» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > General Mercedes-Benz Forums > MB Safety & Testimonials
Old 04-29-2009, 11:20 AM   #1 (permalink)
Date registered: Mar 2009
Transmission
I have 2004 CLK 320 and my car sat for 5 months without being driven in cold weather. When I started to drive my car about 2 weeks ago, the transmission seems to be messed up like it's started in high gear. when I turn off the car and then turn back on, it drives the way it should but then it will act up again in a little while, and now the check engine light came on because it wouldn't go into gear. Does anybody have any advise on what I should do.
dabu260 is offline   Reply With Quote
Old 05-01-2009, 10:42 PM   #2 (permalink)
Date registered: Feb 2009
Vehicle: clk 320
how many miles? 2004 aint that old
silverblade420 is offline   Reply With Quote
Old 05-01-2009, 11:47 PM   #3 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Any sign of leaks? The adapter on the front right of the transmission is known for leaks, can push fluid up to the TCM and trigger limp mode. Get a code reader and plug it in, see what codes you get.
As silver says, how many miles? If you've not serviced the transmission, get it taken care of.
Other possibilities are an obstruction in the air intake, from the initial opening by the radiator all the way back. Critters like to nest, vermin can crawl in and even chew through the air filter. Check all that out. (A badly fouled MAF can trigger limp mode too.)
Do the physical inspection but the big thing is check codes, that will at least give you a hint of what you're looking for.
Take care and enjoy the ride,
Greg
If we ever forget that we are one nation under God, then we will be a nation gone under.
Ronald Reagan
Has anyone who changed their transmission fluid had their transmission fail bavenda W163 M-Class 71 09-14-2008 10:28 AM
Automatic Transmission vrs Manual Transmission gentletyphoon General Mercedes-Benz 2 07-27-2008 07:08 AM
Transmission issues (1990 300E, 3.0L, 722.5 transmission) Eric@StarSuzuki W124 E,CE,D,TD Class 3 11-26-2006 10:11 AM
Automatic transmission question: anyone knows how to make the transmission shift at a higher RPM, DanPro1 R170 SLK Class 8 10-07-2002 02:35 PM
Prefacelift SLK: shift-knobs for automatic transmission can be installed on manual transmission? Marcello (Piacenza - R170 SLK Class 3 04-26-2002 11:05 AM
