» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > GL Class
Old 08-05-2008, 09:16 PM   #1 (permalink)
Date registered: Oct 2007
Oil Type for GL 320CDI
I would like to know the type of oil to use in an GL 320cdi. This vehicle does not have a particle filter.(build 07) I prefer to use castrol.
merc01 is offline   Reply With Quote
Old 08-06-2008, 06:28 PM   #2 (permalink)
Vehicle: GL320 CDI - 2008, '85 Unimog U1700, 2000 Golf TDI 2 dr, '83 Mitsubishi 4WD turbodiesel PU
Use ONLY the oil specified to meet the M-B spec on the sticker in the engine compartment. As far as I know, only Mobil 1 ESP and ELF Solaris 5W30 are specified on the container to meet this specification.
Fourdiesel is offline   Reply With Quote
Old 08-07-2008, 09:40 AM   #3 (permalink)
Date registered: Jun 2008
Vehicle: 2008 GL 320
Castrol is not on the list. There are 3 different oils listed in the back of the owner's manual. Lots of luck finding any of them in your local autoparts stores.
Somewhat disillusioned...
This is a great driver's car, except for the comand center and lack of gauges.
The little gremlins come and go at will.
klausc is offline   Reply With Quote
Old 08-07-2008, 11:13 AM   #4 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI, '06 350SLK
Use Mobil1 Formula M ESP (emissions system protection) which is only available at Mercedes dealers.
There's a sticker in the engine compartment warning to not use ANY QUANTITY of anything else. Otherwise, you'll jeopardize warranty on particulate filter and it will be damaged.
Oil must meet Mercedes 229.51--this is NOT the same as Mercedes 229.5.
No exceptions.
BTW, if you change your oil early, you'll create damage. Follow ONLY Mercedes 10K mile specified intervals.
This is not 1956.
Kent Christensen
Albuquerque
'07 GL320CDI, '06 E320CDI, '06 SLK350
Old 08-07-2008, 03:54 PM   #5 (permalink)
Mobil ONE formula M ESP is available from any large Chevron / Mobil oil distributor. [They may have to order it for you] I was able to order a case of six quarts (that was before I realized the oil change took 9 L!) from Wilcox and Flegel, a local Chevron/Mobil jobber in Longview, WA. Look an the yellow pages for oil distributors/jobbers in your area.
Old 08-27-2008, 03:35 PM   #6 (permalink)
No exceptions.
This is not 1956.
Next week, Sept 3, I will be taking my GL320 in to have the oil sender replaced. Is that going to do any harm? Should I have them replace the particle filter, just for fun?
The mechanic was so nice, he even "swiped" 2 quarts of oil and put them in my car so that I won't run out when I am in the hinterlands looking for 229.51 oil.
My car only has 5,000 miles on it and I don't want to suffer future problems by replacing that black, ugly stuff with new, shiney, oil.
Old 08-27-2008, 03:53 PM   #7 (permalink)
I had the dealer replace my oil sender 2 wks ago and they basically did an oil change for me (without the filter change) they put in Mobil 1 ESP in place of my ELF (now Total Quartz) Solaris that I had put in for the 1st oil change. All I need to do now is reset the display again!
Regarding the particulate filter: That part is welded into the exhaust system and I don't think they will replace it even if you asked them VERY nicely!
Old 09-13-2008, 01:13 AM   #8 (permalink)
Date registered: Sep 2008
Damage by early oil change???
No exceptions.
This is not 1956.
Kent,
How do you create damage (and what is damaged?) when your oil change happens before the 10k interval? Somehow, I've always thought that the clean oil is better for the engine that the used and "dirty" oil. But of course, I may be wrong.
Cheers!
Mirek
guittarr is offline   Reply With Quote
Old 09-13-2008, 04:26 PM   #9 (permalink)
The oils that meet MB spec are depositing protective features in your engine. They don't if you change them early. There is zip/zero/nada benefit to early oil changes--this is the 21st century and things aren't what they used to be.
Change intervals for Mercedes in Europe are 19k miles, but MBUSA recognizes that the USA is filled with DIY geniuses and therefore specifies 13K/10K here.
Old 09-17-2008, 03:28 PM   #10 (permalink)
+1 Even VW has a 2 year oil filter for Europe.
If anything, I would change just the filter at the 5-6K point, but that is probably overkill.
Oil viscocity for GL 320CDI dpallone GL Class 8 04-18-2008 05:40 PM
05 C230K Remove Oil Cap - What type Motor Oil FLBenz W203 C-Class 3 11-06-2007 07:53 AM
Type of Oil to use in Oil Change Paul Mellerowicz W210 E-Class 17 09-22-2007 07:02 PM
Oil Change and oil type HyperLite W202 C-Class 3 03-20-2006 06:20 AM
TYPE of OIL lushansilva R170 SLK Class 12 10-10-2004 10:00 AM
