Emergency stop (engine off) with Keyless Go? - Page 5 - Mercedes-Benz Forum
post #41 of 49 (permalink) Old 11-13-2009, 12:06 PM
Date registered: Jan 2007
so what everybody is saying is that there is NO solution?
peacemf is offline
post #42 of 49 (permalink) Old 11-13-2009, 05:13 PM
imo
Date registered: Dec 2008
process would be brake,neutral and pull over
imo is offline
post #43 of 49 (permalink) Old 11-13-2009, 07:59 PM
eric242340's Avatar
Quoted: 306 Post(s)
Or brake, neutral, pull over engage park and switch off engine if it has not already exploded lol.
ERIC.
eric242340 is offline
post #44 of 49 (permalink) Old 11-13-2009, 08:04 PM
eric242340's Avatar
Quoted: 306 Post(s)
I will also add that many models in the Benz range have a rev limiter that works when not in drive. ie you can only rev the engine to 4000 rpm so if this is fitted and you put the car in neutral then the engine will die back to a max of 4000rpm.
Now anyone want to be the guinea pig and put the gas to the floor with right foot brake with left foot and try to put the car in neutral?
ERIC.
post #45 of 49 (permalink) Old 11-23-2009, 02:33 PM
Date registered: Feb 2007
two things. what, in the name of all that's holy, does the stop/start button give us that a key doesn't? What does it advance in terms of safety, over status: 'oooh, look, i've got a push start button'. Ah, jolly good. Good for you.
Second, i've yet to see this type of crash in mainland europe - or indeed any land outside of the usa.
At what point during the car's epic acceleration did the driver realise he was out of control? What was he doing getting to 120mph before it went t1ts up?
Scudetto is offline
post #46 of 49 (permalink) Old 11-24-2009, 01:08 PM
Pringles21's Avatar
Date registered: Aug 2009
Vehicle: 1997 C280
Hopefully actual keys will make a return sometime.
Pringles21 is offline
post #47 of 49 (permalink) Old 11-25-2009, 04:16 AM Thread Starter
E55MKB's Avatar
Date registered: Oct 2009
Vehicle: 00 E55, 09 SL63, 96 P993T
Quoted from the following article in Yahoo,
AP NewsBreak: Toyota to replace 3.8M gas pedals - Yahoo! News
WASHINGTON – Toyota Motor Corp. will replace gas pedals on 3.8 million recalled vehicles in the United States to address problems with sudden acceleration or the pedal becoming stuck in the floor mat, The Associated Press has learned.
As a temporary step, Toyota will have dealers shorten the length of the gas pedals beginning in January while the company develops replacement pedals for their vehicles, the Transportation Department said in a statement provided to the AP. New pedals will be available beginning in April, and some vehicles will have brake override systems installed as a precaution.
This article seems to confirm the earlier statement that (some) Toyota DBW (drive by wire throttle) does not have the "brake override" thus the plan of the brake override installation as one of the corrective measures.
E55MKB is offline
post #48 of 49 (permalink) Old 11-25-2009, 04:23 AM
eric242340's Avatar
Quoted: 306 Post(s)
YES with this statement "and some vehicles will have brake override systems installed as a precaution" they are admitting fault.
It is NOT a pedal stuck on the carpet situation, which is bad enough in itself but they try to cover up the real problem. In this short statement they have gone from blaming the carpet/pedal to sweeping the situation under the carpet
ERIC.
post #49 of 49 (permalink) Old 11-29-2009, 09:34 AM Thread Starter
E55MKB's Avatar
LA Times 11/29/09: Data points to Toyota throttle
Data point to Toyota's throttles, not floor mats -- latimes.com
Getting more interesting!
Ironically the NHTSA did several investigations regarding Toyota unintended accelerations and found nothing but possible floor mats entrapment. Sounds familiar?? Just like the SEC did several investigations on Bernard Madoff investments after multiple complaints and found nothing until the final meltdown . . . . .
E55MKB is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > MB Safety & Testimonials
    Keyless start/stop not working s l 5 5 a m g R230 SL-Class 6 07-11-2008 12:55 PM
    Malfunctioning Emergency Stop Button dlkonecky W123 E,CE,D,CD,TD,TE Class 8 03-06-2008 11:21 AM
    Emergency, my engine doenst start, help help alexus.one General Mercedes-Benz 19 01-05-2008 09:10 PM
    Engine on emergency program? MB E300TD W210 E-Class 7 04-09-2005 07:43 AM
    Pressing STOP lever does not stop engine, Help! IceBlue_1980_300TD W123 E,CE,D,CD,TD,TE Class 5 08-12-2004 04:41 PM
