Vehicle: 2008 Mercedes Benz GL450, 2007 BMW M6 convertible, 2005 BMW 525i, 2003 BMW Z4
Ok, so I got the PIAAs, I tried to replace the headlamps but got stuck. I got to the final step of actually removing the bulb from the connector... is there a trick because the sucker does not give. The manual makes it sound simple and easy but I can't get the bulb off the connector housing short of extreme force. Any help would be greatly appreciated!
<><><><><><><><><><><><><><><><><><><><> 2008 Mercedes Benz GL450 - Iridium Silver/Gray
2007 BMW M6 Convertible - Silverstone/Silverstone II
If you need, slide a small flat head screwdriver between the metal part of the bulb and the metal part that holds the bulb to the lamp. The pieces are sandwiched together very closely. You may be grabbing the back of the metal piece instead of the back side of the bulb. It shouldn't requre that much force.
