» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > GL Class
Old 08-25-2009, 06:31 PM   #1 (permalink)
Date registered: Aug 2009
Rectify tire pressure.
I just bought a certified 2007 GL 450. I have had it for a week. It is a great drive.
Today I had to reset the remote garage door opener. I think that if affected my TPMS. I have tried to reset my TPMS, but after shutting off the engine, I get "Rectify Tire Pressure" on the dash display.
Is there an easy fix to this problem or does the dealer have to reset the monitor?
Panthervision is offline   Reply With Quote
Old 08-25-2009, 08:18 PM   #2 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI, '06 350SLK
The easy fix should be to actually check your tire pressure and correct it to what it should be.
I'd say it's coincidence that this occurred in a similar timeframe as working on garage door opener.
Kent Christensen
Albuquerque
'07 GL320CDI, '06 E320CDI, '06 SLK350
lkchris is online now   Reply With Quote
Old 08-26-2009, 05:18 AM   #3 (permalink)
Sorry, I forgot to mention that I did fill the tires to the recommended pressures listed on the driver's door. I read in the manual that 2 way radio transmission may interfere with the TPMS. The manual suggested to reset the TPMS after changing the tire pressures.
BTW, when I did check the tire pressures after getting the original message, all tires were at 32PSI. The recommended pressures in the door were 32FR and 38Rear.
Old 08-26-2009, 10:59 AM   #4 (permalink)
Date registered: Feb 2005
Vehicle: '03 CL500,& '07 GL450
Pages 395 and 396 of the owners manual show how to reset the monitor.
'03 CL500,'07 GL450
reddog is offline   Reply With Quote
Old 08-26-2009, 11:11 AM   #5 (permalink)
Thanks
Resetting seems to have worked.
Correct tire pressure for low profile tire on R129 bkksl R129 SL Class 13 07-15-2009 09:29 AM
Tire pressure klee8 W163 M-Class 5 01-17-2008 06:09 AM
taking down tire pressure for 4x4 ing. could you do that on a low profile tire? blau The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 01-06-2006 02:49 PM
Tire Pressure Big D W126 S,SE,SEC,SEL,SD,SDL Class 1 09-08-2003 07:45 PM
Tire Pressure BillP W211 E-Class 2 03-28-2003 11:41 AM
