my first girlfriend. Herpe was so foul I had to use rubber sheets.
not much you can do with std's on limited knowledge, thank Jeebus.
ThrillKill is offline
post #13 of 15 (permalink) Old 11-11-2005, 10:05 PM
DARKTECH's Avatar
Date registered: Sep 2005
Your dash, like the driver, has a crack in it.
DARKTECH is offline
post #14 of 15 (permalink) Old 11-11-2005, 10:22 PM Thread Starter
iNeon's Avatar
after 30 years parked under the hot alabama sun, so wouldnt you.
no really-- i know, i am thinking of sanding them flat, bondoing them in and covering the whole thing in matching blue vinyl.
it might help.
iNeon is offline
post #15 of 15 (permalink) Old 11-12-2005, 12:44 PM
WeVonBraun's Avatar
Vehicle: 1989w126
Quoted: 4 Post(s)
iNeon, I have the exact same cracks at the excat same place over the hot air vents in the middle And the exact same dash color as you have. Your dash looks like the twin brother of mine. With some missing spots here and there.
What's that bondo ? is it good ?
I also notice that my cracks are forming elevated edges on both side of the yellowish canyons.
Tell us more when you start working on that part, I love the way you re create the wood panels. I have been hesitating to simply order a dash-cover and I have been thinking about various solutions. One was to flatten the cracks and fill them (with what?) and then spray a false finish paint. I have seen something that sprays leaving a sort of paper light texture very thin.
And then the color ????
WeVonBraun is offline
