2012 FIA regulations highlights with James Allison - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-13-2011, 11:15 PM Thread Starter
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 1014 Post(s)
By Editor on Thursday, December 8, 2011
© Lotus Renault GP
Following the announcement of the FIA’s 2012 season Technical and Sporting Regulations, Lotus Renault GP’s Technical Director James Allison explained some of the key changes we can expect to see in 2012. Part one is featured below, with part two soon to follow.
Lower Noses
The car noses are lowered to 550mm above the reference plane (previously they could be 625mm high). This is to ensure that all parts of the nose are definitely below the height of the cockpit sides in the event of a T-Bone type of crash.
Panels
The chassis is constructed from certain panels – the so called “homologated panel” – that are regulated to achieve a required amount of penetration resistance in order to protect the driver. To give better protection to the driver in the event that a car T-bones him from the side, the homologated intrusion panel is increased in height to 550mm above the reference plane (the same height as the highest part of the new nose regulation above).
Apertures and aerodynamics
An ambiguity in art 3.8.5 is cleared up to make it entirely clear that each suspension leg that emerges from the rear bodywork may have just one aperture. Suspension apertures allow the team a certain amount of aerodynamic development possibilities and from an aerodynamicists point of view, the more apertures the merrier. Under the old regulation it was possible to construct a wavy surface where a leg exited and re-entered the bodywork several times, on each occasion accruing another legal aperture – under the new regulation this is no longer possible.
Weight distribution
We had originally agreed for the 2011 cars to have a limited range of adjustment for weight distribution for a single year to cover the introduction of Pirelli’s. This regulation has proved successful and has now been extended to 2013.
Tethers
For 2011, each wheel had to be held on by two safety where previously they had only needed one. In order to ensure that the tethers offer genuine redundancy in the event of the failure of one of their mounting points it was agreed for 2011 that the tethers needed to have separate mounting points. The wording for this in 2011 was rather clumsy and had some undesired effects. For this reason we have re-worded art 10.3.6 to ensure that the desired redundancy is delivered in a rational manner.
FOM Cameras
Recent seasons has seen the FOM nose cameras located in a manner clearly aimed at promoting the performance of the front wing rather than to deliver effective TV pictures. A new article (20.3.4) has been introduced to ensure a minimum standard for the field of view of any nose mounted camera. A similar minor change is made to the roll hoop camera location to ensure that a clear picture is not sacrificed on the altar of downforce.
Teutone is offline
post #2 of 2 (permalink) Old 12-13-2011, 11:17 PM Thread Starter
CH4S Artist
Teutone's Avatar
2012 FIA regulations highlights with James Allison – Part II
By Editor on Tuesday, December 13, 2011
Photo credit: Lotus Renault GP
Following the announcement of the FIA’s 2012 season Technical and Sporting Regulations, Lotus Renault GP’s Technical Director James Allison explained the key changes we can expect to see in 2012. Part II is featured below. Part I is available here.
Suspension
Suspension members (wishbones/trackrods etc) are bound by strict aerodynamic limitations (limited chord, symmetrical section, maximum incidence angles etc). This is not true of the uprights which hold the wheel on to the suspension. Their design has always been free. There existed a possibility (albeit never yet exploited) that someone would make a giant, aerodynamic upright to make use of this hypothetical freedom. A change to article 10.5.3 has been introduced to ensure that the uprights may not protrude beyond the volume currently allowed for brake ducts – this prevents the giant upright problem from ever occurring.
Car floor
The floor under an F1 car (the so called step and reference planes) has to be designed flat. Because things cannot be made perfectly flat, a manufacturing tolerance of +/-5mm was permitted. It was felt latterly that this 5mm tolerance allowed for opportunities to design [illegally] some mild contours into the floor. To clamp down on this possibility, the tolerance has been reduced to +/-3mm.
Helium
There has been a recent trend by some teams to use helium as the gas which powers the pit stop guns. This is because helium is capable of making the guns run at higher power for a given gas pressure. It is ruinously expensive however and has been banned for 2012.
Absorbing structures
Each car is fitted with energy absorbing structures on the side of the chassis which act as crumple zones in the event of a side on shunt. These structures are subjected to a crash test at the start of the season where a loaded sled hits them absolutely square on to the chassis. In addition, the structures have to pass a robustness test where they are subjected to a horizontal push-off load to make sure that they will not just flick off the car in the event that they experience a real crash that is not exactly perpendicular to the chassis. In previous seasons we have also had to demonstrate by making stress calculations that the structures would be OK if subjected to a vertical load. For 2012, this stress calculation test is replaced by a physical test as a means of being certain. In theory, this should change nothing. If the calculations were correctly made, then the structure should withstand the load.
Exhausts
The 2011 generation of blown floors are discarded. For 2012, the exhaust must exit in a prescribed box that is in a similar location to the top exit exhausts of circa 2008. It is also subjected to particular exit angles and diameter as a means of providing further restriction. This does not mean that exhaust generated downforce is a thing of the past – it is very hard to stuff that back into Pandora’s box. However these changes, coupled with the recent technical directive banning off throttle blowing create an environment where exhaust generated downforce for 2012 will be a much smaller proportion of the total than it was in 2011.
Technical Directives
For many years there was a growing list of Technical Directives offering guidance on how to operate the electronics and software side of the car in a legal manner. There has been a concerted effort this year by the teams and the FIA to bring the settled parts of these TDs into the main body of the technical regulation to provide a more convenient and more permanent home for them
Teutone is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Mercedes-Benz Motorsports & Racing
    Project Engine MB OM906LA / Allison 6spd Auto- Tranny & Hydro Pto. Monstermog1964 Unimog 19 10-19-2015 04:27 PM
    2012 Honda Civic Si Video Highlights New Features With Animated Graphic Novel Style AutoGuide.com AutoGuide.Com News 0 06-28-2011 09:50 AM
    my weekend by Allison ... yes, I highjacked Daddy's account again Luke@tirerack The Discount Tire Direct Tire, Wheel, Brake & Suspension 5 05-16-2006 12:51 PM
    New Rules and Regulations ML430ish Off-Topic 6 03-09-2004 10:45 PM
    It's official, my SLK is dead...I lost it to Allison. Qui R170 SLK-Class 11 07-06-2001 06:24 AM
