Loud Squeaking! Help - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-02-2012, 04:22 PM Thread Starter
Date registered: Mar 2012
Vehicle: 1995 E320
Hello to all!
I have a question. I have a 95 e320 and I ran through a large flooded road and the next day I have horrific squeaking noise.
When I turn the wheel either side and also when I push on the car to rock it squeaks too. Im wondering if anyone has had something similar. Its sounds like old squeaky wooden floor.
Spicealata is offline
post #2 of 7 (permalink) Old 03-09-2012, 06:38 AM
AMGViper's Avatar
Date registered: Sep 2006
Vehicle: SLR
Send a message via AIM to AMGViper
You dumb ass haha. A Mercedes is not a boat
AMGViper is offline
post #3 of 7 (permalink) Old 03-09-2012, 11:38 AM Thread Starter
Vehicle: 1995 E320
Jack
HAHA yeah guess I was little dramatic. Thanks for your response! Guess you have nothing better to do!!! This forum is not like the respectful BMW!!
post #4 of 7 (permalink) Old 03-12-2012, 01:21 AM
~BANNED~
Date registered: Jan 2012
Vehicle: 1991 560sl / 1987 300TDT / 1995 E300D / 1994 S350D / 1993 300SD /Cummins Diesel PU /2 airplanes
Sorry some people here have been rude to you for just asking a question. There are some very knowledgeable people here that can help you and are very generous with their time but there are a few others that seem to have "issues". Try to ignore the rude posts as these people usually can't help you anyway.
Of course, it's impossible to exactly diagnose a sound like your hearing, over the internet but from what you said I would check it myself or take the car to a reputable shop and have the ball joints and entire front end examined for wear. There are a lot of moving parts under there but this could very well be a warning sign that the boots around the ball joints are torn and have allowed water into the joint. If the ball joints are the cause of this noise you need to replace them ASAP!
These are maintenance free ball joints, no grease fitting, when they are bad they must be replaced.
Check out the W-124 forum as this problem, procedure, cause etc... has been discussed ad nauseam. Not to cause you undue alarm but your front wheel axle could literally become disconnected if the ball joint separates. This has happened to several members here including myself.
Don't ignore this as it could be life threatening. If this were my car I would guess 90+ % that it's the ball joints. I ONLY use OEM ball joints when replacing these. I think it's Mercedes part #124-333-0327 . The job is not that difficult IF you have the correct press tools and some experience, most are easy some are a PITA!. Depending on the age and wear, you might find that you also need control arm bushings, tie rod ends etc...water could have gotten into the wheel bearings if the seals are bad. If you have no experience in this at all, take the car to a good shop you trust, that knows these cars. IMO, absolutely insist on Original Equipment Mercedes replacement ball joints. They are fairly inexpensive online.
Use the search function to look for W-124 ball joint replacement and you should find more than enough information to cause you to have this addressed very quickly.
Good luck!
Rudolf Diesel is offline
post #5 of 7 (permalink) Old 03-12-2012, 01:24 AM
~BANNED~
W124 front suspension is SAFETY CRITICAL ( 1 2 3 ... Last Page)
post #6 of 7 (permalink) Old 03-12-2012, 01:31 AM
~BANNED~
Hope this helps.
Both of these have recently been posted with some photos.
W124 front suspension is DANGEROUS
post #7 of 7 (permalink) Old 05-14-2012, 04:14 PM
Date registered: May 2012
it sounds like your bushings dried out. the fact that you hit the puddle doesn't make sense but it could have just been a coincidence. I'd start there. maybe try greasing them up. hope that helps.
Zimmerautosport is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > MB Safety & Testimonials
w115: Loud, squeaking sound when steering ijiwaru Vintage Mercedes-Benz 6 09-17-2011 07:00 AM
Loud squeaking noise form rear? johnnydee W203 C32 AMG, C55 AMG 5 10-27-2009 05:31 PM
Loud squeaking at idle (270 CDI) davidmilward W203 C-Class 2 08-05-2009 10:18 AM
Belts making really loud squeaking noise zlaja230 R170 SLK-Class 24 04-18-2009 03:14 PM
super loud squeaking noise Badfish2008 W201 190-Class 2 01-07-2009 12:39 PM
