Just do a panic stop, hit the brakes hard and fast, you should feel things tighten up if you have the system in your car. If your brake pedal goes to the floor and seems to stay there then you have adaptive braking as well.
AZ.Benz
Adaptive braking, what's that? Or Brake Assist (for full braking power in panic stops)?
S.
2006 ML350 white/ash
2008 C300 Sport mars red/black
2004 986S seal gray metallic/black/black
Vehicle: 2008 Arctic White W204 C350 Sport AMG Pack+Advanged Agility Pack, and 2008 B170 Facelift.
Maybe I must define my question further: I know and understand the breaking applications of safety, like ABS & applied selectively at skidding. This is not my problem.
A Merc owner of the W203 Avantgarde model actually told me that his car swerve away for obsticals in the road, if he does not in time. Ok, I took his word for it, although it sounded mighty suspicious.
Now that I ordered a new W204 myself, I received Merc's correspondence which included a CD called "Serene Agility".
Now if I whatch this CD they actually illustrates this swerving action for a brance in the road. I am sure most of you must have this CD, or it's available as a clip from Mercedes websites. Now I am worried....On investigation on Internet I found all sorts of explanations, but I fail to find the explanation on how this swerving action is accomplished by not sliding in the process to begin with.
Please point me to this decription if available, or explain what they actually try to show with the CD, regarding missing that branch in the road. I believe some people may be totally mislead by this if not the case, cause obviously there are people who belives these cars can do this.
I don't know of any car that will actively steer for you in the event of an emergency swerving or lane change maneuver.
Click here and go to Features & Specs at the top, then Features Spotlight, then ESP. Watch the short video and see if that's similar to the one you have on the CD.
I suspect that the video you're talking about is just another demonstration of ESP, although with a tree branch in the CD. ESP won't interfere unless any wheels are sliding or skidding, as you mentioned.
You're right that some people might get the idea that the car will do the steering for you from viewing the videos. However, that's not the case. The W203 owner might just be one of the many owners out there that doesn't fully understand how the active safety systems work, he just knows it's there and it does something.
If the car had ABS, the wheels would not lock. No locked wheels, no skid marks. At least that's my theory. Someone will correct me if I'm wrong.
ABS brakes do lock, but only momentarily, then they release. Take a look at a slow mo video of an ABS braking system at work. You'll see the wheel lock, release, lock, release, lock etc
Therefore, cars with ABS brakes do leave skid marks, albeit it different ones; rather than long black skid marks, they are staggered marks, much like the markings on a zebra/pelican crossing.
As the steering is still a mechanical device on a car, I doubt that electronic intervention caused the C-Class to crash. Which leaves mechanical failure, driver impairment through drink or drugs, sudden illness (heart attack?) or just good old driver error.
