Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > GL Class
Old 04-16-2008, 03:28 PM   #1 (permalink)
Date registered: Jul 2007
Vehicle: 2008 GL320CDI, 1999 E320 Wagon 4Matic
Oil viscocity for GL 320CDI
My oil is low, can I add 1 quart of Mobil One synthetic 10W30? Is this the right viscocity? I can't find the information in the owner's manual.
dpallone is offline   Reply With Quote
Old 04-16-2008, 03:43 PM   #2 (permalink)
Date registered: Sep 2005
Vehicle: 2002 ML320 - Capri Blue!!
The only oils approved for CDIs are 229.51 low ash specification oils.
Here is a list of approved oils for MBs: Mercedes-Benz Engine Oil Recommendations Oils approved for diesels are noted as such. Mobil1 ESP Formula 5W-40 is found easily at the dealer.
asianml is offline   Reply With Quote
Old 04-17-2008, 01:11 PM   #3 (permalink)
Date registered: Apr 2008
Vehicle: R350
I would make sure that it's not a problem with the level sensor before you add oil. I've had that problem on ML and GL CDIs. It seemed to happen after driving for a few hundred miles.
AaronATL is offline   Reply With Quote
Old 04-17-2008, 02:17 PM   #4 (permalink)
It is not the sensor since I checked the dipstick and it is at the bottom below the appropriate range. I think it makes sense since the truck has 8,000 miles and I had the oil changed at 3,000 miles. I will take it to the dealer for the 10,000 mile service and have the oil and filter changed. Any thoughts?
Old 04-17-2008, 04:52 PM   #5 (permalink)
Date registered: Oct 2007
Vehicle: GL320 CDI - 2008, '85 Unimog U1700, 2000 Golf TDI 2 dr, '83 Mitsubishi 4WD turbodiesel PU
First oil change should have been at 10,000 mi. The 'factory' oil needs to stay in that long to properly break in the engine and 'set' the additive package. In any event, use ONLY the Mobil ESP oil specified. Not usually too hard to find and it is NOT equivalent to Mobil 1 from Walmart.
Fourdiesel is offline   Reply With Quote
Old 04-17-2008, 06:18 PM   #6 (permalink)
Vehicle: 08 gl320 cdi
My SA said to stop in whenever my 320 needed oil and he would top it off. Don't wait for 10k miles. Call yours and see if he will offer to do it.
BTW, The factory oil is no different than the required Mobil 1 ESP Formula M 5W-40.
Previously: 04 e55, 01 clk55, 99 ml320
ima55r2 is offline   Reply With Quote
Old 04-18-2008, 08:41 AM   #7 (permalink)
mitaka's Avatar
From what I know MB does not use break in oil like some other Japanese makers do. So changing the oil earlier is fine. Diesel engine does not fully break in for 20 25k miles. It takes that long for the engine to achieve optimum compression.
07 R320 CDI 4MATIC
05 Dodge Durango HEMI
08 Honda CR-V EX-L AWD
Previous cars:
Audi A8 4.2 Quattro
Audi A4 1.8T Quattro
VW Passat 4 Motion
Honda Accord Hybrid
mitaka is offline   Reply With Quote
Old 04-18-2008, 03:23 PM   #8 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
CAUTION
There's a sticker under your hood that states that you may not add ANY QUANTITY of non-complying motor oil.
Forget questioning "viscosity," just get the proper oil at your Mercedes dealer--it's the only place it's available.
Kent Christensen
Albuquerque
Old 04-18-2008, 04:40 PM   #9 (permalink)
Fuchs TITAN GT1 229.51 SAE 5W-30 (first fill oil in OM 642) is different from the Mobil 1 ESP change oil that M-B approves. It may not be classed as a 'break in' oil, but it DOES have a different additive package. Those additives require time to work, hence the 10,000 mi first change interval. Most subsequent change intervals are longer - depending on your driving conditions and habits.
For more info see: Wolfgang's ML Page
Oil Viscocity for 560s NC_Mike W126 S,SE,SEC,SEL,SD,SDL Class 18 01-26-2007 07:20 PM
320cdi triturbo Germanick R230 SL Class 4 01-26-2007 02:57 PM
Any info on when the 320CDI will be available? mbr129 W164 M-Class 2 07-07-2005 08:28 AM
2 problems for '00 320CDI matteus W210 E-Class 1 06-30-2003 07:55 AM
Oil viscocity (sp) BigBoutitBenz W126 S,SE,SEC,SEL,SD,SDL Class 1 12-29-2002 10:29 AM
