300SE fuel pump relay-location?? - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 05-06-2005, 01:57 PM
talbir's Avatar
Date registered: Dec 2004
Quoted: 2 Post(s)
RE: 300SE fuel pump relay-location??
On the HT leads, only original MB leads have resistors that screw on/off. Replacement HT leads are one piece, all the way from dist cap to spark plug. So it'll depend on which ones have been installed.
Where are you located ? I am happy to meet you and you can try out the ful pump relay from my 300SE. I can also test to confirm whether it's fuel pump relay or ECU voltage issue. And I have a spare HT lead if you require. ( I have far too many spares in my garage at home!)
I am near Heathrow airport, based in Uxbridge. Could always meet somewhere and I can take a look for you.
Email me on sharanbains@hotmail.com if I can be of assistance.
Mercedes w124 500E 1993 Black 040
Mercedes w124 500E 1993 Spruce Green
Mercedes AMG 560SEC 1988
Mercedes AMG DOHC M117 w126 AMG Widebody SEC 1985
Mercedes 560SE Carat Duchatelet 1987
Mercedes w126 SEL Brabus
Mercedes w124 T Brabus
Porsche 911 Turbo SE Slantnose 1986
Mercedes 560E - w124 5.6 DOHC 360bhp by Stratton
Ferrari 328 GTS Quattrovalvole 1986 Koenig Widebody
Porsche 928 S4 by Strosek, Supercharged 550bhp
Mercedes 190E AMG Widebody
Mercedes SEC by Gemballa 6.9
talbir is offline
post #12 of 13 (permalink) Old 05-06-2005, 06:07 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
If there were a problem with the ECU than I would suspect you’d experience more pronounced problems such as rough idle and stalls, not just a dead engine. The ECU is item five in the picture below. The ECU receives data from the many system sensors, such as the engine temp sensor, and uses that information to make needed adjustments to the fuel system via switches and valves, such as the EHA, item four (“pressure actuator�). Since you are not experiencing any of the associated problems with a bad ECU, I think you’re safe to replace the relay.
jdc1244 is offline
post #13 of 13 (permalink) Old 05-07-2005, 02:09 AM
sss11's Avatar
Date registered: Sep 2003
Vehicle: 300 SEL (1989)
Mine had a dry joint.Try resoldering the internal joints & keeping it as a spare.
<a href="http://english.wunderground.com/global/stations/48698.html">
<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/english/global/stations/48698.gif"
sss11 is offline
    90 300SL- Fuel pump relay location?? benzluvr1 R129 SL-Class 3 10-28-2012 05:06 AM
    Location of Fuel Pump Relay for 1990 190 E BobbyGee General Mercedes-Benz 0 03-18-2006 04:31 PM
    Location of Fuel Pump Relay and/or Electrical Diagrams Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 6 12-13-2005 09:30 AM
    fuel pump relay location dave850 R/C107 SL/SLC Class 3 06-27-2004 12:52 PM
    300e Wiring question: location of fuel pump relay Guest (MBNZ) W124 E,CE,D,TD Class 3 08-28-2001 10:16 AM
