Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > GL Class
Old 07-08-2008, 06:42 PM   #11 (permalink)
DrGL's Avatar
Date registered: Jun 2008
Vehicle: 2008 Mercedes Benz GL450, 2007 BMW M6 convertible, 2005 BMW 525i, 2003 BMW Z4
Ok, so I got the PIAAs, I tried to replace the headlamps but got stuck. I got to the final step of actually removing the bulb from the connector... is there a trick because the sucker does not give. The manual makes it sound simple and easy but I can't get the bulb off the connector housing short of extreme force. Any help would be greatly appreciated!
2008 Mercedes Benz GL450 - Iridium Silver/Gray
2007 BMW M6 Convertible - Silverstone/Silverstone II
DrGL is offline   Reply With Quote
Old 07-11-2008, 06:00 PM   #12 (permalink)
Date registered: Nov 2002
Vehicle: 560 SEC Supercharged(sold), E55 AMG, Renntech CL600 Bi-turbo, Porsche 928
If you need, slide a small flat head screwdriver between the metal part of the bulb and the metal part that holds the bulb to the lamp. The pieces are sandwiched together very closely. You may be grabbing the back of the metal piece instead of the back side of the bulb. It shouldn't requre that much force.
Supercharged SEC is offline   Reply With Quote
Problem with upgrade of my 2000 hella halogen headlights to newer style hella projector halogen. tsource1 W163 M-Class 8 01-08-2007 03:37 PM
halogen headlight upgrade? Roman W163 M-Class 4 12-03-2004 09:25 AM
Halogen Upgrade??? RHoodJr W163 M-Class 6 08-09-2002 09:59 AM
Question about 2002 halogen headlight upgrade... M. Ozcan W163 M-Class 13 04-18-2002 10:12 AM
ML320 2001 Headlight Upgrade to Halogen 2002 Peter - San Francisc W163 M-Class 10 02-03-2002 12:35 PM
