» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > MB Safety & Testimonials
Old 04-01-2008, 11:54 AM   #21 (permalink)
lsk7's Avatar
Date registered: Jun 2005
Vehicle: 1982 Mercedes 240d, 1999 Mercedes C280 , (1995 Mercedes c220 RIP Demolished 5/08 )
Originally Posted by Asterisk View Post
... DAMN.
Please check your C220, Look at my pictures and then get yours up on the rack..
Lee
lsk7 is offline   Reply With Quote
Old 04-03-2008, 01:29 PM   #22 (permalink)
Date registered: Mar 2008
Vehicle: CLS550 Master Lease, 1990 300zxTT, 2000 camry
Lsk7, I understand what you are saying and was not trying to make it sound unimportant or as though what happened was your fault. But for those of you who do not have this problem yet, please pay attention and clean out the A arm. You can do so with compressed air pretty easy. An easy way to prevent rust would be to spray some automotive grade body wax or sealant in there sometimes. Hindsight is 20/20 and yes it was not the best idea to design the arm the way they did, but I doubt they forsaw a problem like this. And by this being part of maintenance, I meant that responsibility should be for the technician taking care of the vehicle. We are paid to check those type of things out when the vehicle is in the shop. We dont have issues with corrosion where I am from, but technicians in areas where it is an issue should be used to those types of things and should have caught the problem.
kyle21nluvnit is offline   Reply With Quote
Old 04-06-2008, 10:34 AM   #23 (permalink)
Date registered: Dec 2003
this does not apply to 140 right?
96 S500 Coupe. Black on black, 18" AMGs
snik is offline   Reply With Quote
Old 04-07-2008, 05:29 AM   #24 (permalink)
I dont think so, but what would it hurt to lift it up and check it out?
Old 04-23-2008, 09:07 PM   #25 (permalink)
Date registered: Jan 2006
Vehicle: 1999 C43 /w 55 swap, c36 diff, 210 mirror mod, mcs navi, fac. sat, much more
huhh
I understand that it sucks this happened but its a 95!!! depending on the build date it could be 15-16years old and probably higher milage. Its sort of like complaining that my 69 camero has a hole in the floor or quarter. bmw,mercedes,jag,ect. all have diffrent problems
and i do agree this is a maintanice item during one of those many oil changes your mehcanic
did i would think he would of saw somthing. Ive been a master tech for benz for 10 years and i have never seen this happen before....
hcetzneb is offline   Reply With Quote
Old 04-28-2008, 02:30 PM   #26 (permalink)
Date registered: Apr 2007
Vehicle: 1999 E320, 1975 450SEL, 1979 280SE
A hole in the floor or quarter would not cause a sudden failure that could result in a fatal accident.
rabbit188 is offline   Reply With Quote
Old 05-26-2008, 06:31 PM   #27 (permalink)
PWogaman's Avatar
Vehicle: 1985 300SD, 1980 280SL
Originally Posted by kyle21nluvnit View Post
Like I said even on the ones with the drain holes it still has to be cleaned out. You can also clean and retreat the ones without drain holes. So in a way yes it is a maintenance item.
Perhaps you could direct us to the part of the service manual to spells out how often this "maintenance" should be performed: once a day? once a week? once a year? Once a mile? And, what the specific maintenance is - what is the task number? How many hours should a shop charge to perform it? How long could we disregard the timing of the inspection before we would be considered negligent ourselves?
Bottom line, if this maintenance item is not specficically called out as requiring a certain periodic inspection then it is a design issue. I.e., it was not designed to be maintained. All cars come with recommended/required periodic inspections and maintenance and if the purchaser is not put on notice of it then it is not their fault.
Current
1985 300SD - 152K miles;
1980 280SL - The Green Hornet;
2001 SAAB V6 Wagon - 57K miles;
1996 Dogde Grand Caravan SE - 121K;
Former
1987 VW Cabriolet; 1987 VW Golf GL; 1987 Ford Ranger; 1980 VW Rabbit; 1980 Dodge Ramcharger Snow Commander; 1975 Simca; 1967 VW Beetle; 1959 Bultaco; 1957 VW Beetle; Honda CX500; Kawasaki 250; Honda CB50
PWogaman is offline   Reply With Quote
Old 05-29-2008, 06:55 AM   #28 (permalink)
lsk7's Avatar
Unhappy Well it doesn't matter anymore
Well it doesn't matter anymore for my c220, By the way the Insurance adjuster said after inspecting my (old) 1995 he thought it was a much newer car because the interior and body were "like new" with no visable wear...
Can you tell that I replaced my lower support arms a month or 2 ago ??
Old 05-29-2008, 10:55 AM   #29 (permalink)
MB-SV's Avatar
Date registered: Nov 2007
Ohh, very bent.
S.
2006 ML350 white/ash
2008 C300 Sport mars red/black
2004 986S seal gray metallic/black/black
MB-SV is offline   Reply With Quote
Old 06-02-2008, 03:57 PM   #30 (permalink)
sphinxrider's Avatar
Date registered: Oct 2007
Vehicle: 1987 300SDL
Originally Posted by Mike Tee View Post
Rubbish, what a stupid comment.
agreed!
sphinxrider is offline   Reply With Quote
Front spring fell out mistel W123 E,CE,D,CD,TD,TE Class 9 03-17-2008 08:37 AM
The front fell off.. Kwik SC Off-Topic 4 01-24-2008 07:28 AM
1995 C220 Front Brakes Sam Salter W202 C-Class 7 05-06-2007 10:22 PM
Rusted Wheel Bolts! wcairns W203 C-Class 4 03-25-2007 05:52 AM
1995 C220 Noele W202 C-Class 11 10-09-2003 09:26 PM
