» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > GL Class
Old 06-10-2009, 11:25 AM   #1 (permalink)
Date registered: Feb 2007
Easy Entry Feature
Hello GL'ers!
I have a quick question... every time my wife folds down the 2nd row seat to allow acces to the 3rd row for my son, the FRONT passenger side seat moves up a few inches. In order to get it back to normal you have to push one of the memory buttons on the front passenger seat.
This never used to happen, but after taking it in for service, it started happening.
I read the manual, supposedly deactivating the "easy entry feature" should do the trick but it only works for the driver seat.
Anyone out there know how to disable this feature so the passenger seat stays put? Not a big deal, but the fact that this never used to happen tells me there must be a way to disabel this "helpful feature". I'll call the service advisor, but I get the feeling you folks know more in here than they do.
Thanks in advance!!!
gteach26 is offline   Reply With Quote
Old 06-10-2009, 04:53 PM   #2 (permalink)
Date registered: Oct 2007
Vehicle: GL320 CDI - 2008, '85 Unimog U1700, 2000 Golf TDI 2 dr, '83 Mitsubishi 4WD turbodiesel PU
The feature (moving the front passenger seat forward) is necessary to assure there is enough room to fold the 2nd row seat forward. If that didn't happen it would be necessary to add a sliding door! The big issue seems to be if the car can be 'taught' to return the front seat to whatever position it was in before the 2nd row seat folded. I'm not sure of the answer, but try approaching the Service Advisor with that question.
Fourdiesel is offline   Reply With Quote
Old 06-23-2009, 12:44 PM   #3 (permalink)
Franman's Avatar
Date registered: Apr 2009
yeah - Im pretty sure it must have always happened as Fourdiesel points out b/c if not, the 2nd row would hit the passenger seat and wouldnt fold all the way down. Especially bad if you have the '09 model with Rear Entertainment as it would directly hit the screen.
Franman is offline   Reply With Quote
Old 06-24-2009, 12:32 PM   #4 (permalink)
b757236's Avatar
Date registered: Aug 2007
Easy entry has to do with the steering wheel moving up when you shut the car off. It has nothing to do with the front passenger seat moving up because you are accessing the 3rd row. My front passenger seat moves forward then I have to reach over and press the memory button. I set the "number 2" button because it is easier to reach from the drivers seat-it is higher than number 1 I wish it would return when you lock the second row but I think that is wishful thinking at best
Adam
2007 GL 320CDI
Every option on board
2003 BMW M5
b757236 is offline   Reply With Quote
Old 06-25-2009, 09:16 PM   #5 (permalink)
Date registered: Jun 2008
Vehicle: 2008 GL 320
Funny. These overworked engineers forgot to move the seat back. I swore when I found that feature. Why should I have to use a memory switch when the seat could have done it for me?
I owned a 1989 Volvo 780, a 2 door model. It had power front seats, and when you moved the seat back forward to gain access to the rear seat, the motor engaged and moved the seat forward. When you flipped the seat back back to the upright position, the seat would move back to the prior position. This was in 1989!!!! On a Volvo!
Tenty years later, Mercedes can't do it on a $70K car???
Somewhat disillusioned...
This is a great driver's car, except for the comand center and lack of gauges.
The little gremlins come and go at will.
klausc is offline   Reply With Quote
EASY ENTRY/EXIT FEATURE 2000 S 500 sammy515151 W220 S-Class 3 01-13-2010 08:32 PM
Easy-entry feature in DAS ole320 W203 C-Class 5 02-13-2009 09:54 AM
Easy-entry feature in DAS ole320 W203 C32 AMG, C55 AMG 0 02-07-2009 10:02 AM
Easy-entry/exit feature on ML Courage W164 M-Class 18 02-04-2008 07:21 AM
Easy-entry/exit feature Skylaw W220 S-Class 2 11-26-2004 08:35 AM
