» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > GL Class
Old 06-10-2007, 10:50 AM   #1 (permalink)
Date registered: Jun 2007
kleen wheels
HAS ANYONE EVER USED THESE? IF SO DO THEY WORK WELL?
Kleen Wheels are dust shields which protect your wheels from brake dust
JCHAP is offline   Reply With Quote
Old 06-10-2007, 01:02 PM   #2 (permalink)
Date registered: Dec 2006
I haven't seen a first hand report of anyone's usage but these have been discussed before. It seems that the heat build up is a concern with these.
oknish is offline   Reply With Quote
Old 06-11-2007, 04:16 PM   #3 (permalink)
boxboss's Avatar
Date registered: Jan 2007
Vehicle: 07 GL450 05 645Ci
See this thread: Brake Dust post #9 and up.
2007 GL450 Obsidian Black/Macadamia Leather
2005 645Ci Mineral Silver/Beige
2004 745Li Toledo Blue/Grey
boxboss is offline   Reply With Quote
Old 12-04-2007, 04:26 PM   #4 (permalink)
Date registered: Nov 2006
Vehicle: 07 gl 450 and 07 s550
i have them on my gl. they work great. no dust at all. no heat problems. go for them
spencerdillman is offline   Reply With Quote
Old 12-05-2007, 07:50 AM   #5 (permalink)
Date registered: Dec 2007
Being a new member to this forum, I have not researched previous posts on brake dust issues and squealing, so here's my humble opinion.
After having owned 15 MB's over the last 20 years, I would never recommend a brake dust shield on any car. If you are a less than enthusiastic driver, live in a cooler climate, and do not tow anything, you may be lucky and not have any overheating or warpage issues.
Mercedes and other manufacturers spend considerable time and effort in keeping the brake components supplied with adequate ventilation in order to eliminate brake fading and overheating during normal use. Any kind of shield totally negates this.
If you are really serious about eliminating brake dust, change your pads to an approved composition that does not deposit as much dust as the factory pad.
A good recommendation is the Rotex pad, which has German TUV approval.
This pad is quiet, has high initial grip, stops well, does not cause excessive rotor wear, emits about 50-70% less dust, and will last slightly longer than the stock pad.
Brakewarehouse.com – Brakes, Brake Pads, Brake Rotors, Calipers has these pads at adecent price.
I have used these pads on the last 6 of my MB's with great results and zero problems.
The squealing problem is caused by a high frequency vibration of the brake pad against the brake piston surface. It usuallly occurs at slight to medium braking application.
Some pads have anti-vibration shims to help stop this, but a better solution is to spray a thin silicone coating on the back of the pad before reinstalling. This thin coating absorbs the vibration and stops the noise. This product is available at any auto parts store.
atlantamb is offline   Reply With Quote
Old 12-05-2007, 10:52 AM   #6 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
Kleen Wheels have been banned by Mercedes for decades.
Kent Christensen
Albuquerque
'07 GL320CDI, '06 E320CDI, '06 SLK350
Old 12-07-2007, 09:02 AM   #7 (permalink)
MB-SV's Avatar
Date registered: Nov 2007
I'm avoiding the clean shields on my ML. I prefer to see the large rotors through the open spokes of my 19" wheels. And I don't want to compromise the brake cooling.
S.
2008 Mercedes C300 Sport mars red/black
2007 Lexus IS350 Sport Pkg. smoky granite metallic/gray
2002 Jeep KJ 4wd Sport white/gray
MB-SV is offline   Reply With Quote
Old 07-04-2009, 02:47 PM   #8 (permalink)
i have kleen wheels and have no problem. they work great
Old 07-10-2009, 02:43 PM   #9 (permalink)
Date registered: Jun 2008
Vehicle: 2008 GL 320
I just wash my wheels when they get dirty
Somewhat disillusioned...
This is a great driver's car, except for the comand center and lack of gauges.
The little gremlins come and go at will.
klausc is offline   Reply With Quote
Old 08-12-2009, 05:47 PM   #10 (permalink)
i have them. no problems. i just powder coated my stock wheels and they match the white body. look great. 350$ for all wheels
Kleen Wheels Bartek W163 M-Class 8 09-25-2004 01:44 PM
Kleen Wheels Fiddlefoot W123 E,CE,D,CD,TD,TE Class 2 07-05-2004 11:13 AM
Kleen Wheels Chupper W124 E,CE,D,TD Class 0 10-08-2002 09:25 PM
Kleen Wheels Arnold W163 M-Class 5 04-03-2002 11:35 AM
Kleen Wheels Guest (MBNZ) W210 E50 AMG, E55 AMG 4 01-10-2001 08:31 AM
