87 300TD no power - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-09-2005, 09:25 PM Thread Starter
Date registered: Apr 2005
87 300TD no power
Has anyone encountered a problem where the car runs fine but has no power? Everything seems fine but it has absolutely no excelleration.
poods2 is offline
post #2 of 2 (permalink) Old 04-09-2005, 10:05 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon/'01 EV Weekender
Quoted: 1419 Post(s)
RE: 87 300TD no power
Definitely a fuel related issue there. Check both your fuel filters (and possibly the tank strainer), but you'll also need to investigate the ALDA device on the injection pump for proper function. The latter is typically the cause of lackluster acceleration in MB turbodiesel engines. These units need to hold at least 10psi pressure to function properly, and many have developed leaks over time. They can also be adjusted or shimmed to increase fuel quantity under the boost curve, which will dramatically improve your off-idle acceleration.
Zeitgeist is offline
