Indian Grand Prix: BBC F1 analyst Gary Anderson's set up guide - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 10-25-2013, 09:52 PM Thread Starter
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 937 Post(s)
BBC Sport - Indian Grand Prix: BBC F1 analyst Gary Anderson's guide
By Gary Anderson
BBC F1 technical analyst The Buddh International Circuit that hosts the Indian Grand Prix this weekend has some really good, fast sweeping corners and is a good test of both car and driver.
Primarily, the car needs to have a good aerodynamic balance as a lot of the corners lead into one another - such as the combinations at Eight and Nine, 13 and 14 and particularly through 10, 11 and 12.
It's a reasonably high-speed track but braking stability is vital into Turns One, Three, Four and 16 are all about getting the car stopped and turned in.
Because of that, the track requires a real compromise set-up.
The Indian Grand Prix
Image of Andrew Benson Andrew Benson
Chief F1 writer
The Indian Grand Prix is a rare example of a new Formula 1 race not backed by government money, or indeed any government support at all.
It owes its presence on the F1 calendar to the vision of a construction group who wanted a grand prix circuit as part of a new 'sports city' to the south-east of Delhi.
The result has been a challenging track with a pleasant ambience and, for India, proof that it can smoothly run a sporting event of international standing, an important landmark for an increasingly powerful and influential nation.
But the race, only three years old and with two years to run on its contract, already has an uncertain future.
It has been dropped for 2014 and although the claim is that it will be back in early 2015, organisers continue to insist they would prefer October as a date.
Most in F1 expect not to be going back there after this year, which seems a shame, given what the race could mean to both the sport and its hosts this weekend.
It is not possible to have a forward aerodynamic balance, as would be the tendency on a circuit with predominately slow corners, as this would make the car very nervous in the fast corners.
One of the most interesting parts of the track is the complex at Turns Five, Six and Seven.
Turn Five is a left-hander with a fast entry - just over 130mph - but as soon as the driver is into it, he has to slow down for a second left-hander, which is less than 100mph, and immediately after that there is the quick right-hand kink at Turn Seven.
A good car really shows up there.
The driver needs good rear-end stability for braking and turning into Turn Six and then he needs to get on the accelerator as quickly as possible to accelerate towards the 130mph right-left kink at Turns Eight and Nine and then the long, long double apex right-hander at Turns 10 and 11.
Turns 10 and 11 are effectively one corner and it's quite unusual in modern F1. It has an element of banking to it but it then drops away on the exit, which is always going to make the rear unstable.
But the layout actually helps the drivers a little there. They come through Turns 10 and 11, holding, holding, holding the car into the corner and it's very easy to lose the rear on the exit kerb. But because Turn 12 is a left-hand kink, it sort of catches the car for you, because that's the direction you're turning next anyway.
Good for drivers; not so good for racing
With good corner combinations like that, it's no surprise the drivers all like it, but unfortunately that does not mean it will produce a great race. It certainly has not yet.
Quite often, the tracks the drivers like are not so good for racing because they lean towards the faster, more demanding corners, rather than stop-and-go corners.
So in India, while Turn 10-11-12 is immensely satisfying to drive around, there is no way a driver could think about overtaking anyone through there.
The Indian Grand Prix facts
•Laps: 60
•Circuit Length: 5.14km (3.19 miles)
•Number of times held: 2
•First held: 2011
•Most wins (drivers): Sebastian Vettel (2)
•Most wins (constructors): Red Bull (2)
Turn One looks like it should be a decent overtaking spot at the end of the pit straight, but it's deceptively fast, and then the curve to the track in Turn Two means you'd have to be very brave to try to get inside someone at Turn Three.
There's then a long, long straight down to Turn Four, which is the best overtaking opportunity on the track.
After that, the lap is fast and flowing, which makes it very difficult to follow someone closely, so drivers are often a fair bit behind when they arrive back at the section where they might have a chance of overtaking.
The track was made nice and wide and open to try to encourage overtaking, but actually that works against it.
That's because the extra width means the drivers can always carry good corner speed without worrying too much about things going wrong. They don't have to play safe and worry about going off the track because there is plenty of room to get back onto the track if they do go off.
By contrast, on some of the tracks where the drivers have to be a bit more wary of what can go wrong, they have to slow down much more, which leaves room for somebody brave to have a dive up the inside.
Hard to see past Vettel
Sebastian Vettel Sebastian Vettel could win the Formula 1 championship at the Indian Grand Prix
Sebastian Vettel has won both Indian Grands Prix so far in dominant fashion and it's hard to see anyone stopping him doing the same again this year.
The need for braking stability, good corner entry, change of direction, traction and strong aerodynamics all play to the all-round strengths of the Red Bull.
Having said that, Mercedes and Lotus will be knocking on the door. They are not far away and if they get it right and Red Bull trip up for whatever reason, there will be an opportunity for someone else to win.
Former Jordan, Stewart and Jaguar technical director Gary Anderson was talking to BBC Sport's Andrew Benson
Teutone is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Mercedes-Benz Motorsports & Racing
