C280 with fault codes 0064, 0060, 0703, etc. - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-22-2012, 03:09 PM Thread Starter
Date registered: May 2012
Vehicle: C280
Looking for some thoughts! I bought my C280 a month ago and now it's coming up with a check engine light and codes 0064 and 0060 (Continuous camshaft adjustment: incorrect position of the exhaust camshaft- left and right), as well as 0703 B70 (crankshaft hall sensor- check wiring of signal line and voltage), C1161 Rotation speed and lateral accelerator sensor plausibility error, C1707 Cruise Control ESP failure, C1025 CAN communication with engine system faulty, C1700 Cruise control engine CAN error. I am disappointed and am wondering what this is going to take to fix. The car sounds clattery upon starting but then gets quieter in a minute or so. I went to start it today and it took four times to start, finally by turning it over for about 5 seconds it started up. Not sure what that was all about.
If anyone has experience with any of these issues, please comment!
ltbrahmas is offline
post #2 of 2 (permalink) Old 05-22-2012, 03:20 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
It would probably help if you specify the YEAR of your car. Mercedes has been making the C280 for a long time and the engines and issues related to them are different.
Also, the safety/testimonial forum is really geared towards that: safety issues, crashworthiness, etc..
There are model/chassis specific forums to help with tech issues such as you're having. So rather than continue this thread, it's probably better to pick the correct forum and repost there.
Good luck.
Check Codes is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > MB Safety & Testimonials
    ESP and BAS Fault Codes tabocat W220 S-Class 16 05-15-2016 01:16 AM
    Fault Codes - 96 C280 jamesjedi W202 C-Class 6 08-13-2014 11:10 AM
    ABS Fault Reading Fault Codes DavidUK1 V-Class 3 09-26-2012 04:27 AM
    E350 07_4matic_error codes 0272 & 0703(camshaft) NetE320 W212 E-Class 2 11-06-2010 09:02 PM
    Fault Codes scabba W124 E,CE,D,TD Class 6 04-30-2007 12:22 PM
