Dyno C32 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-20-2006, 12:14 PM Thread Starter
Date registered: Feb 2006
Send a message via MSN to TonyC32
Dyno C32
Anybody out there know the proper way to dyno a c32. I had a shop try and even with the dash ESP turned off, it only layed down 240 @ the wheels. On the 1/4 test it would fall flat after 3rd gear. Any tricks or is there some sort of dyno mode?
TonyC32 is offline
post #2 of 2 (permalink) Old 02-20-2006, 04:21 PM
Andrew2004az's Avatar
Date registered: Feb 2004
Vehicle: 02 ML 320
RE: Dyno C32
there is a dyno mode. it turns off ESP your best bet is to search the C lass section cuse its a combo of buttons you have to press on startup. not sure if that will work on the C32 since its older you might have to plug into a computer and turn it off.
Andrew2004az is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > MB Safety & Testimonials
