» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz News & Polls > Mercedes-Benz News
Old 06-10-2008, 08:13 AM   #1 (permalink)
Administrator
administrator's Avatar
Date registered: Mar 2006
Brabus Bullit Black Arrow Finally Goes On Sale, Takes Mercedes C-Class To The Extreme
No, that's not Darth Vader. Nope, it's the Brabus Bullit Black Arrow and trust us, it's got more in common with Vader than the Mustang variant with the same name. We showed you the new Brabus-built C-Class first back at the Frankfurt Auto Show a couple months ago, but now the Deutsch tuners of all things Daimler have just revealed that their newest Übermensch-motored Mercedes is now available for purchase in an orgasm of Bruce (don't believe us? Check the press release out yourself). If you remember, the Bullit Black Arrow gets a SV12 S Biturbo twelve-cylinder engine dropped into the engine bay to replace the normal highest-end 6.2-liter V8 engine from the C-Class. That newer, faster, stronger engine gives the Bullit Black Arrow 720 HP (SAE net) and an astonishing 974 lb-ft of torque — and 0-to-186 mph in 24.5 seconds. Oh but wait, we're talking a top speed of 225 MPH. Sounds to us like some automaker wants to make sure that the 556 HP 2009 Cadillac CTS-V doesn't take all the glory from the four-door race for the highest-speed four-door sedan. Full press release after the jump.
BRABUS BULLIT BLACK ARROW The Four-Door V12 Biturbo Stealth Super Sports Car With 730 hp (720 hp SAE net), 1,320 Nm (974 lb-ft), 0 - 300 km/h (186 mph) in 24.5 seconds and a Top Speed of More than 360 km/h (225 mph) Ultra powerful, ultra fast and conspicuously inconspicuous: The four-door stealth super sports car BRABUS BULLIT BLACK ARROW offers performance superlatives like no other car on the market: The basis for the car is the body of the new C-Class sedan, covered with a special matte-black coating. The BRABUS SV12 S Biturbo twelve-cylinder engine was dropped into the engine bay with almost surgical precision. Performance is staggering: 3.9 seconds from rest to 100 km/h (62 mph), 24.5 seconds for 0 - 300 km/h (186 mph) and a top speed of more than 360 km/h (225 mph). BRABUS produces the BULLIT BLACK ARROW in small-series production starting at 348,000 Euros MSRP.
The BRABUS BULLIT BLACK ARROW ensures that the world's fastest sedans continue to come from Bottrop. The BRABUS BULLIT BLACK ARROW follows in the footsteps of the 330-km/h (206 mph) BRABUS E V12 based on the W 210-series Mercedes E-Class, the 350.2-km/h (219 mph) E V12 Biturbo of the new W 211 generation and the world's current fastest sedan, the 365.7- km/h (227.2 mph) BRABUS ROCKET based on the Mercedes CLS.
Numerous modifications to the reinforced body were necessary to install the turbocharged V12 engine in the C-Class engine bay. The BRABUS SV12 S Biturbo engine is derived directly from the BRABUS ROCKET and uses the latest Mercedes S 600 engine that has been completely reworked in the company-own engine building shop.
Nothing beats displacement except even more displacement: A crankshaft with longer stroke, larger cylinder bore, and special pistons and piston rods increase displacement of the twelve-cylinder three-valve engine from 5.5 to 6.3 liters (336 to 385 cu. in.).
Cylinder heads optimized for faster gas exchange and high-performance camshafts also contribute to the increase in power output. They are assisted by a more efficient dual turbocharging system, special manifolds, larger turbochargers and larger intercoolers. Because of space constraints in the C-Class body an entirely new stainless-steel high-performance exhaust system with low back-pressure metal catalysts had to be developed.
The BRABUS motor engineers used state-of-the-art engine test benches to program new mapping for engine electronics and on-board diagnostics. The new mapping ensures optimal power yield while meeting strict EURO IV emission limits.
The BRABUS SV12 S Biturbo displacement engine, lubricated like all BRABUS high-performance engines with ARAL Synthetic motor oil, produces 730 hp (720 hp SAE net) / 537 kW at just 5,100 rpm. The peak torque of 1,320 Nm (974 lb-ft) is limited in-car electronically to 1,100 Nm (811 lb-ft).
Power is transferred to the rear wheels via a reinforced five-speed automatic transmission and a BRABUS limited-slip differential with a locking rate of 40 percent. Customers can choose from two final drive ratios. The BRABUS BULLIT BLACK ARROW features all modern driving dynamics systems such as ABS, ASR and ESP.
The matte-black stealth street rocket delivers unique performance: Just 3.9 seconds pass for the sprint from 0 - 100 km/h (62 mph), 200 km/h (124 mph) is reached after just 10.49 seconds. And after just 24.5 seconds the car shatters the 300-km/h barrier (186 mph). Top speed is more than 360 km/h (225 mph).
At these speeds favorable aerodynamic properties are absolutely essential. The BRABUS BULLIT BLACK ARROW was honed to perfection in the wind tunnel. The BULLIT front apron features large air ducts to supply cooling air for radiators and front brakes. Its sophisticated design further reduces lift on the front axle. Its aerodynamic counterparts in the rear are a three-piece rear spoiler and a rear apron with integrated diffuser. Both front and rear aprons are made from especially light yet highly robust autoclave-baked carbon fiber.
A wider track optimizes directional stability so elementary at speeds beyond 300 km/h. The BRABUS designers have styled aluminum wheel arch flares for front and rear axle. They are seamlessly melded to the production body and add six centimeters (2.4 inches) to the C-Class width. BRABUS rocker panels optimize the airstream along the sides. They also feature integrated entry lights that make entering and exiting the vehicle safer in the dark.
The visual appearance of the BRABUS BULLIT BLACK ARROW is further characterized by the new hood. Its integrated 'gills' are not just distinctive features, they also ensure the engine's thermal health.
The wheel arch flares provide space for especially wide matte-black BRABUS Monoblock S light-alloy wheels with high-performance tires from technology partners YOKOHAMA or Pirelli. The 9.5Jx19 wheels on the front axle are shod with size 265/30 ZR 19 tires. The rear axle is fitted with size 10Jx19 wheels and size 285/30 ZR 19 tires.
The height-adjustable coil-over suspension was developed specifically for the BRABUS BULLIT BLACK ARROW. The gas-pressure shocks feature ten selectable settings each for bound and rebound. They provide a sporty yet comfortable ride and safe handling in any situation. Sport stabilizers reduces body roll to a minimum during fast cornering.
The BRABUS high-performance brake system can handle even the most extreme stress. It features 12-piston aluminum fixed calipers on the front axle that grip vented and grooved 380 x 37 millimeter (15 x 1.46 inches) brake discs. The rear axle stops with 360 x 28 millimeter (14.2 x 1.1 inches) discs and six-piston aluminum fixed calipers.
Exclusive individuality also abounds in the interior of the BRABUS automobile: The standard equipment package includes a fully leather interior hand-crafted in the company-own upholstery shop from the finest Mastik and Nubuk leathers.
The custom BULLIT seats offer a perfect combination of comfort and lateral support. Their carbon-fiber rear covers lend the interior an especially sporty feel. This look is complemented by carbon-fiber components on dashboard, center console and door panels as well as by the ergonomically shaped sport steering wheel and aluminum pedals and shifter.
BRABUS BULLIT BLACK ARROW - Technical Data
Body
4-door sedan based on Mercedes-Benz C-Class, W 204 series
Steel unibody widened with BRABUS fender flares by 60 mm (2.36 inches). BRABUS hood with integrated gills.
BRABUS BULLIT aerodynamic-enhancement kit with BULLIT front and rear bumper manufactured from carbon fiber baked in an autoclave. Rocker panels with integrated entrance lights, three-piece rear spoiler.
BRABUS BULLIT BLACK ARROW with matte-black coating.
Measurements:
Length 4.590 mm 180.7 in.
Width 1.830 mm 72.0 in.
Height 1.402 mm 55.2 in.
Curb weight 1,850 kg 4,079 lbs.
Engine
BRABUS SV 12 S Biturbo displacement engine based on Mercedes 600
V12-cylinder 3-valve light-alloy engine with twin turbochargers
Displacement 6,233 cm³ (380 cu. in.)
Compression ratio 9.0 : 1
Rated power 730 hp (720 hp SAE net) / 537 kW at 5,100 rpm
Peak torque 1,320 Nm (974 lb-ft) from 2,100 rpm (electronically limited to 1,100 Nm - 811 lb-ft)
Fuel: Super plus (98 octane)
Motor oil: ARAL
BRABUS SV 12 S Biturbo engine conversion consisting of:
Displacement increase to 6.3 liters with special crankshaft with longer stroke, enlarged cylinder bore with corresponding larger pistons. Both cylinder heads feature flow-optimized ports and special camshafts. Two high-performance turbochargers with special exhaust manifolds; more efficient intercooling system and BRABUS stainless-steel high-performance exhaust system with low-back-pressure metal catalysts. Newly programmed mapping for engine electronics and on-board diagnostics.
Drivetrain
Rear-Wheel Drive
Reinforced five-speed automatic transmission
Gear ratios:
1st gear 3.59
2nd gear 2.19
3rd gear 1.41
4th gear 1.00
5th gear 0.83
BRABUS locking rear differential with 40 percent locking rate
Final drive either 2.65 : 1 (top speed 315 km/h - 196 mph) or 2.24 : 1 (top speed 350 km/h - 217 mph - electronically limited).
Suspension
Independent suspension front and rear with height-adjustable BRABUS coil-over suspension.
Front axle:
Three-link, anti-dive geometry. Height-adjustable BRABUS struts with coil springs and gas-pressure shocks featuring ten settings each for bound and rebound; BRABUS sport sway bar.
Rear axle:
Five-link, anti-dive and anti-squat geometry. Height-adjustable BRABUS struts with coil springs and gas-pressure shocks featuring ten settings each for bound and rebound; BRABUS sport sway bar.
Wheels:
BRABUS Monoblock S light-alloy wheels with YOKOHAMA or Pirelli high-performance tires.
Front: 9.5Jx19 H2 with 265/30 ZR 19
Rear: 10.0Jx19 H2 with 285/30 ZR 19
Brake System
Dual-circuit brakes with Brake Assist and BRABUS high-performance brake system.
Front: BRABUS 12-piston fixed aluminum calipers with vented and grooved 380 x 37 mm
(15 x 1.46 in.) steel brake discs.
Rear: BRABUS six-piston fixed aluminum calipers with vented and grooved 360 x 28 mm (14.2 x 1.1 in.) steel brake discs.
Performance
0 - 100 km/h (62 mph): 3.9 sec
0 - 200 km/h (124 mph): 10.49 sec
0 - 300 km/h (186 mph): 24.5 sec
Top speed: more than 360 km/h (225 mph)
Gallery / Source: BRABUS Bullit Black Arrow: Brabus Bullit Black Arrow Finally Goes On Sale, Takes Mercedes C-Class To The Extreme
If you have any suggestions or feedback, please PM me.
administrator is offline   Reply With Quote
Old 06-10-2008, 10:07 AM   #2 (permalink)
MB-SV's Avatar
Date registered: Nov 2007
I especially like the top speed of 225mph.
S.
2008 Mercedes C300 Sport mars red/black
2007 Lexus IS350 Sport Pkg. smoky granite metallic/gray
2002 Jeep KJ 4wd Sport white/gray
MB-SV is offline   Reply With Quote
Old 06-11-2008, 03:07 PM   #3 (permalink)
Date registered: Jan 2008
Vehicle: 2008 C300 Sport
this is insane. too bad its like $500,000
jgorman13 is offline   Reply With Quote
Old 06-11-2008, 09:03 PM   #4 (permalink)
Kasprzak85's Avatar
Date registered: Dec 2007
Vehicle: 2003 SLK32 AMG
I want... House or car hmmmmm....
Kasprzak85 is offline   Reply With Quote
Old 06-12-2008, 10:16 AM   #5 (permalink)
~BANNED~
benz rider's Avatar
Vehicle: 97'C280
C-class with a V12? DAMN!
benz rider is offline   Reply With Quote
Old 06-13-2008, 07:36 PM   #6 (permalink)
Yal
Date registered: Sep 2004
Have mercy!!!!!!!!!!!!
Yal is offline   Reply With Quote
Old 06-13-2008, 08:37 PM   #7 (permalink)
emac53's Avatar
Date registered: Jun 2007
Vehicle: 1990 300ce 24v.
I want one. This is the ultimate in extreme family motoring.
emac53 is offline   Reply With Quote
Old 06-14-2008, 12:21 AM   #8 (permalink)
rothmans18's Avatar
Vehicle: Black 560 SEC AMG, White 560 SEC Carat (RIP 09) , 300E
i woonder how it corners, must understeer like a bitch
rothmans18 is offline   Reply With Quote
Old 06-14-2008, 10:25 PM   #9 (permalink)
danboy's Avatar
Date registered: Apr 2008
Vehicle: 91 560SEL(RIP),98 E320matic 230k baby!,98 C230,93 500Ehurt,Rover crawler,97 Vulcan,01 R1,02suzukiTLR
wow, where could you possibly drive that to it's potential?
danboy is offline   Reply With Quote
Old 06-15-2008, 07:01 PM   #10 (permalink)
Yal
Bonneville Salt Flats?
HTML code is On
G Class BRABUS Bullbar Black NEW for W463 G RedLine For Sale, Trade & Wanted Items 0 04-24-2006 12:31 PM
Bush finally takes to Afghanistan 320CLSman Off-Topic 20 03-02-2006 06:19 PM
FOR SALE! 1997 C-280 Black on Black - Brabus Suspension - AMG Wheels ExtremeRacingNY W202 C36 AMG, C43 AMG 1 12-22-2005 08:26 AM
Mercedes E-class Brabus D6 korisnikone W211 E55 AMG, E63 AMG 2 12-07-2005 02:19 PM
For Sale: 2000 Mercedes-Benz : G-Class Brabus 5.8 Saigon76nyc For Sale, Trade & Wanted Items 0 07-30-2005 06:51 PM
