» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > GL Class
Old 11-03-2008, 09:10 PM   #1 (permalink)
Date registered: Nov 2008
Easy to Remove Running Boards?
Many of the new GL450's come with running boards, either as a separate option or with the Appearance Package.
I would want a GL450 without running boards as I tend to drag my calf across them when getting in and out of the car.
Does anyone know if it is easy to remove the running boards, and if there are any visual signs that the running boards were there after you take them off (mounting holes or other evidence of the mounting)?
Thank you.
ddlv is offline   Reply With Quote
Old 11-07-2008, 06:56 PM   #2 (permalink)
Date registered: Aug 2008
The running boards are intended for use as a step, which if so used, may alleviate your dilema.
greul is offline   Reply With Quote
Old 11-09-2008, 10:56 PM   #3 (permalink)
Date registered: Sep 2006
Vehicle: 1971 280SL, 2007 R320CDI (White/Macadamia)
Good question. I just upgraded from 2007 leased R320CDI to a GL320CDI with running boards. This was a demonstrator with running boards but at 6'-3" I hardly need to step up on a running board and then duck to get in the door. Any ideas or answers to the question?
tompat42 is offline   Reply With Quote
Old 11-10-2008, 07:51 PM   #4 (permalink)
I hear you tompat42. At 6'5 I share in your experience. I too had the same problem as DDLY, especially when wearing a suit...that is until I started stepping directly onto the runningboard. Initially, was scared it wouldnt hold my weight 240, but it did without hesitation. In any event it takes a bit getting used to. Some models have a "comfort feature" whereby the vehicle will actually lower itself during the entry/egress process - this can be set by scrolling throught the controls on the steering wheel. I'm glad I kept the running boars as they are visually appealing and functional nonetheless.
Looking for running boards bkdewitte GL Class 3 02-11-2008 07:31 PM
anyone know where i can get running boards roughyear W164 M-Class 2 12-19-2006 10:29 AM
need running boards roughyear W164 M-Class 2 11-10-2006 02:47 PM
ML running boards-how to remove? JMPRO General Mercedes-Benz 3 04-19-2006 05:32 AM
Running boards BordeauxBentz W163 M-Class 7 08-15-2005 11:38 AM
