Which one is the safest Benz? - Page 2 - Mercedes-Benz Forum
post #11 of 35 (permalink) Old 12-21-2010, 06:54 AM
Date registered: Feb 2008
Vehicle: 1987 560SL - Signal Red, 2014 ML350 - Diamond White, 2016 Ford Explorer - Magnetic (company car)
Quoted: 55 Post(s)
Originally Posted by BenzW113 View Post
I guess, but the structure of the S class is far stiffer I believe
and Mercedes probably put down a lot more money developing the safety consept of the S class
the S class have cutting places for the firedepartment, the GL dont
I was under the impression that all newer cars have the cutting instructions as all the airbags and sensors are located in various places and the FD needs to know where to cut without causing any danger to occupants and them self, anyways most MB cars are safe...
2008R320 is offline
post #12 of 35 (permalink) Old 04-27-2011, 05:42 PM
~BANNED~
Date registered: Jan 2011
Vehicle: 2008 C200K (W204) & 1998 SL500 (R129) Imperial Red
Quoted: 25 Post(s)
You guys are ALL wrong!! the S-Class W140 (1991 - 1999) isby far the most safest car out there! Its litrally like a tank, with the double-pane windows and solid 2,5 ton build.. See the crash test for it on youtube, it was tested against an opel corsa.. The corsa was a write off with any occupants dead.. The S-Class W140 did not even crack the windscreen.. Passenger cabin was completely intact, now that is pure safety!!
Not to mention safe agains "Smash & Grab" and Hijacking, as the criminals cannot easily break the windows.. If anybody tried to block you in, you could RAM them out the way and the S-Class will still be drivable to make your escape
S-Class W140, even the W221 does not feel as solid..
bnZE430/1999 likes this.
MafiaDON is offline
post #13 of 35 (permalink) Old 05-02-2011, 07:57 PM
Quoted: 55 Post(s)
No doubt that the W140 is safe, but to test it against an Opel Corsa does not prove that it is the safest, a lot has changed in new safety features and steel options, to I'm pretty sure that is you crash the W140 against the W221 will come out better for the occupants.
It is also important that the car can will act correct during a maneuver to avoid an accident both active and passive safety is important
2008R320 is offline
post #14 of 35 (permalink) Old 05-03-2011, 02:24 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Ah yes, the car in which Princess Diana was killed! One survivor out of four.
http://www.dailymail.co.uk/news/arti...ook-death.html
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #15 of 35 (permalink) Old 05-03-2011, 03:08 PM
~BANNED~
Quoted: 25 Post(s)
Originally Posted by lkchris View Post
hahahahaha, dont be a hater! Or be a hater, its up to you lol!!
Yes that statement is half true.. But that one survivor was the only one wearing a seatbelt, that is why he did survive.
Had Diana, Dodi, and the Driver been wearing seatbelts, I trully belive that atleast Diana AND Dodi would have survived..
W140 is still the strongest built car ever, put against a W221 it would smash the W221 beyond recognition, while occupants in both vehicles would all still be alive becasue both are Benz`s that have various saftey features..
All these new Benz`s are made like formula 1 cars, that explode into hundereds of pieces during a collistion in an effort to save the driver.. I prefer to drive away from fender benders thank you, not have to be towed. Where other softer Benz`s the whole engine would drop to the floor..
MafiaDON is offline
post #16 of 35 (permalink) Old 05-03-2011, 07:08 PM
Quoted: 55 Post(s)
Exactly, that is why you probably have a higher chance to survive in a W221 than W140, strong like a tank does not mean that you will survive, it is all about the deceleration e.g. the g-forces your body and internal organs are exposed too.
Of course if you are in an old small eco box without the safety cage/structure you might not be able to survive anyway.
I believe that the W140 is a safe car but a lot has changed in structures and different steels to absorb the different forces that occur during a crash.
2008R320 is offline
post #17 of 35 (permalink) Old 05-04-2011, 03:54 AM
BenzWorld Elitist
Marsden's Avatar
Vehicle: Mercedes-Benz
Quoted: 450 Post(s)
An S-Class, almost any S-Class since the W126.
Marsden is offline
post #18 of 35 (permalink) Old 05-04-2011, 10:05 PM
Date registered: Oct 2007
Vehicle: '03 Z4, '02 E55, '11 ML350
I feel pretty safe in my W210 E55 but that doesn't mean I drive like some of the idiots out there, testing the laws of physics.
BTW Marsden, interesting photo there. Any info you can share on the car? Brabus Monoblock V's? Early AMG front air dam? Just curious.
I'm not sure of the rest of you, but traveling the highways, I'd have the most confidence in the E and S classes. With a definite thumbs up on the W140.
Cheers !!
Mike K.
Mike K. is offline
post #19 of 35 (permalink) Old 05-05-2011, 11:32 AM
Quoted: 2 Post(s)
Mercedes is more or less the leading car company in the world and makes real advancements all the time. Not a lot of reason to think anything but the latest is the safest. I'd rate the W140 the safest 1990s car there is.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #20 of 35 (permalink) Old 05-05-2011, 12:01 PM
Vehicle: 1985 190E 2.3-16
60's-70's 600 Grosser.
Aside from being stout, it's big, visible, noticable, and intimidating - you're much less likely to have an accident at all. There is a lot to be said for intimidation - I've noticed that when I'm out in my Ford F350, with crew cab and dually rear, my fellow motorists are decidedly more polite. They don't pull out in front of it, don't cut it off, don't tailgate it. With a curb weight of 9300 pounds, it's not a vehicle you want running into you. The safest accident is the one you don't have.
Besides, when you look at the list of dictators and despots who have owned a Grosser, people would think twice about getting near it - they might end up on the wrong end of a death squad.
TrapperJohn is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > MB Safety & Testimonials
    Is Mercedes the safest car around? jackie100 General Mercedes-Benz 17 08-06-2009 11:55 PM
    Which S-Class would you feel safest is?? skipinschool W140 S-Class 38 05-24-2009 07:37 AM
    B Class is Safest -official! hawk20 W245 B-Class 13 02-08-2007 07:15 PM
    Mercedes-Benz E-Class rated safest car in U.S. zergcerebrates MB Safety & Testimonials 9 07-20-2006 07:26 AM
    Safest cars around AnE2pleaz MB Safety & Testimonials 11 04-01-2004 12:44 AM
