Left last year's gas in my snowblower - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 10-28-2004, 03:49 PM Thread Starter
Date registered: Sep 2004
Vehicle: Passat Variant
Send a message via Yahoo to kuan1
Should I try and start it or drain it? It's a 4 stroker.
All hail the Sixteen Men of Tain!
kuan1 is offline
post #2 of 12 (permalink) Old 10-28-2004, 03:51 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 737 Post(s)
RE: Left last year's gas in my snowblower
You were supposed to drain it at the end of last winter. No harm in trying it now.
GeeS is offline
post #3 of 12 (permalink) Old 10-28-2004, 03:53 PM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
Savor that low cost fuel while you can. [:D]
MTI is offline
post #4 of 12 (permalink) Old 10-28-2004, 03:58 PM
Date registered: Sep 2003
Vehicle: 300d, 409d
The drawback to trying to start it is that you may suck up pieces of varnish into the jet from the carb bowl. If you didn't put Stabil in the fuel to keep it fresh, I'd be half inclined to drain the tank, drop the bowl on the carb and clean it out before starting so the gunk never makes it into the jet.
On the other hand, I have a 72 Dodge Travco motorhome which has sat with stale gas for most of its existence(it has 100 gallons in the tank) It wasn't until about 1999 that I had to take the carb apart and clean it. However, it was thoroughly caked with varnish everywhere.
PS--any accountants on board? Do I have to report the increased value of that fuel to the IRS as capital gains?
kerry edwards is offline
post #5 of 12 (permalink) Old 10-28-2004, 04:01 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 737 Post(s)
Isn't varnish damage done by leaving fuel in the carbs? I always thought varnish was just a coating that stayed where it was.
GeeS is offline
post #6 of 12 (permalink) Old 10-28-2004, 04:03 PM
Vehicle: 300d, 409d
GermanStar - 10/28/2004 7:01 PM
It definitely flaked off in my Dodge. Perhaps it was a result of many years of buildup and one year won't matter. I think when the fuel evaporated from the bowl after sitting for months, some of the varnish dropped into the bottom of the bowl. That's the only explanation I have for what I found in there.
post #7 of 12 (permalink) Old 10-28-2004, 04:10 PM Thread Starter
Knew that topsider was gonna be good for something. I'll drain it. Maybe some STP injector cleaner?
kuan1 is offline
post #8 of 12 (permalink) Old 10-28-2004, 04:20 PM
w126's Avatar
Yeah, gas sitting in the carb isn't good as it'll turn into varnish -- smaller volume = trouble and will clog up the jets. The old smell test always works. :)
w126 is offline
post #9 of 12 (permalink) Old 10-28-2004, 04:31 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 737 Post(s)
w126 - 10/28/2004 4:20 PM
Right, but would you be afraid to use the gas in the tank?
GeeS is offline
post #10 of 12 (permalink) Old 10-28-2004, 05:00 PM
w126's Avatar
In that small of a tanks, yes.
If it were an auto with at least a half full tank, no. More than a year of sitting, I'd drain the tank and clean the fuel system.
I'm getting ready to store the Cadillac and will top off all 26 gallons with 93 octane and stabilizer. Time for a long winters sleep. [|)]
w126 is offline
