Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz News & Polls > Mercedes-Benz News
Old 09-21-2007, 02:25 PM   #1 (permalink)
Administrator
administrator's Avatar
Date registered: Mar 2006
Frankfurt 2007: Mercedes has an answer for Lexus with S-Class Hybrids
click above image to view high-res gallery of the Mercedes S300 Hybrid Concept
During the huge debut Mercedes held for the F700 Concept and C-Class Estate, it also showed off the new 2010 Mercedes-Benz S300. This is the first product of a collaboration between Mercedes and BMW to develop a less complex mild hybrid that could be adapted to most of their vehicles. Promised for 2010, this will be the first model introduced under that program. It mates the 3.0L Bluetec diesel V-6 to that new hybrid set-up and gets a combined 43.6 mpg (in US gallons) on the economy cycle.
Sounds pretty efficient to us. Mercedes also had some info on the 2009 S400 Hybrid, which uses a petrol engine instead of the diesel used in the S300, and will be the first gas-engined German hybrid on the market when it goes on sale in '09. While the car itself looks exactly like the S300 above, we added a shot of the placard to our gallery so you can see the specs.
If this sounds like a good thing to you, and frankly, why wouldn't it, click over to AB Green to read more about the car and the technology behind it. And don't forget to check out the gallery of live shots as well.
[Source: Mercedes-Benz via AutoblogGreen]
PRESS RELEASE:
2009: S 400 HYBRID sets a new note in the luxury segment
At the same time as the ML 450 HYBRID, Mercedes-Benz will be launching an S_Class with petrol hybrid on the market. In the S 400 HYBRID, which will also be available from mid-2009 in Europe, the 205 kW/279 hp V6 petrol engine is combined with a hybrid module delivering from the outset 160 Nm and 15 kW/ 20 hp. The combined maximum power output is 220 kW/299 hp, the combined maximum torque amounts to 375 Newton metres.
The S 400 HYBRID can accelerate in 7.3 seconds from 0 to 100 km/h and reach an electronically limited top speed of 250 km/h. Yet even with such excellent performance, this superb combustion engine requires a mere 7.9 litres per 100 kilometres in the NEFZ cycle. This results in CO2 emissions of just 190 grams per kilometre, making the S 400 HYBRID the most fuel-efficient luxury petrol engine saloon in the world, independently of whether competitors pit a petrol- diesel- or hybrid drive against it. Only the S 300 BLUETEC HYBRID, the S 400 BLUETEC HYBRID and the F 700, also presented at the IAA by Mercedes-Benz, can improve significantly on the world record set by the S 400 HYBRID in terms of low fuel consumption and CO2 emissions.
Enjoyable and economical driving from one efficient unit
The compact hybrid module installed in all the S-Class hybrids comprises a disk-shaped electric engine, which also functions as a starter motor and dynamo. This system offers a double benefit, working on the one hand in various ways to save fuel, and making driving so much more fun.
The main reason for the increased driving enjoyment is what is known as the boost effect, whereby the electric engine supports the combustion engine during the high-consumption acceleration phase with a maximum extra torque of 160 Newton metres. With this high torque the electric engine assists the combustion engine heartily when accelerating from very low engine speeds. As a result, the combustion engine itself needs less time and energy to build up its maximum torque. The only thing the driver notices from this synergy of the two power units is a supremely effortless power output whenever he starts off.
The hybrid module also features a comfortable start-stop function which switches the engine off whenever the vehicle stops, for example at traffic lights. Once the vehicle is ready to move off again, the electric engine starts the main engine again so gently, that it remains virtually unnoticed. This of course also contributes to fuel savings and is kind to the environment: since the engine starts virtually immediately, virtually no unburned fuel is discharged when starting off. When decelerating, on the other hand, the electric engine functions as a generator, and can recover braking energy in what is known as the recuperation process. This energy is stored in a powerful but compact lithium-ion battery pack in the engine compartment, ready for use when required. The engine management of this complex system is governed by a powerful control unit, which is also installed close to the engine.
2010: S 300 BLUETEC HYBRID with 560 Nm and just 5.4 l/100 km
The tremendous savings potential of the modular technology concept being applied by Mercedes-Benz is underlined by the S 300 BLUETEC HYBRID, due to arrive on the market in 2010, too. The configuration and performance data of this engine are identical to those in the E 300 BLUETEC HYBRID. In the S-Class too, the BLUETEC/Hybrid combination develops a maximum torque of 560 Newton metres, comparable with that of a large-volume V8 petrol engine. When combined with the standard 7G-TRONIC seven-speed automatic transmission, the S 300 BLUETEC HYBRID accelerates from 0 to 100 km/h in just 8.4 seconds, and it can reach a top speed of 240 km/h. Even with this superior performance, fuel consumption stands at just 5.4 litres of diesel per 100 kilometres, corresponding to a mere 142 grams of CO2 per kilometre _ 57 grams, or some 30 per cent, less than the current best saloon in the S-Class segment anywhere in the world.
The S-Class uses the version of BLUETEC with AdBlue injection system. Thanks to the combination of BLUETEC and hybrid technology - the only combination of this nature in the world, delivering the most economical and environmentally compatible premium cars in the world - the S 300 BLUETEC HYBRID has the potential to meet the most stringent emissions standards applicable anywhere in the world – for example, the European EU6 standard or the US 50-state BIN5 standard.
[Source: Autoblog.com]
If you have any suggestions or feedback, please PM me.
administrator is offline   Reply With Quote
Old 10-03-2007, 05:41 AM   #2 (permalink)
NAB
Date registered: Oct 2005
Vehicle: 1992 400Se; 1984 230CE
Wink The way forward
The European Commission is currently having a major debate about the level of emissions that will be acceptable for all new cars sold in the EU. Significant reductions are being tabled and it is clear that while the manufacturers are lobbying hard to prevent these rules being too stringent, they are also spending money on creating cars that will meet the new CO2 targets.
These new S class cars are exciting examples of that research - fast, low emissions and high mpg - it's re-assuring to know that we will still be able to drive luxury cars even when the environmental laws have got a lot stricter.
I don't know about the US position, but I imagine most buyers will welcome increased economy.
The only downside is that these hybrids are expensive and I guess that's why they are starting with the high-end models where the cost difference will be less significant.
Neil
NAB is offline   Reply With Quote
Old 11-15-2007, 11:15 PM   #3 (permalink)
Vehicle: 82 200 W123, 92 300E 2.6 W124, 90 260SE W126
I just hope I could save up enough cash in time when the S300 BLUETEC HYBRID comes out in the market
ronw123w124 is offline   Reply With Quote
HTML code is On
Frankfurt 2007: Mercedes Benz F700 administrator Mercedes-Benz News 0 09-21-2007 02:24 PM
2007 Frankfurt Auto Show Mercedes F700 mcbear General Mercedes-Benz 20 09-16-2007 04:21 PM
2007 Mercedes G-Class review torres G-Class 2 02-28-2007 06:05 AM
First Drive: 2007 Mercedes-Benz GL-Class MLSONIC W164 M-Class 1 03-26-2006 12:07 PM
Lexus SC 430 Vs. Mercedes-Benz SLK-Class malibuite R171 SLK Class 41 09-20-2005 12:42 AM
