New 2017 F1 Tech Rules Changes Analysis. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-25-2016, 01:29 AM Thread Starter
Date registered: Jul 2005
Quoted: 1042 Post(s)
We will have to see if they are made official, it looks pretty solid.
Article by Scarbs from Weds.
Analysis: F1's 2017 tech changes
Wednesday, 24 February 2016
Craig Scarborough
Formula 1 teams finally reached a consensus on what could have been sweeping changes to the cars in 2017.
After months of wrangling, the FIA has finally announced a draft set of technical regulations for 2017. Down from the original target of five to six seconds, the plan aims to cut lap times by three seconds by increasing aero and mechanical grip, combined with revised Pirelli tires to suit slightly heavier cars.
The headline points are wider tyres and wings, and a larger diffuser. These changes have been largely aimed at making the cars faster, mainly from increased corner speed rather than top speeds. However, the stated intentions do not included improving overtaking, and many of these changes reverse the work done by the Overtaking Working Group back in 2009.
It remains to be seen if the step up in performance from the wider and grippier setup, and bigger diffuser, somehow transpires to allow cars to overtake easier.
Despite the relatively far-reaching changes, the rules do not list a reduction in front-wing complexity, which remains largely unrelated, and is a key factor in how difficult it is to follow another car.
1997The fundamental change is the move to a wider car overall, returning the track width to the pre-1998 dimension of two meters (RIGHT: 1997 Ferrari). With the matching tires now some 60mm wider at the front and 80mm wider at the rear, the car will have more grip and less lateral weight transfer robbing the inside wheel of grip in corners.
These wider tires will create more drag down the straights, as a trade-off for the increase in grip. To create aerodynamic grip, the front wings will become 200mm wider, keeping the wing's alignment to the current front wheels the same.
The floor between the front and rear wheels will be wider, also by 200mm, with the diffuser now longer, taller and slightly wider.
Above this, the rear wing is widened by 150mm and lowered, making it visually similar to the pre-2009 wings. Although not an aerodynamic change, both the front and rear wings, as well as the front of the sidepods, will have a swept-back shape, to make the cars more usually interesting than the current, constrained rectangular shapes.
Along these lines, the area allowed for bargeboards to the side of the cockpit is increased, and the front wing endplates scaled back to simpler designs.
Overall, it means a return to the dimensions of Formula 1 cars in the 1990s, albeit with the modern curvature and complexity we see today.
As well as the basic dimensional rules, a number of smaller allowances for curvature and angles around the floor and suspension have been listed. Allied to those bigger changes, there is massively increased potential to produce even more aerodynamic performance and sensitivity.
It is possible the three-second lap time improvement could be easily eclipsed by teams being aggressive with their interpretation of the rules. As a result, teams will now have to balance how they develop their just-launched 2016 cars while diverting resources towards next year's disruptive changes.
With this set of rule changes, there is clearly an opportunity for a team to make a big step forward in competitiveness.
F1 Racing News | Racer.com - Analysis: F1's 2017 tech changes
Noodles is offline
post #2 of 4 (permalink) Old 02-25-2016, 08:38 PM
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 1036 Post(s)
Pirelli concerns
Found: I remembered reading this article outlining Pirelli 2017 tire concerns in Jan.
Plans to speed up 2017 F1 cars watered down after Pirelli concern - BBC Sport
Plans to make Formula 1 cars faster for 2017 are being watered down following an intervention from Pirelli.
Rule changes, including making cars wider and more dramatic-looking, had targeted a lap-time gain of five seconds.
But F1's tyre supplier Pirelli told teams its tyres could not cope with the planned increase in cornering forces without making them much more resilient, and therefore slower.
Teams are now investigating the effect of a revised series of changes with a smaller increase in aerodynamic downforce.
That work is ongoing, but leading engineers predict the cars will now be more like three seconds a lap faster.
Pirelli told BBC Sport the data it presented to teams was based on calculations at an early stage in the process of defining the tyres for 2017.
What is this all about?
F1's bosses decided last year to make the cars more exciting and dramatic-looking in response to concerns that the sport's appeal is waning.
Teams and governing body the FIA had by the end of November agreed on a series of changes for 2017:
to widen the track - the distance across the car between the wheels - from 1800mm to 2000mm
fit wider tyres
change the shape and size of the front and rear wings
produce more aerodynamic downforce from wider bodywork and a re-designed underfloor.
The increase in downforce predicted from these plans is estimated at between 25-60%.
What derailed the plan?
Sources say Pirelli made a presentation to the teams in which it said its tyres, made to the planned 2017 dimensions, could not cope with more than a 10-15% increase in downforce without it needing to impose much higher tyre pressures.
It said pressures would have to be as high as 27psi - about 50% higher than would be considered by teams to be 'normal'.
But higher tyre pressure reduces grip, which would mean diminishing returns from the increase in car performance.
The other problem was that with reduced tyre grip, a greater proportion of the lap-time gain would come from aerodynamics, and the feeling among engineers and world governing body the FIA was that this would make close racing and overtaking even more difficult than it already is.
This is counter to the initial intent behind the changes, which was to speed up the cars without having a detrimental effect on the quality of the racing.
Nico Rosberg - Mercedes
Mercedes' Nico Rosberg will hope to end Lewis Hamilton's grip on the World Championship in 2016
A Pirelli spokesman said: "With the new tyre sizes proposed for 2017, we think the load capacity of a tyre built to the current construction would increase by about 10%. But nobody knows what structure we will choose for 2017 yet.
"Everything will be calculated much more carefully when we start testing."
He added that one of the problems was that Pirelli was forbidden by F1's rules from doing on-track testing before 2017, and there was still no agreement on a resolution to that problem.
So what now?
Not all the teams supported the proposal to revise the new rules - the vote was eight in favour and three against among the 11 teams.
But that was felt to be a significant enough majority to press ahead.
Pirelli - McLaren pit crew
McLaren finished ninth in the constructors' championship
The FIA asked teams to investigate the effect of abandoning two key elements of the new rules package which had been aimed at increasing downforce - a redesigned underfloor and introduction of wider bodywork.
Plans to widen the gap between the tyres, revise the size and shape of the front and rear wings and fit bigger tyres remain, however.
A senior insider said the target speed increase for 2017 could not be confirmed until the completion of research into the revised plans. The aim is to finalise a new set of rules before the start of the new season in March.
Hasn't this come up already?
The development comes after world champions Mercedes raised concerns towards the end of last season about the 2017 rules, questioning whether the tyres would be able to cope with the increased loads.
Among other issues, Mercedes pointed out that current F1 cars are approaching historic highs in terms of downforce and power and that, if the sport pressed ahead, Pirelli would have to deal with loads to which no other racing tyre has ever been subjected.
Mercedes' rivals rejected their concerns at the time, many saying that the team were trying to protect their competitive advantage by keeping rules stable.
Is there a wider issue?
There is concern in some quarters that the limitations of the tyres will undermine the aims of the new rules and lead to a lot of expensive research into new car designs for little effect.
As a result of this, there was a proposal to abandon the whole process of changing the cars fundamentally for 2017, or to just keep the wider track but change nothing else. This was rejected by the wider group of teams.
Pirelli said: "Maybe a totally brand new tyre can be built. There is a lot of speculation about this process, but it is still at a very early stage."
The spokesman added that Pirelli thought a five-second reduction in lap times was "too much", and that four seconds was more appropriate.
What about engines?
The rule changes for 2017 are being formulated at the same time as the road car manufacturers in F1 are trying to come up with revisions to the engine rules to satisfy a request from the FIA for power units to be cheaper, simpler, noisier and more widely available to teams.
The manufacturers have to finalise proposals by 15 January.
BBC Sport has learned that a bid to drop the MGU-H, the part of the hybrid system that regenerates energy from the turbocharger, has been rejected and that the proposal will be for the hybrid system to remain part of the same design as it is now.
However, the idea is for a lot of other parts of the engine to be made standard to reduce costs.
The target is for the price of engines for customer teams to be 10m euros (£7.5m) in 2018, when the changes will be introduced. Power units currently cost customers in the region of 18-23m euros a season.
Noodles likes this.
Teutone is offline
post #3 of 4 (permalink) Old 02-26-2016, 01:03 AM Thread Starter
Interesting stuff there.
I do recall Pirelli issuing concerns about the tires, but did put 2 and 2 together that the revised changes had to do with that. Sort of ticks me off that Pirelli can't build a tire. I am sure somebody could build a tire to handle the extra stress.
As far as what they love to now call power units that is a sore spot with me also. I am not sure I would be the avid fan I am today if I was at a track while I was living in the UK as a kid and heard a car making the noises they do today would have really excited me like those beasts of the late 70s and 80s.
Noodles is offline
post #4 of 4 (permalink) Old 02-26-2016, 01:49 AM
CH4S Artist
Teutone's Avatar
Plus, in the 70's you could get up real close (especially Zolder) to the cars and drivers, to sounds and imo equally important smells.
I remember behind the Zandvoort paddock (infield of the track) witnessing a ex F1 racing driver hitting a journalist with his fist (J.P. Beltoise?).
It was a French driver who had one of his elbow joints damaged permanently in an accident, and had the doctors set it at an angle so he could still hold a steering wheel.
Another time my friend and I found ourselves sitting next to Derek Bell in the Zandvoort track restaurant. Drivers in racing overalls and 'civilian' visitors were sharing the same space.
Cheers
Noodles likes this.
Teutone is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Mercedes-Benz Motorsports & Racing
