Tech Help Needed - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-09-2004, 11:31 AM Thread Starter
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 545 Post(s)
Tech Help Needed
Dear Tech Support:
Last year I upgraded from Girlfriend 7.0 to Wife 1.0. I soon noticed that the new program began unexpected child processing that took up a lot of space and valuable resources. No mention of this was included with the product information. In addition, Wife 1.0 installed itself into all other programs and now launches during system initialization, where it monitors all other system activity. Applications such as Poker Night 10.3, Football 5.0, Hunting and Fishing 7.5, and Racing 3.6 no longer run, crashing the system whenever selected. I can't seem to keep Wife 1.0 in the background while attempting to run my favorite applications.
I'm thinking about going back to Girlfriend 7.0, but the uninstall doesn't work on Wife 1.0. Please help!
Thanks, A Troubled User.
Dear Troubled User:
This is a very common problem that men complain about. It is due to a primary misconception. Many people upgrade from Girlfriend 7.0 to Wife 1.0, thinking that it is merely a Utilities and Entertainment program. Wife 1.0 is an OPERATING SYSTEM and is designed by its Creator to run EVERYTHING!!!
It is also impossible to delete Wife 1.0 and to return to Girlfriend 7.0. Hidden operating systems files cause Girlfriend 7.0 to emulate Wife 1.0, so nothing is gained. It is impossible to uninstall, delete, or purge the program files from the system once installed. You cannot go back to Girlfriend 7.0 because Wife 1.0 is designed to not allow this. Some have tried Girlfriend 8.0 or Wife 2.0 but end up with more problems than in the original system. Look in your Wife 1.0 manual under Warnings-Alimony/Child Support.
I recommend that you keep Wife 1.0 and work on improving the situation. I suggest installing the background application "Yes Dear" to alleviate software augmentation. Having installed Wife 1.0 myself, I also suggest that you read the entire section regarding 'General Partnership Faults'!
Your Wife 1.0 does a scan for GPFs during it's monthly program maintenance scan (PMS). You must assume joint responsibility for any faults and problems that occur, regardless of their cause. You will also find that GPFs are cyclical. The best course of action is to enter the command C:\APOLOGIZE.
Avoid excessive use of C:\YESDEAR because ultimately you will have to give the APOLOGIZE command before the system will return to normal anyway.
Remember, the system will run smoothly as long as you share the blame for all GPFs. Wife 1.0 is a great program, but it tends to be very high maintenance.
Wife 1.0 comes with several support programs, such as Clean and Sweep 3.0, Cook It 1.5 (which replaces Burn It 1.0), and Do Bills 4.2. You must, however, be very careful how you use these programs. Improper use will cause the system to launch the program Nag Nag 9.5. Once this happens, the only way to improve the performance of Wife 1.0 is to purchase additional software. I recommend Flowers 2.1 and Diamonds 5.0 should this happen.
WARNING!!! DO NOT, under any circumstances, install Secretary With Short Skirt 3.3. This application is not supported by Wife 1.0 and will cause irreversible damage to the operating system.
Best of luck,
Tech Support
GeeS is offline
post #2 of 3 (permalink) Old 06-11-2004, 08:28 AM
Date registered: May 2004
Vehicle: 85 300cd, 2000 ford excursion diesel, 1999 528 itwagon 95 roadking
RE: Tech Help Needed
wait ,,,after 4 years your downloading by yourself.I went thru this, after 18 years and 24 years of knowing eachother, the baby will come first get a hobby.I was once told that in out relationship that the kids{twins} came first and then work, never did tell me where I was in the lineup. still dont know.decide , both of you how everything w/ child is to be handled, and stick with it it lessens the fights. remember , she will still have a ton of hormones raging in her system after the baby is born and as sure as the sun, you will be wrong a lot wether you are or not is imaterial. good news,, it will pass and you will survive I did and I thought I was a gonner 3 times.good luck
rousch is offline
post #3 of 3 (permalink) Old 06-12-2004, 08:48 PM
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
she needs to be booted....oh I mean rebooted...
BENZDOC is offline
